Red Dead Redemption 2 [PC]
  • Απαντ. 2,6k
Στην δική μου περίπτωση με 2600x & 1070ti μάλλον χειρότερα είμαι σε fps με τα ίδια settings πριν το patch.
Το προχώρησα λίγο σήμερα το single player  και πράγματι το benchmark δεν αντικατοπτρίζει 100% τον μέσο όρο fps που θα έχεις εντός παιχνιδιού.
https://www.dsogaming.com/news/red-dead-redemption-2-pc-november-13th-update-is-2-91gb-available-for-download-full-patch-notes/
Changelog
Spoiler
Red Dead Redemption 2 November 13th PC Update Release Notes
Graphics & Performance Fixes
Added an additional launch argument (-cpuLoadRebalancing) to rebalance workload on the CPU cores and avoid hitting an edge-case in certain NVIDIA graphics card drivers that causes significant stalls on 4-core and 6-core CPUs
Added improvements for performance and stability on graphics cards with 4GB of VRAM or less when using Vulkan
Fixed an issue that resulted in audio stuttering and sound drops on some CPUs when using Vulkan
Fixed an issue that resulted in graphics problems when using Fullscreen mode on systems with multiple displays
Fixed an issue that resulted in the game becoming stuck in Windowed Borderless mode instead of Fullscreen mode if the game lost focus or certain graphics settings were changed under DirectX 12
Fixed issues that resulted in the incorrect detection of devices and problems switching between SDR and HDR modes. Players who previously encountered these issues should enable HDR through the Windows Display Settings prior to launching the game
Fixed an issue that resulted in the game launching in a window larger than the maximum resolution of the attached display when using Windowed display mode
Improved the auto-detection of system hardware so that the recommended default graphics settings will provide higher performance
Fixed an issue that resulted in the game setting a default graphics preset that was unsupported by the amount of available VRAM on some graphics cards, preventing the game from launching
Fixed an issue that resulted in VRAM usage estimation for pending settings changes to be slightly different to the actual usage once the settings were applied
Added a separate option to enable tessellation on tree models within the Graphics settings menu
Fixed an issue that resulted in reduced performance when switching between different graphics settings presets without restarting the system
Fixed an issue that affected the brightness of Photo Mode images that were captured in HDR after editing them using the Social Club menu
Fixed issues with some full-screen effects and Photo Mode filters when using a display aspect ratio other than 16:9
Fixed an issue that resulted in graphics artifacts in mirror reflections when using Multisample Anti-Aliasing (MSAA)
Fixed an issue that resulted in graphics artifacts on the Pause Menu Map when using Multisample Anti-Aliasing (MSAA )
Fixed issues with rendering and lighting that occurred with some waterfalls
Fixed issues with rendering that occurred with a Story Mode character
Fixed an issue that resulted in flickering graphics artifacts on some systems using multiple graphics cards
Fixed an issue that resulted in graphical corruption during the theater shows in Saint Denis
Fixed an issue that resulted in graphics artifacts to appear when rendering some light reflections
Fixed an issue that affected the rendering of the Pause Menu background after changing the display resolution
Fixed an issue that resulted in reduced world detail at long distance when using items that allow zooming, such as scopes and binoculars
Fixed an issue that resulted in rendering issues with shadows on some parts of the terrain
Fixed an issue that resulted in graphics artifacts that could occur with some hair/fur rendering when using Multisample Anti-Aliasing (MSAA)
Improved the performance rendering some in-game particle effects
Improved the performance rendering of trails when in snowy areas of the game
Fixed an issue that resulted in the partial rendering of the Pause Menu while some graphics settings were active
Stability Fixes
Fixed issues that resulted in crashes during game startup and logo screen
Fixed issues that resulted in crashes when changing graphics settings or switching back and forth between presets
Fixed an issue that resulted in crashes during the initial boot of the game in the Windowed display mode
Fixed an issue that resulted in a crash when switching between Windowed and Fullscreen display modes on some graphics cards
Fixed an issue that resulted in a crash when the game window lost focus or as a result of using Alt+Tab
Fixed an issue that resulted in a crash when attempting to load an autosave on some systems
Fixed an issue that resulted in a crash when repeatedly transitioning between Story Mode and Red Dead Online
Fixed issues that resulted in crashes when attempting to quit the game
Fixed an issue that resulted in a crash on some systems when connecting and disconnecting input devices with the game running
Fixed an issue that resulted in a crash when attempting to switch weapons in Story Mode
Fixed an issue that resulted in a crash when opening the HDR Calibration screen with some combinations of graphics cards and displays
Fixed an issue that resulted in a crash when using the mouse to switch between categories in the Satchel menu
Fixed an issue that resulted in the game freezing when applying remapped keyboard inputs through the Settings menu
Fixed an issue that resulted in an infinite loading screen when exiting the Settings menu and returning to the Landing Page
Fixed an issue that resulted in a crash when playing Story Mode while offline
Fixed crashes and stability issues that resulted in the error “Red Dead Redemption 2 exited unexpectedly” during gameplay
Fixed an issue with attempting to join another player’s Red Dead Online session with a different control scheme or lock-on type that resulted in networking issues
Fixed an issue that prevented the Red Dead Redemption 2 desktop shortcut from correctly launching the game
Control & User Interface Fixes
Improved mouse support in some Store menus
Fixed an issue that resulted in a black screen during the initial boot of the game rather than the loading bar
Fixed an issue that resulted in players being unable to equip emotes in Red Dead Online while using the mouse
Fixed an issue that resulted in the Map in the Pause Menu being cut off when changing the game resolution
Fixed an issue that resulted in player overhead displays to appear in the incorrect position on displays other than 16:9 aspect ratio in Red Dead Online
Fixed an issue that prevented some keyboard inputs from being remapped
Fixed an issue that resulted in some incorrect text and warning screens to appear when when remapping keyboard inputs
Fixed issues that resulted in problems with scrolling in parts of the user interface
Fixed an issue that resulted in some menus not displaying input controls, including Safe Zone and Brightness Calibration screens
Fixed issues with keyboard text input when using some languages
Fixed issues that resulted in the red selection highlight disappearing while browsing through menus
Fixed issues that resulted in problems with mouse selection, or erratic cursor movement when browsing some menus
Fixed an issue with keyboard navigation of the Pause Map after selecting a blip/icon.
