toxotis70 Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 Επίσης, απ ότι είδα, δεν μπορείς να παίξεις κάποια παιχνίδια στο steam os όπως c all of duty, Fortnite κλπ …σωστά;
xtrmsnpr Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 (επεξεργασμένο) Έρχεται νέο steam deck 16/11/23 5 ώρες πριν, Material_Defender_1032 είπε https://store.steampowered.com/sale/steamdeck_2023 Λίστα αλλαγών: Εμφάνιση κρυμμένου περιεχομένου General: Updated APU to 6 nm for better efficiency Updated memory to 6400 MT/s, improving latency and power management Increased thermal module thickness and performance Updated Display: Increased active area to 7.4" (from 7.0") Updated refresh rate to 90Hz (from 60Hz) Updated peak brightness to 1000 nits Updated touchscreen polling rate to 180Hz, improved latency and accuracy Updated WiFi / Bluetooth module Added support for WiFi 6E Added support for Bluetooth 5.3, supporting newer codecs such as aptX HD and aptX low-latency Added third antenna near the top of the device for better Bluetooth performance, including when docked Added support for wake from Bluetooth controllers Audio: Improved bass response for an overall flatter sound profile Added support for using onboard microphone array simultaneously with the 3.5mm headphones connector Controls: Adjusted analog stick top material and shape for increased grip and dust build-up resistance Adjusted analog stick post material to improve interaction feel with front cover and reduce wear Improved reliability of analog stick touch detection Improved responsiveness and tactility of shoulder buttons switch mechanism Adjusted D-pad snap ratio and diagonal interactions Redesigned trackpad for improved fidelity and edge detection Greatly improved trackpad haptics feel and precision Power: Improved battery capacity from 40Wh to 50Wh Improved battery chemistry for faster charging, from 20% to 80% in as little as 45 minutes Changed charging LED to WRGB Added support for waking up from initial unboxing by long-pressing power button instead of requiring AC power Adjusted power supply cable length from 1.5m to 2.5m Added logo to power supply Frame: Reduced total system weight to ~640g, or ~5% less than Steam Deck Rear cover screws now thread into metal Adjusted rear cover screw heads to Torx™, as well as other materials and geometry tweaks on the heads to reduce stripping risk Lowered number of screw types throughout system Reduced step count required for common repairs Improved bumper switch mechanism drop reliability Moved bumper switch to joystick board for easier repair Improved display repair/replacement to not require taking rear cover off Software: Greatly improved memory power management firmware Added preliminary support for open-source BIOS and EC firmware Improved resume time by roughly 30% Α το είπατε ήδη. Πάσο τότε! Ώρα να γεμίσει το σαητ με σκοτωμένες αγγελίες 😁. Επεξ/σία 10 Νοεμβρίου 2023 από xtrmsnpr
SabotazNic Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 3 ώρες πριν, xtrmsnpr είπε Ώρα να γεμίσει το σαητ με σκοτωμένες αγγελίες 😁. Ε καλα, ενας που εχει ηδη δεν ειναι deal breaker η oled. Ωστοσο, για εμας που περιμεναμε, good to have. 3
xtrmsnpr Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 20 λεπτά πριν, SabotazNic είπε Ε καλα, ενας που εχει ηδη δεν ειναι deal breaker η oled. Ωστοσο, για εμας που περιμεναμε, good to have. Μη! Σταμάτα! Άσε τους να νομίζουν ότι είναι must have, να τα διαλύσουν όλα στις αγγελίες! (Τα ίδια δεν έκανε και η νιτεντο με το OLED switch? Νομίζω το αποθέωσαν αυτό το must have κομμάτι hardware 😁)
Xvipes Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 Από ότι κατάλαβα η OLED version δεν θα έρθει ακόμα Ελλάδα. Με βάσει την LCD version θυμάστε πόσο καιρό έκανε για να ανοίξουν οι αποστολές για εδώ ή αν ξέρουμε legit τρόπο να το παραγγείλουμε από τώρα;
Nik1239 Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 Έχει δοκιμάσει κανείς τα refurbished τους; Με ψήνει πολύ το 512gb στα 380€ ή να κοιτάξω για μεταχειρισμένα;
toxotis70 Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 μεταχ/να δε πολυσυμφερει ακομα.... σχεδον ιδια τιμη το δινουν.
