Elden Ring [PC]
Θα κανεις roll να αποφυγεις το Boss,θα σου φριζαρει και θα την τρως.
Αντε ξανα απο την αρχη.
Δεν ειναι απλο frame rate drop,κανει freeze και τα κανει τακτικα...
Επεξ/σία από optimus prime
  • Απαντ. 2k
22 λεπτά πριν, GhostRiderLSOV είπε
Θα δούμε όταν παίξουμε.
Καλη τυχη..
Elden Ring performance: what to expect on PS5, Series X/S and PC • Eurogamer.net
Spoiler
The PC situation is also worth clarifying. As it currently stands the PC version using the latest 1.02 patch has a number of issues that will affect all hardware configurations on all graphical settings presets. Elden Ring is From Software's first foray into low-level APIs on PC and the game uses DirectX 12. As we have seen in other DX12 titles, there can be severe and distracting frame-time stuttering issues.
First there are stutters of up to 250 milliseconds in length when new effects, enemies, and areas appear on screen. These types of stutter lessen as the play experience goes on and enemies, areas, and effects are revisited by the player. A second and more pervasive stutter appears to be tied to loading new game areas - when traversing the terrain, moving from one area to the next can cause minor one-off frame drops a few times a minute, or at worst, tumbling frame-time issues that drop the frame-rate from a steady 60 into the 40s.
Variable refresh rate monitors using G-Sync or Freesync help alleviate a level of the distracting nature of some of these issues, but leaning on the technology is not a good situation in light of how the console versions do not suffer from these stutters. Other issues to note are the lack of ultrawide screen support, no support for frame-rates above 60fps, and unintuitive graphical options that lack visible scaling. As we have seen with other titles suffering from similar issues such as Final Fantasy 7 Remake and Halo Infinite, it could be sensible to wait for further patches before investing time into the PC version of Elden Ring.
3 λεπτά πριν, optimus prime είπε
Καλη τυχη..
  Απόκρυψη περιεχομένων
Το ίδιο θέμα είχε και το Sifu
6 λεπτά πριν, optimus prime είπε
Καλη τυχη..
Έχει μπει ήδη, αλλά επειδή έχω ξαναδεί "αυτό το game είναι χάλια γιατί (κομμάτι που δεν άρεσε)" και μετά τούμπες, δεν θέλω κι εδώ.
Εγώ δεν καταλαβαίνω γιατί τόσο θάψιμο με το παιχνίδι πριν ακόμα κάνει release! Στο ρεντιτ διαβαζω απλά έχει κάποια φριζ εδώ και εκεί και δεν είναι κάτι το τρομερό! Είναι τόσο χάλια όσο τα παρουσιάζει ο φίλος πιο πάνω; 🤔
Μόλις τώρα, optimus prime είπε
Δεν το εχω παιξει και δεν νμζ να το παιξω στο αμμεσο μελλον εαν εχει τετοια θεματα.
Ένα stutter στο φόρτωμα των περιοχών, πολύ πολύ σύντομο αλλά αισθητό. Επειδή όμως είναι μικρό παιχνίδι σε αριθμό επιπέδων δε φαινόταν πολύ.
2 λεπτά πριν, Georgram είπε
Για να λένε οι reviewers ότι έχει θέματα performance, ναι, θα έχει.
Πόσο μεγάλα και τι αντίχτυπο στο PC του καθενός, θα δούμε όταν παίξουμε.
17 λεπτά πριν, Armoral είπε
Αυτος σου λεει οτι το stutter ειναι 250 mil,δλδ βαρβατο και τρωει βουτιες στα 40 για κανα δευτερολεπτο οπου εκει νιωθεις οτι σου φριζαρει.
Ακομα και στο βιντεο του ACG φαινεται καθαρα οτι γινεται πολυ συχνα αυτο.
Ακομα και gsync τσιπακι να εχεις θα την ακουσεις καλα οταν θα πεσει στα 40.
Εδω δειτε καταντια..
Elden Ring PC Issues (Hard Locks) - Twitch
1 ώρα πριν, naruto14 είπε
Το θεωρώ απαράδεκτο να παίρνει τόσα 10άρια με τόσο χοντρά θέματα. 10άρι σημαίνει ότι το παιχνίδι είναι αψεγάδιαστο. Και η δικαιολογία "α είπαν θα το φτιάξουν" δεν στέκει. Δεν είναι μόνο στο PC προβληματική η κατάσταση αλλά ακόμα και στις κονσόλες. Κρατάω το pre-order μου, αλλά περιμένω να δω τι θα γίνει τις επόμενες μέρες. Αυτά που βλέπω ΔΕΝ μου δίνουν την εντύπωση ότι πρόκειται για μια ευχάριστη εμπειρία, ακόμα και με VRR όπως ισχυρίζεται το DF.
Το Breathe of the Wild ,ειδικα στην Wii U εκδοση ειχε performance drop,stutter και μαλιστα και freezes του ενος δευτερολεπτου στο combat,κακο Day 1 launch. Το αποτελεσμα ηταν να παρει 96 Metacritic :D
Δεν με νοιαζει εμενα η μεγαλη βαθμολογια φιλος,ας παρει και 110.
Εμενα με νοιαζει να πηγαινω στα boss fight και εαν ειναι πεφτω,να πεφτω επειδη πρεπει να μαθω καλυτερα το στυλ του καθε boss και οχι επειδη μου κανει κομπλες το αθλιο opτimization που εχουν κανει.
Δεν θα μου σπασουν εμενα τα νευρα αυτοι..
Για starting class για αρχάριο τι προτείνετε ? , έχω παίξει και εχω τελειώσει το sekiro τρώγοντας φυσικά πολύ ξύλο αλλα δεν εχω παίξει κανενα souls game :P , έλεγα να αρχίσω με  Vagabond
2 λεπτά πριν, SPANK είπε
Δες το βιντεάκι που ποστάρανε πιο πριν, τα εξηγεί ωραία και συνοπτικά,
  • Like 5