Fixed an issue that resulted in players being unable to complete some actions while inspecting weapons
Fixed an issue that resulted in save game information to be missing from the Load Game menu
Fixed issues with text input of non-Latin characters and added support for more input methods
Fixed an issue that resulted in the Pause Map moving position after placing a waypoint
Fixed an issue that resulted in difficulty aiming with a mouse, especially at low DPI settings
Fixed issues that resulted in incorrectly sized, overlapping or misaligned user interface elements under different display resolutions
Fixed an issue that resulted in the loss of previous selections when navigating back and forth between menus
Fixed an issue that resulted in redundant options in the Keyboard and Mouse submenu of the Controls menu
General / Miscellaneous
Improved the stability and result consistency of the in-game Benchmark Tool
Fixed an issue that resulted in players appearing underneath the world when in the lobby screen while playing some Red Dead Online content
Fixed an issue that resulted in incorrect performance of the ‘Tap and Hold Speed Control’ accessibility feature while using keyboard and mouse controls in First Person camera mode
Fixed an issue that resulted in camera stuttering when using the mouse to look around while sprinting
Fixed an issue that caused problems with the fishing minigame when running at high framerates
Το tree tesselation (το καινούργιο setting) ήταν όλο το πρόβλημα σε μένα για τα χαμένα fps με το καινούργιο patch..
Switch to off and that's it!
14 λεπτά πριν, Sprou είπε
σωστος. fps killer το συγκεκριμενο.
στα πρωτα 3  parts του bench, ημουν περιπου 10 fps μειον, και βλαστημουσα γιατι θα τρωγα κανα 2ωρο παλι να δω τι φταιει.
τωρα ισα βαρκα ισα νερα, ακριβως το ιδιο performance με pre-patch.
btw οσοι νομιζουν οτι εχουν μεγαλες αυξησεις ας μπουν στον κοπο να
κοιταξουν τα settings τους:P
εχουν γυρισει σε default
Επεξ/σία από rofl
Ειδικά οταν μπήκα σε δάσος κλάμα..και γω τα ίδια fps pre-patch με τα ίδια settings.
Απορώ με τις αλλαγές.
Και αυτό ότι θα βοηθηθεί η φουκαριαρα η κάρτα δεν το βλέπω 90%gpu 30%cpu..Εκτός εάν κατάλαβα  κάτι λάθος
Επεξ/σία από Sprou
Διαβάζω το changelog από το τελευταίο patch και πραγματικά αναρωτιέμαι αν έκαναν beta testing πριν το release ή απλώς τελείωσαν με τον κώδικα και το έβγαλαν στην αγορά...
βγηκε και fix για το stuttering
 https://support.rockstargames.com/articles/360038940333/Graphics-stuttering-or-stalling-in-Red-Dead-Redemption-2-on-PC
  1. Disable any custom workarounds for this issue, including Process Lasso or BES
  2. Start the Rockstar Games Launcher
  3. Select Settings
  4. Under My installed Games Select Red Dead Redemption 2
  5. Scroll down to Launch arguments
  6. Add the following command
    -cpuLoadRebalancing
6 λεπτά πριν, Sprou είπε
τι εννοεις? η gpu δε φτανει το 100%?
κανονικα θα πρεπε, το gpu usage ιδανικα θα πρεπει να ειναι παντα 100%,
εκτος κι αν εχεις βαλει fps cap.
Επεξ/σία από rofl
σε μενα τιποτα δε βοηθησε στα θεματα που εχω..Οπως πριν ακριβως...το dx 12 ειναι καμμενο σε μενα,,,,,Δε μπορεις να βαλεις καν fullscreen και κλειδωνει στα 48 hz μονο..Στο vulkan κλειδωμενη αναλυση και hz ,δε μπορεις να τα αλλαξεις καν ,παλι καλα που ειναι native..Στο brightness calibration οσο και να το παω δεξια δε βλεπω καν το logo...To stuttering δε λυθηκε ειδικα στις πολεις ουτε με το argument και δεν εχω καν i 5 που υποτιθεται εχουν θεματα,εχω i7 8ης γενιας 6/12...Τα fps τα ιδια τα ειδα ,μονη λυση οπως και πριν για να μπορω να παιξω χωρις μεγαλα θεματα να κανω lock ta fps
7 ώρες πριν, 4saken είπε
καινουργιο patch και κερδισα 5-10 fps χωρις να πειραξω κατι...Βλεπετε και εσεις διαφορα?
Μια απο τα ίδια και εγω, 10fps πάνω.
14 λεπτά πριν, jimtriol είπε
το hyperthreading to εχεις ανοιχτο στο bios?
Επεξ/σία από rofl
