FRITZ!Box 7590 Review
Αγαπητέ poyline θα κάνεις κανένα review σε κάτι που να κοστίζει λιγότερο από 200 ευρώ;
έχω κανει στο 7530 που κανει 150 και ειναι και super vectoring και με 2 fxs.κοινως τα αξιζει τα χρηματα του. Dual band wifi ac.
https://www.insomnia.gr/review/hardware/routers/fritzbox-7530-review-r1012/
Βγηκε η 7.10
Product:	FRITZ!Box 7590
Version:        FRITZ!OS 7.10
Language:       Dutch, English, French, German, Italian, Polish, Spanish
Release date: 05/16/2019
**New Features:**
- Over 50 new features and improvements: more performance and convenience in the wireless network, Mesh and Smart Home
- Seamlessly connected in the Mesh: Mesh WiFi steering, shared telephone book and Smart Home
- Well informed: Important information arrives simply and directly at the email address of your MyFRITZ! account
- New in the internet: more information on DSL, faster LTE and expanded VPN functions
- Added value for FRITZ!Fon: easy sharing of access to the wireless guest access, direct blocking of telephone numbers, and much more
- Practical to operate: quick overview of updates for FRITZ! products, LEDs can be switched off
- Stronger support for new products: FRITZ!Repeater 3000 and FRITZ!DECT 400 Smart Home switch
Note: Instructions for configuring and using Mesh functions are presented at en.avm.de/mesh-faq
Below you find a complete list and descriptions of the new functions in the latest FRITZ!OS, along with a list of further improvements in this version.
# New Features in FRITZ!OS 7.10
## DSL:
- **NEW** A DSL data rate considerably higher than the speed of the internet connection given by the provider can now be reduced to a lower value in order to improve stability
## Mesh:
- **NEW** Mesh WiFi steering can automatically direct devices (smartphones or computers, for instance) to the best Mesh WiFi Repeater (access point steering)
- **NEW** The FRITZ!DECT 400 Smart Home switch can be used on every FRITZ!Box in the Mesh
- **NEW** All FRITZ!Boxes in the Mesh now have a shared telephone book at their disposal
## Telephony:
-**NEW** Support for SIP trunking from Deutsche Telekom, dus.net, easybell, envia Tel and EWE/swb/osnatel
## DECT:
- **NEW** Support for DECT door intercom systems (manufactured by Telegärtner)
## DECT/FRITZ!Fon:
- **NEW** Very easy to offer wireless guest access: Display the account data or initiate WPS on the handset
- **NEW** Block incoming telephone calls directly from the handset call lists
- **NEW** Fast accessibility to Smart Home devices as favorites
- **NEW** Configure and delete call diversion settings directly from the handset menu
## Home network
- ** NEW** Graphic display of home network connections when editing the connection of a network device
## Smart Home:
- **NEW** For the FRITZ!DECT 400 Smart Home switch, pressing a button longer can trigger a second switching action
- **NEW** Now a "Template" option is available as an additional switching option for FRITZ!DECT 400
## System:
- **NEW** FRITZ!Box sends information on certain events to the email address of your MyFRITZ! account
- **NEW** All LEDs on the device can now be switched off in the user interface
- **NEW** Display of the available updates for the FRITZ! products connected in the home network on the Overview page
## Mobile network:
- **NEW** Higher data rates possible through support for the Mobile Broadband Interface Model (MBIM) (for instance, W1208 from 4G Systems)
- **NEW** Push Service for sending received text messages
With each FRITZ!OS update, AVM also updates its security functions. Therefore we recommend performing the update for all devices.
