problem-problem-problem
stathi02
paidia exo athlon xp 2700+.Akouste ta ola kai skeftite to ligo sovara san na itan diko sas to pc.Loipon exo kanei tin eksis ma@#$@# apo tote pou ton pira.Exo mono ton anemistira tis manas tou gia ton CPU.Episis exo to kouti to plaisiou(nai auto to terastio).Olo to xeimona tin evgala kala.Prin kana dio mines arxisa na perno mple othoneskai restart tou tipou:
You may receive the following Stop error message:
STOP: 0x0000009C (0x00000004, 0x00000000, 0xb2000000, 0x00020151)
"MACHINE_CHECK_EXCEPTION"
The four parameters inside the parentheses may vary.
This behavior occurs because your computer processor detected and reported an unrecoverable hardware error to Windows XP. To do this, the processor used the Machine Check Exception (MCE) feature of Pentium processors or the Machine Check Architecture (MCA) feature of some Pentium Pro processors. The following factors may cause this error message:
System bus errors
Memory errors that may include parity or Error Correction Code (ECC) problems
Cache errors in the processor or hardware
Translation Lookaside Buffers (TLB) errors in the processor
Other CPU-vendor specific detected hardware problems
Vendor-specific detected hardware problems
STATUS
oi thermokrasies sto pc einai pragmati ipsiles
45 sto couti kai 61 sto cpu se iremia
kai 51 kai 71 meta apo kana paixnidi afou vevea exei stamatisei(to game)
Loipon epeidi den eixa xrono na asxolitho exo valei enana anemistira me
anoixto to case kai otan einai anoixtos den kanei restart (mono mia fora otan itan gia kana 4oro anoixtos).Antitheta otan ksexaso na ton anikso meta apo ligo restart.
Kai tora tha ithela prin pao gia sistima psiksis kai kainourgio case (tha tou valo auto me tous efta anemistires) na sigoureuto oti ola auta einai apo
ti thermokrasia!!!(iparxei kana programa na elekso eksidikeumena to cPU?)
me liga logia thelo na do an exei epelthei provlima sto cpu i allou(mnimes)gia na ksero ti tha kano.(den tha antekso na doso 200-300 euro kai na do ta idia)
A telionontas(epitelous) kai sto media player me ton anemistira anoixto troei kolimata pou den etroge).
Parakalo pes te mou ti gnomi sas genika kai ligo ipeuthina
1000 signomi gia to terastio POST
Euxaristo poli!!!
na simpliroso kai kati allo apo ta restart kai tis mple othones
A machine check exception occurs when Windows XP and your hardware platform cannot recover from a hardware error so that the system can continue to run successfully and reliably. More specific diagnosis of machine check exceptions is difficult, and there is no general solution. Contact your hardware manufacturer or a computer hardware technician for help with troubleshooting this issue.
Machine check exceptions are frequently caused by one of the following conditions:
You are running the processor or mainboard beyond its specifications. For example, you are overclocking the processor or bus. We recommend that you run your hardware at the manufacturer-rated speeds.
Noisy power, overstressed power strips, outmatched power supplies and failing power supplies can destabilize your computer. Make sure that you have a stable, reliable power supply to your computer.
Extreme thermal conditions caused by the failure of cooling devices such as fans may damage your computer. Make sure that your cooling devices are all working.
You have damaged memory or memory that is not the correct type for your computer. If you recently changed the memory configuration, revert to the previous configuration to determine what is wrong. Make sure that you are using the correct memory for your computer.
Για αρχη για κανε ενα post των full specs του μηχανηματος σου...δηλαδη πες μας αναλυτικα τι περιεχει ο υπολογιστης σου...
τωρα με μονο τον επεξεργαστη που μας λες δεν μπορει καποιος να καταλαβει και πολλα...
Το προβλημα που αναφερεις ετσι οπως το αναφερεις μου φαινεται σαν να ειναι οντως προβλημα θερμοκρασιας.
45 βαθμοι στο κουτι ειναι αρκετα υψηλη θερμοκρασια οπως επισης και στον επεξεργαστη.71 βαθμους σε καποιο παιχνιδι?????
Μια αλλη περιπτωση ειναι να εχεις υπερχρονισει καποιο απο τα μερη του υπολογιστη σου επεξεργαστης,καρτα γραφικων,
μνημες σιγουρεψου οτι οντως ειναι οκ αυτα...στην αναγκη κανε και ενα setup bios default αν δεν ξερεις τι εγινε....
Τωρα οσον αφορα την θερμοκρασια στον επεξεργαστη δοκιμασε να αφαιρεσεις την ψυκτρα και να βαλεις παστα καλα πανω και να κουμπωσεις την ψυκτρα παλι επανω με προσοχη...
Αν δεις οτι παλι η θερμοκρασια του επεηεργαστη σου ειναι ακομα ψηλη αγορασε μια αλλη ψυκτρα ουτως η αλλως δεν προκειται να σου παει χαμενη.
Υστερα κοιταξε λιγο και το τροφοδοτικο σου.Σου δινει τις απαραιτητες τασεις?
Ψαξε τελος και λιγο τις μνημες σου...κοιταξε ειναι συμβατες με την μητρικη σου τρεχουν στα ορια που δινει ο κατασκευαστης της μητρικης?