vaggos88 Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 4 ώρες πριν, Xvipes είπε Από ότι κατάλαβα η OLED version δεν θα έρθει ακόμα Ελλάδα. Με βάσει την LCD version θυμάστε πόσο καιρό έκανε για να ανοίξουν οι αποστολές για εδώ ή αν ξέρουμε legit τρόπο να το παραγγείλουμε από τώρα; Θα έρθει η OLED. Συγκεκριμενα και οι 2 version θα ειναι διαθεσιμες (512gb 1tb) οπου ηταν και το παλιο μοντέλο. Η limited edition μονο US-CANADA Legit αγορα κανεις μονο μεσα απο το site της Valve (steam) και θα ειναι διαθεσιμο απο 16 νοεμβριου. Απο κει και περα κανει περιπου 10-15 μερες να ερθει και αποστελεται απο Ολλανδια σε εμας χωρίς τελωνεια κλπ. Τελικη τιμη οτι πληρωσεις στο Steam. https://store.steampowered.com/sale/steamdeck_2023LE 2
DTse Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 4 hours ago, Nik1239 said: Έχει δοκιμάσει κανείς τα refurbished τους; Με ψήνει πολύ το 512gb στα 380€ ή να κοιτάξω για μεταχειρισμένα; Το εχω κανα 2 μηνες. Μπορω να πω οτι ηταν σαν καινουργιο, δεν ειδα να εχει κατι επιφανειακα οπως σε καποια βιντεο στο youtube. Και μεσα που το ανοιξα πεντακαθαρο. Το μονο αρνητικο ειναι οτι ερχεται μεσω ACS 🤣 1
gust Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 Για όσους έχουν την πρώτη γενιά δε λέει το upgrade για 2-3 fps και oled οθόνη. Για όσους είχαν στο πρόγραμμα να αγοράσουν πρώτη φορά εννοείται πας σε oled. Για όσους είχαν αποφασίσει να περιμένουν, να καθίσουν στα αυγά τους γιατί σε κανα 1-1,5 χρόνο βλέπω steam deck 2 που θα κάνει παπαδες! Αυτά! Καλή απόλαυση σε όλους τους νεόυς κατόχους! 2
Xvipes Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 14 minutes ago, vaggos88 said: Θα έρθει η OLED. Συγκεκριμενα και οι 2 version θα ειναι διαθεσιμες (512gb 1tb) οπου ηταν και το παλιο μοντέλο. Η limited edition μονο US-CANADA Legit αγορα κανεις μονο μεσα απο το site της Valve (steam) και θα ειναι διαθεσιμο απο 16 νοεμβριου. Απο κει και περα κανει περιπου 10-15 μερες να ερθει και αποστελεται απο Ολλανδια σε εμας χωρίς τελωνεια κλπ. Τελικη τιμη οτι πληρωσεις στο Steam. https://store.steampowered.com/sale/steamdeck_2023LE Thank you! Αξίζει πιστεύετε το anti-glare etched glass? Για αποθηκευτικό χώρο δε με πειράζει να ξεκινήσω με 512gb οπότε αν κτλβαίνω καλά ο μόνος μετά λόγος για να πάρεις το 1tb είναι το anti-glare. Βράδια θα παίζω συνήθως στο κρεβάτι.
vaggos88 Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 48 λεπτά πριν, Xvipes είπε Thank you! Αξίζει πιστεύετε το anti-glare etched glass? Για αποθηκευτικό χώρο δε με πειράζει να ξεκινήσω με 512gb οπότε αν κτλβαίνω καλά ο μόνος μετά λόγος για να πάρεις το 1tb είναι το anti-glare. Βράδια θα παίζω συνήθως στο κρεβάτι. Θα παρεις τοτε το 512 και αν χρειαστεις ακομα χωρο θα παρεις μια sd card με 30-40ε και εισαι κομπλε.
Xvipes Δημοσ. 10 Νοεμβρίου 2023 Δημοσ. 10 Νοεμβρίου 2023 36 minutes ago, vaggos88 said: Θα παρεις τοτε το 512 και αν χρειαστεις ακομα χωρο θα παρεις μια sd card με 30-40ε και εισαι κομπλε. Άρα το anti-glare δεν έχει ουσιαστική διαφορά;
