ΚΑΛΗΣΠΕΡΑ
ΥΠΑΡΧΕΙ ΚΑΝΕΙΣ ΚΑΤΑ ΠΡΟΤΙΜΗΣΗ ΑΠΟ ΘΕΣΣΑΛΟΝΙΚΗ ΓΙΑ ΒΟΗΘΕΙΑ ΣΧΕΤΙΚΗ ΜΕ ΤΟ STEAM DECK?
ΒΟΗΘΕΙΑ ΣΧΕΤΙΚΑ ΜΕ:
- EMULATION STATION
- EPIC GAMES , GOG , BATTLENET ΚΤΛ
  • 4 εβδομάδες αργότερα...
  • Απαντ. 2,4k
Πρώτη προσπαθεια vinyl wrap. Δεν ηταν και πολυ δύσκολο. Το αποτελεσμα ειναι θετικό για την ωρα αλλα κατι μου λέει στις λαβες θα ξεκολλήσει γρηγορα στις ακρες (Λογο ποιοτητας) Το πηρα απο aliexpress στα 8-9ε.
+100 mandalorian armor protection
60 locked fps with the force.
  • Like 14
https://store.steampowered.com/sale/steamdeck_2023
Λίστα αλλαγών:
Spoiler
General:
  • Updated APU to 6 nm for better efficiency
  • Updated memory to 6400 MT/s, improving latency and power management
  • Increased thermal module thickness and performance
Updated Display:
  • Increased active area to 7.4" (from 7.0")
  • Updated refresh rate to 90Hz (from 60Hz)
  • Updated peak brightness to 1000 nits
  • Updated touchscreen polling rate to 180Hz, improved latency and accuracy
  • Updated WiFi / Bluetooth module
  • Added support for WiFi 6E
  • Added support for Bluetooth 5.3, supporting newer codecs such as aptX HD and aptX low-latency
  • Added third antenna near the top of the device for better Bluetooth performance, including when docked
  • Added support for wake from Bluetooth controllers
Audio:
  • Improved bass response for an overall flatter sound profile
  • Added support for using onboard microphone array simultaneously with the 3.5mm headphones connector
Controls:
  • Adjusted analog stick top material and shape for increased grip and dust build-up resistance
  • Adjusted analog stick post material to improve interaction feel with front cover and reduce wear
  • Improved reliability of analog stick touch detection
  • Improved responsiveness and tactility of shoulder buttons switch mechanism
  • Adjusted D-pad snap ratio and diagonal interactions
  • Redesigned trackpad for improved fidelity and edge detection
  • Greatly improved trackpad haptics feel and precision
Power:
  • Improved battery capacity from 40Wh to 50Wh
  • Improved battery chemistry for faster charging, from 20% to 80% in as little as 45 minutes
  • Changed charging LED to WRGB
  • Added support for waking up from initial unboxing by long-pressing power button instead of requiring AC power
  • Adjusted power supply cable length from 1.5m to 2.5m
  • Added logo to power supply
Frame:
  • Reduced total system weight to ~640g, or ~5% less than Steam Deck
  • Rear cover screws now thread into metal
  • Adjusted rear cover screw heads to Torx™, as well as other materials and geometry tweaks on the heads to reduce stripping risk
  • Lowered number of screw types throughout system
  • Reduced step count required for common repairs
  • Improved bumper switch mechanism drop reliability
  • Moved bumper switch to joystick board for easier repair
  • Improved display repair/replacement to not require taking rear cover off
Software:
  • Greatly improved memory power management firmware
  • Added preliminary support for open-source BIOS and EC firmware
  • Improved resume time by roughly 30%
:ph34r:
  • Like 6
Πολυ δυνατο το νεο steam deck και στα 569 αρκετα τιμια τιμη για αυτα που προσφερει. Δεν λενε κατι για καλυτερη gpu η cpu μονο για ram λενε και οτι πηγε σε μικροτερη λιθογραφια. Κριμα που αφησαν το 256 με LCD.
9 λεπτά πριν, toxotis70 είπε
Επεξεργαστής , κάρτα γραφικών είναι ίδια με το προηγούμενο μοντέλο;
Σωστές βελτιωσεις, ακουσαν και εκαναν τις βασικες για την ωρα αναβαθμισεις. Παρολα αυτα δεν θα ελεγα πως το ζηλεύω ώστε να το αντικαταστισω με αυτο που εχω τωρα. Οταν βγει steamdeck 2 τοτε ναι.
Επεξ/σία από vaggos88
Aς ειχε zen 4 μαζι με rdna 3 και το ειχα αγορασει χτες , ακομα και 700+ να εκανε . Προς το παρον καθομαι με το rog ally μεχρι να βγει καλυτερο σε performance steam deck .
Η OLED είναι τεράστιο upgrade σε σχέση με την LCD και το σάπιο bleeding που παρουσιάζει. Προσωπικά, το βλέπω να σκοτώνω το τωρινό μοντέλο που έχω και να πηγαίνω για την μεσαία έκδοση των 512GB.
3 minutes ago, toxotis70 said:
Μπορεί να μπουν steam os και windows στον ίδιο εσωτερικό δίσκο?
Ναι, φυσικά.
Πλέον δεν υπάρχει λόγος βέβαια, με εξαίρεση το Xbox Game Pass. Όλα τα υπόλοιπα γίνονται άψογα σε SteamOS.
