Red Dead Redemption 2 [PC]
  • Απαντ. 2,6k
Έχει κανένας ιδέα τι ακριβώς προσθέτει/διορθώνει αυτό το τελευταίο update των 3+ gb? Δεν έχουν κυκλοφορήσει patch notes απ'όσο είδα.
Εκτός αν το κυκλοφόρησαν για να αφαιρέσουν τα assets που υλοποιεί το πρόσφατο "Hot Coffee" mod για το RDR2 :P
https://support.rockstargames.com/articles/360042861654/RDR2-Title-Update-1-17-Notes-PS4-Xbox-One-PC
Αναφορά σε κείμενο
[February 20, 2020] General / Miscellaneous (PC)
  • Improvements to reduce issues with ambient wildlife populations in certain Red Dead Online sessions
  • Improvements made to performance optimizations that should prevent some stuttering/hitching issues that occurred when using Vulkan on systems with NVIDIA graphics cards
  • Fixed an issue that caused the “Rockstar Games Launcher exited unexpectedly” error when launching the game on some systems with specific types of audio hardware
  • Fixed several crashes that occurred on systems with multiple monitor/adapter configurations when launching the game or entering fullscreen mode
  • Fixed several crashes that occurred during loading screens when launching the game or switching between Story Mode and Red Dead Online
  • Fixed several crashes that occurred when using Vulkan drivers on systems with NVIDIA graphics cards
  • Fixed several crashes that occurred when using Vulkan drivers on systems with Intel integrated graphics processors
  • Fixed issues with lighting quality and benchmarking tool accuracy on some systems using multiple graphics cards
  • Fixed several random crashes that occurred during gameplay in Story Mode and Red Dead Online
  • Fixed an issue that caused a crash and prevented the game from launching when switching between different Graphics API options on some hardware configurations
  • Fixed a crash that occurred when changing resolution via Windows’ display settings while the game was running
  • Added a warning that informs the player of outdated graphics cards drivers when launching the game
  • Added ‘-noDPIAdjust’ launch argument - Users encountering aspect ratio issues when using an AOC AG241QX monitor through DisplayPort should manually add this argument through Rockstar Games Launcher / Epic Games Store / Steam
Σκοτωσα ένα Legendary animal , Πηρα το δερμα του και πηγα να το παραδωσω στον trapper για crafting.
Στην διαδρομή όμως με σκοτωσαν και τωρα βλεπω δεν είναι στην κατοχή μου το δερμα. τι γινεται σε αυτην τη περιπτωση?
Προφανως μιλας φιλε μου για το story
Δεν χανονται τα legendary αν πας θα το εχεις κανονικα να το πουλησεις απλα δεν θα το εχεις πανω στο αλογο σου
Από επιδοσεις μια χαρα παει τωρα το προβλημα ειναι με τα bug
ΥΓ Σημερα παιδια σπαστηκα παρα πολυ , μπηκα για 2' για να ανω στω ενα daily και τσαντιστηκα
Σκοτωνα κροκοδειλους και με το που σηκωνα το δερμα εξαφανιζοταν
Αφου ειχα 6-7 μπροστα μου ξαφνικα εξαφανιστηκαν ολοι
Παω στον Cripps μπας και απλα δεν τους βλεπω και μου εχει εμφανισει μονο τα δοντια καθολου δερμα
Το καμπ το βρηκα κλασσικα με το 3ο login για να φαω τη σουπιτσα
ΥΓ2
Αι στα διαλα Rock Star
Kαλα και στο gta v ειχα φαει ενα μηνα μπαν γιατι μπηκε στο server καποιος που πετουσε σακια με λεφτα και πηρε και μενα η μπαλα. Ε δεν ξανα ασχοληθηκα απο κει και περα με το online ξανα.
Σχετικα με τα Treasure maps
Αγορασα ένα χαρτη με θησαυρο από έναν πλανοδιο εκει περα και δειχνει ένα μερος με ένα χ που λογικα εκει είναι ο θησαυρος.
και που ξερω εγω που βρίσκεται αυτό το σημειο στον χαρτη? είναι εκει κοντα στο σημειο που αγορασα τον χαρτη?
Καλημέρα φίλε μου πατάς το B και μπαινεις στο μενου σου και βρισκεις τους χαρτες σου πιθανον να εχεις και αλλους εκει
Διαλεγεις αυτον που θελεις , αν εχεις μονο αυτον που πηρες το τε αυτον πατας και σου βγαζει ενα Χ οπως ειπες
το θεμα ειναι οτι το Χ στο βγαζει σε μια περιοχη κιτρινη και καπου μεσα σε αυτη ειναι ο θησαυρος
Συνηθως ειναι σε πετρες δεντρα γενικα εχει κατι να τον σκεπαζει οποτε θελει ψαξιμο θα εισαι συνεχεια με το dead eye και θα δεις τις κλασσικες κιτρινιλες απο πανω και θα ειναι ο θησαυρος
Επαναλαμβανω το Χ δεν σου δειχνει που ακριβως ειναι ο θησαυρος απλα σου σημαδευει τη περιοχη που θα ψαξεις σε ολο το κιτρινο μπορει να ειναι
Τελος πρεπει να ξερεις τον ιδιο χαρτη μπορεις να τον παρεις πολλες φορες και απλα θα ειναι σε διαφορετικο σημειο ο θησαυρος
ΑΝ μπεις you tube και γραψεις το ονομα του χαρτη θα δεις οτι θα σου εχει 4-5 τοποθεσιες αυτο σημαινει πως τον ιδιο χαρτη μπορεις να τον παρεις 4-5 φορες και ουσιαστικα ειναι 4-5 διαφορετικοι θησαυροι στην ιδια περιοχη απλα εσυ μπορεις να βρεις μονο 1 καθε φορα μην ψαξεις για 2ο δεν θα βρεις ποτε