# Additional improvements in FRITZ!OS 07.10
## DSL:
- **Improved** Approximate line length displayed in the DSL Overview
- **Change** For VDSL vectoring connections, manufacturer of the DSL central exchange (DSLAM) named in the user interface
## Internet:
- **Improved** Now domain names can be specified for VPN connections that are resolved via the tunnel
- **Improved** For VPN connections, the remote network is displayed in the network even after the connection has been cleared
- **Improved** Now any names can be specified for VPN connections
- **Improved** A VPN connection can now transfer the entire network traffic (VPN full tunneling, default route via VPN tunnel)
- **Improved** Better VPN connection negotiation
- **Improved** VPN LAN-LAN linkup of a FRITZ!Box on a DSL Lite connection possible to IPv4 remote sites
- **Improved** Various changes for importing a VPN settings file
- **Improved** More devices possible in the guest access (and wireless hot spot): assigned IP addresses now reserved for only 6 hours (DHCP lease time, configurable)
- **Improved** FRITZ!Box no longer repeats an attempt to register with MyFRITZ! if the confirmation link sent by email was not clicked
- **Change** For Vodafone, also consideration of first configuration on fiber optic connections
- **Change** For activation of internet access to the FRITZ!Box via HTTPS, TCP number selected randomly
- **Change** Transfer rate of the internet connection on the WAN port entered in Mbit/s instead of Kbit/s
- **Change** For connections from Telekom, "Zuhause Start" connections now called "MagentaZuhause Regio Tarif"
- **Fixed** "Standard" and "Guest" access profiles, configurable under Filters, contained a budget setting that was not supported
- **Fixed** Settings from the window for VPN settings could not be copied
- **Fixed** Under port sharing it was not possible to enter the IPv6 interface ID 0:0:0:0:*
- **Fixed** Switch of type of connection from IP client to internet router generated illegal IP settings
- **Fixed** Releasing a port on a dual-stack connection (IPv4 and IPv6) for sharing with a device configured only for IPv4 sometimes failed
- **Fixed** Internet connection failed after switching internet provider via mobile network to existing connection via wireless LAN
. **Fixed** In rare cases a device in the wireless guest access via a repeater was not assigned an IP address
- **Fixed** Misleading message úpon disabling internet access to the FRITZ!Box via HTTPS
- **Fixed** Port sharing for destination IP addresses in the form 192.168.*.127 was not possible
- **Fixed** Port sharing for IPv6 could not be enabled for internet connections with a prefix length /64
- **Fixed** VPN LAN-LAN linkup to fixed IP addresses did not work (IKE error 0x2005)
- **Fixed** Additional characters transmitted during download of the FRITZ!Box certificate under FRITZ!Box services
- **Fixed** Registration with MyFRITZ! could be instable when upper-case letters were used in the email address of the MyFRITZ! account
- **Fixed** With IPv6 and FRITZ!Box users without the right to access from the internet, access from the home network via FTP to storage (NAS) shared in the home network could fail
- **Fixed** Guest network block was not applied in individual access profiles configured in parental controls
## Wireless:
- **Improved** The wireless radio network table of known wireless devices was reworked
- **Improved** For devices that support the wireless protocols 802.11v/k (smartphones or computers, for instance), improved automatic steering into the 2.4-GHz or 5-GHz band (band steering)
- **Change** For wireless devices in the radio network, the property 802.11k displayed only when the scope of performance is sufficient (beacon report)
- **Change** New report in event log on problems with "protected logins from wireless devices (PMF)"
- **Change** The radio channel settings option for automatic steering of wireless devices now also offers Mesh WiFi steering
- **Fixed** "Wireless LAN coexistence" option now works reliably again (2.4 GHz)
- **Fixed** When one wireless frequency band is switched off, the radio network of the other frequency band is no longer interrupted
- **Fixed** Line breaks on the captive portal for the wireless guest access were not saved
- **Fixed** Wireless LAN settings (channel, wireless standard, etc.) no longer selectable when disabled
- **Fixed** On the "Wireless / Radio Network" page, wireless devices that are not connected are no longer listed in the table only with a marking for the 2.4-GHz band
## Mesh:
- **Improved** Display of important notifications for secure, reliable operation on all FRITZ!OS products in the Mesh (with red "Info"' LED and on start page)
- **Improved** Smart Home templates can now be used on every FRITZ!Box in the Mesh This allows actions like "Everything off" to be applied to all FRITZ!Boxes in the Mesh
- **Improved** Information on Mesh proved in the FRITZ!Box push service mail
- **Improved** New message in event log on wireless devices that were reregistered because of Mesh steering