Συνηθως οι μπλε οθονες και τα restart οφειλονται η
1ον στις μνημες του μηχανηματος αν δεν ειναι καλα τοποθετημενες,η αν δεν υποστηριζονται η αν τις εχεις υπερχρονισει και δεν τις <<σηκωνει>> η μητρικη
2ον Σε καποιο conflict που γινεται αναμεσα σε καποιες απο τις συσκευες και
3ον απο τις θερμοκρασιες ειτε του επεξεργαστη ειτε της μητρικης ειτε των μνημων η καρτας γραφικων.
Δοκιμασε αυτα που σου γραφω παραπανω και κανε ενα post για να δουμε πως παει το θεμα...
*****Για οτι περιγραφεται σε αυτο το post δεν φερω καμια ευθυνη για κακη μεταχειρηση χρηση η σφαλμα σου που
τυχον προκυψει στο μηχανημα.Απλα σου λεω μερικες περιπτωσεις στο τι μπορει να συμβαινει....
Μπορεις παντα να πας και σε ενα καταστημα υπολογιστων για να σου
το δει καποιος τεχνικος... :) :)
loipon exo
motherboard:APOGΣΣ
CPU:ATLON XP 2700
MNINMI: 1 512 DDR KINGSTON 333
KARTA GRAFIKON:FX 5200
SKLIRO EXO WESTERN AND DIGITAL 80 gb
AUTA
APO IPERXRONISMO DEN PAIZEI TIPOTA OLLA EINAI OK
ETREKSA KAI ENA TEST GIA MEMORY(OXI POLI KAMIA ORA) KAI DEN VRIKE KANA LATHOS.
THA DO KAI AUTA GIA BIOS KAI THA SOU PO?
TO THEMA EINAI OTI OLA KSEKINISAN OTAN ZESTANE O KAIRO.....
AN GINETE VOITHISE ME TI AKRIVOS NA KOITAKSO STO TROFODOTIKO?
(GRAFEI MAXIMOUM 300wATT OUTPUT)
πριν αγορασεις κουτια με 77 ανεμιστηρες, ψαξε πιο βασικα πραγματα.
αν εχεις 71 τωρα, στα 85 καιγεσαι :)
1. βγαλε την ψυκρτρα και δες τι γινεται απο κατω. μπορει:
α. αν δεν το συναρμολογησες μονος σου, να μην εχει καθολου παστα.
β. να εχει υπερβολικη ποσοτητα παστας, που κι αυτο κακο ειναι.
γ. να μην εχει κουμπωσει καλα η ψυκτρα και να εχει κενα στην επαφη
ισως να μην καταλαβες αυτα επειδη ηταν χειμωνας, οποτε με 50-65 βαθμους, αν και πολυ, δουλευε, ενω το καλοκαιρι σου πηγε 70+.
2. μηπως το fan της ψυκτρας ειναι κουλό? παει πολυ αργά?
3. σιγουρεψου οτι η cpu παιρνει τα default volt (νομιζω ο 2700 θελει 1.65).
κανε load bios default (ή safe settings ) για να αποκλειστει οτι κατι εχει πειραχτει προς τα πανω.
αν δεν φταιει φαν/ψυκτρα, μπορει το bios να λεει οτι δινει 1.65 και στην πραγματικοτητα να δινει λιγο παραπανω/λιγοτερο,
check this also
4. για να δεις αν κατι ειναι ελλατωματικο και δεν φταει θερμοκρασια, βαλε μια χαμηλοτερη fsb απο την 166, πχ. 100-133, και δοκιμασε memtest, toast, prime95, κλπ...
basika den ksero na vgalo psiktra kai tetoia kai oute exo oreksi na dokimaso.Loipon den ton exo sinarmologisi ego,to fun paei giro stis 4600 strofes,to cpu voltage einai 1.65(apo bios).auta tora pos na elekso tin pragmatiki tasi sto cpu?iparxei kana diagnostiko gia ti cpu?
99% εχεις προβλημα με θερμοκρασια. εχω σε full tower με 4 HD,dvd,cdrw. xp 2700 kai gigabyte 7n400pro2 εχω 57 - 61 cpu & 39 - 43 system.
ολα αυτα βεβαια με 7 fans ( 3 front - 4 back) cooler tis AMD normal & system coler/fan ena xtreme apo HACshop ton 20euro.
πριν βαλω τα fan & κυριως το cooleraki sto system (εφτανε πριν 48-50c), το PC κολαγε σαν τρελο, 70C cpu. τωρα παιζει τελεια :)
apla pragmata. cpu thermaltake silent boost artic silver pasta kai case me 12cm fans mpros - piso px herolchi, antec lanboy klp kai vevea psu i tagan i kana levicom pou einai kai psiloftina kai kala i kana akasa pou exei kai 12cm fan. KAI KATHARISES
Το default cooler της AMD σε καίει (κυριολεκτικά), αν αναβαθμίσεις αυτό με καμιά Volcan 12 θα είσαι αρκετά καλά σχετικά ανέξοδα, τώρα, αν θες καλύτερη λύση θα πρέπει και το κουτί να αλλαχθεί. Πάντως και νέο κουτί με αυτή τη ψύκτρα δεν θα κάνει πολλά...
paidia thelo na sigoureuto prin allakso kouti kai psiktra.Paratirisa loipon apo to bios oti to cpu vcore paizei 1.61 kai 1.63 eno otan valo safe settings einai standart
1.63.Auto ti simenei lete na fteei to trofodotiko?