- **Improved** Notice on Mesh Overview about FRITZ!Repeaters or FRITZ!Powerline devices that can still be integrated into the Mesh
- **Improved** Home network access of the FRITZ!Repeater 3000 optimized for performance in wireless bridge mode
- **Improved** The name assigned to a Mesh Repeater in the Mesh or Network Overview is applied as its "Repeater name". The user interface of the Mesh Repeater can then be accessed with http://assigned_name
- **Change** Mesh designation of the Powerline devices without wireless function that participate in the Mesh
- **Change** Device names of FRITZ!OS devices in the Mesh are adopted from the Mesh Master as push service sender names
- ** Change** During configuration of telephony in the Mesh, the "landline enabled" setting on the Mesh Repeater is switched off
- **Fixed** Distribution of wireless LAN settings in the Mesh erroneous in rare situations
- **Fixed** The battery status of Smart Home devices was occasionally displayed incorrectly on the user interface of a Mesh Repeater
- **Fixed** If a FRITZ!Box configured as a Mesh Repeater was removed from telephony, this change was not applied until the Mesh Master restarted
- **Fixed** Telephony messages (Message Waiting Indication, MWI) were not passed on to the Mesh Repeater with the right dialed telephone number
## Telephony:
- **Fixed** Type of an existing call diversion could not be changed from the initial setting
- **Fixed** In isolated cases, conversations were incorrectly negotiated with voice compression
- **Fixed** Telephony messages (Message Waiting Indication, MWI, RFC 3842) were switched off when adding/editing internet telephone numbers
- **Fixed** Error in display of contact groups from Google contacts when their names contained "&"
- **Fixed** While copying an existing telephone book the setting for "important person" was not adopted
## DECT/FRITZ!Fon:
- **Improved** Titles from the media player played on the handset can now be fast forwarded and rewound
- **Improved** https supported even for live images, for instance for images from a door intercom system
- **Improved** Playback compatibility of https web radio and podcast streams
- **Improved** Faster zapping between radio stations
- **Fixed** Occasional rhythmic sound disruptions when playing web radio
## Home network
- **Improved** Change to radio network name now optional when setting the FRITZ!Box name
- **Change** Podcasts preset for the media server updated. Also applies to FRITZ!Fon
- **Fixed** Failure to set up a home network connection for certain interfaces in the MyFRITZ!App
- **Fixed** Problem with DNS resolution of local home network devices when using DHCP without host name
- **Fixed** In some rare cases it was not possible to set LAN ports to 100 Mbit/s (Green mode)
## Smart Home:
- **Improved** Better illustrations of temperature profile in push service (email)
- **Change** Updated the AHA-HTTP-APU programming interface. https://www.avm.de/schnittstellen
- **Fixed** In rare cases the sunrise/sunset function did not work reliably
- **Fixed** Error when setting the temperature for a group
## Storage/NAS:
- **Improved** Optimized treatment of NTFS-formatted storage media
- **Fixed** In some cases new files were indexed incompletely or not at all
## System:
- **Improved** User interface permanently saves the desired sorting of a table by column
- **Improved** Dual-band wireless devices were displayed in the overview only with  2.4 GHz
- **Change** Push service sends important messages from the FRITZ!Box only to the recipient of the FRITZ!Box Info mail
- **Change** The FRITZ!Box user ftpuser is no longer created ex works (or after restoring the factory settings). One FRITZ!Box user must be created for sharing of storage media (NAS) in the home network
- **Change** Updated the TR-064 programming interface. See http://www.avm.de/schnittstellen
- **Fixed** Update with FRITZ!OS file could fail with an IPv6 connection to the FRITZ!Box
- **Fixed** No import of settings possible when "Magenta Cloud" was enabled
## Mobile network:
- **Change** Huawei 3372 mobile communications dongle switched from USB tethering to interne connection via mobile network. The mobile network PIN and provider must be entered once under "Internet / Mobile Network"
## Security
- **Change** Support of outdated TLS 1.0 standard to secure FRITZ!OS services in the server role switched off
- **Change** Length of DH parameter extended to 2048 bit for FRITZ!OS services in the server role
58 λεπτά πριν, dream21 είπε
Βγηκε η 7.10
## DSL:
αυτο πως γινεται; δε βρισκω επιλογη
Επεξ/σία από sezebo
αν θυμαμαι σωστα στο internet και στο dsl μετα εχει μια καρτελα στα δεξια που μπορεις να παιξεις με την γραμμη για να εχεις μεγαλυτερο Stability .βεβαια μπορει να χασεις σε ταχυτητα.απλα να εχεις βαλει το advanced view απο τις 3 τελειες πανω δεξια οταν μπεις μεσα στο Web interface. ειναι δεξια απο το Fritz!nas και Myfritz
3 ώρες πριν, dream21 είπε
εχω κι εγω fritz...και θελω να βαλω addblock.....ξερω το access profiles , αλλα εκει τι να βαλω στην blacklist? εχεις λιστα καπου?
  • 2 μήνες μετά...
Ξέρω χαζή ερώτηση αλλά θα την κάνω γιατί καμιά φορά από τα υποτιθέμενα προφανή την πατάς :
Το router κάνει και για PSTN και για ISDN γραμμές σωστά; Και το ρωτάω επειδή μέχρι πρότινος τα router τα έβγαζαν σε 2 εκδόσεις ανάλογα το είδος της γραμμής που είχες.
Ναι .τo international παιζει και στα 2.οταν τρεχεις το wizard στο ρωταει.αυτο για το adsl.στο vdsl παιζουμε annex b σαν region.
Πουλινέ έχεις καμιά ενημέρωση για το αν θα βγουν powerline με το G.Hn πρότυπο από την AVM; Αυτή τη στιγμή παίζω με το Asus AC87VG και με τα Devolo Magic 2 όπου πετυχαίνω οριακά καλή ταχύτητα powerline στον τελευταίο όροφο όπου έχω τα pc και σε γενικές γραμμές είμαι ικανοποιημένος ενώ με τα TP LINK 1300 (AV2) η σύνδεση φτάνει με το ζόρι και έχω συχνά αποσυνδέσεις.
Το λέω γιατί βλέπω ότι η AVM έχει ενσωματώσει MESH WIFI από το ρούτερ έως το μικρότερο extender για ένα ενιαίο οικοσύστημα αλλά το πιο δυνατό της powerline χρησιμοποιεί AV2 πρότυπο και φοβάμαι μη δεν φτάνει από κάτω έως πάνω. Διαφορετικά το άλλο που μπορώ να κάνω είναι να βάλω άλλα 1-2 Magic 2 nodes και να καταργήσω το wifi απ'το ρούτερ και να έχω ενα οικοσύστημα με τα Devolo μόνο.
Επεξ/σία από Andresalonika
On 24/08/2019 at 12:53, niliyatsi said:
Την απάντηση σε αυτά τα ερωτήματα έρχεται να μας δώσει μία από τις κορυφαίες εταιρείες στο χώρο, η AVM δίνοντας μας την ευκαιρία να παρουσιάσουμε το κορυφαίο filezilla uc browser rufus μοντέλο της που δεν είναι άλλο από το FRITZ!BOX 7590. Η AVM διαθέτει μια μεγάλη γκάμα προϊόντων όπως VDSL/ADSL routers, Powerlines, WiFi sticks, DECT phones(FON),repeaters όπως και συσκευές για radiator control, power outlets. Ιδρύθηκε το 1986, έχει έδρα το Βερολίνο και απασχολεί 660 υπαλλήλους. Τo τμήμα υποστήριξης όπως και το τμήμα κατασκευής  βρίσκονται στη Γερμανία, ενώ τα προϊόντα της εταιρείας συνοδεύονται από 5 χρόνια εγγύησης.
  • 3 μήνες μετά...
Καλησπέρα
Εχω παραγγείλει το 7590 και δεν το έχω παρει ακομη στα χέρια μου. Οταν με το καλο έρθει πως ελέγχω αν είναι η international version ή όχι?
Με forthnet (οχι voip γραμμη) θα έχω καποιο θέμα? για την συνδεσμολογία υπάρχουν οδηγίες για αρχάριους κάπου?
Ευχαριστώ
On 17/12/2019 at 20:56, Evg9 said:
Καλησπέρα
Ευχαριστώ
ναι λεει για την συνδεσμολογια μεσα.αν δεν θες να ριξεις την tdm τηλεφωνια πανω στο Fritz τοτε βαζεις ενα απλο τηλεφωνικο καλωδιο και δεν χρειαζεται το Y cable.αν και αυτο να βαλεις παλι δεν ειναι λαθος.το γραφει αν ειναι International συν οτι εχει και καποιο κωδικο.οχι παιζει κανονικα εφοσον δεν εχεις voip.επειδη το dsl του fritz ειναι rj45 προτιμησε να βαλεις καλωδιο που να τελειωνει σε rj45.παιζει και το rj11 αλλα σε σπανιες περιπτωσεις μπορει να κανεις ζημια στα pins.
