Artifact (Valve Card Game)
21 ώρες πριν, Sanjuro είπε
^Ακόμα και αν αγόραζα κάθε τόσο πακετάκια απ'την Blizzard (δεν τους έχω δώσει ούτε 1 ευρώ για το hearthstone) και πάλι θα ήθελα πρώτα να δω λίγο πως θα τα πάει το Artifact πριν δώσω χρήματα στην Valve. Γενικά έχω μια δυσανεξία στα pre-orders.
Στα artifact news τώρα, ανάμεσα σε πολλές αλλαγές έχουν και αυτό...
  • You can now recycle cards into event tickets at a rate of 20 cards to 1 ticket. There is a "Recycle Cards" tab accessible from the collection. Note that each card will currently show "N/A" where the market price would be until the market is open. Sort by market price will sort by mana cost until the market is open.
https://steamcommunity.com/games/583950/announcements/detail/1714079132209348269
Εγω μολις το αγορασα παντως, μετα τις 2 τελευταιες ανακοινωσεις που εκαναν, διαβασα οτι εχουν προτεραιοτητα και κατι σαν ladder...οποτε, το τσιμπησα.
  • Απαντ. 47
Artifact is coming to Steam in just two days! In the meantime, we're happy to launch the first in a new series of Artifact comics, called Prelude. Artifact is more than just a Dota card game — it is a shared universe with a storyline that will deepen the history, expand the world, and change the fates of the heroes of both games.
We'll also be releasing a second comic called Call to Arms on launch day, which sets the stage for a series of events that will transform the world of Dota forever. Don't forget to come back and check it out.
We're also updating the beta, once this afternoon's stress tests have completed.
Pre-loading will be available tonight!
11/26 Beta Update
Features
  • Added the ability to inspect the current deck lists during play using F2 and F3.
Bug Fixes
  • Fixes for several crashes.
  • Pressing ESC to cancel an unrecommended action no longer causes the card to become unresponsive.
  • When you try to recycle >1000 cards, the dialog box will be clearer about why you can’t.
  • Fixed the text not fitting in some dialog boxes.
  • Fixed the reward ticket image sometimes being black.
  • Fixed the allied Radiant towers covering damage preview numbers.
  • Fixed bugs with the forced surrender warnings firing too frequently and under the wrong conditions.
  • Improved timing on for Lux and Nox to make them less active.
  • Updated gauntlet rewards sounds.
  • Updated the localization files.
Ως Dota fan είχα πει να ασχοληθώ πρώτη φορά με trading card game με το Artifact. Έχω λίγο όμως απογοητευτεί με το κόστος για να μπορέσω να φτιάξω ένα ικανό deck για να μπορέσω να παίζω...
Τι ποσά παίζουν, γνωρίζετε;
17 λεπτά πριν, lemonide είπε
Η πραγματικότητα είναι πως δεν έχουμε ιδέα σε αυτή τη φάση πόσο θα κάνει ένα μελλοντικό ανταγωνιστικό deckάκι γιατί απλά δεν υπάρχει η εσωτερική αγορά ακόμα για να δούμε πόσο θα πουλάνε τις κάρτες που δεν θέλουν οι παίκτες ο ένας στον άλλο. Πάντως το παιχνίδι δίνει αρκετά πράγματα με την αρχική αγορά, και απ'οτι ξέρω μπορείς να παίζεις αν θες draft τζάμπα απλά δεν θα κερδίζεις κάρτες κλπ.
Επεξ/σία από Sanjuro
1 ώρα πριν, lemonide είπε
Άνοιξε το μάρκετ φίλε μου, μπορείς να δεις τις τιμές της καθες κάρτας, κυμαίνονται στα 5-10 λεπτά .
Με ένα 10αρικο παίρνεις όλες τις uncommon/common, δεν είναι ακριβό .
Casual phantom draft 4 dayzzzz. (Μέχρι στιγμής, υποθέτω πως θέλει τον χρόνο του για να πιάσει κανείς τα αρνητικά του, το παιχνίδι είναι και γαμώ)
^Το μόνο σαϊτ που ξέρω είναι αυτό: https://www.artifactfire.com/
Είναι πολύ νωρίς όμως για να μιλάμε για καλά deck νομίζω. Πρέπει να περάσει λίγος καιρός για να υπάρξει κάποιο meta, και μετά να μπορούμε να πούμε τι είναι πραγματικά καλό και τι όχι.
Δεν ξέρω αν είναι καλή εποχή για να φτιάξει κανείς τώρα κάποιο συγκεκριμένο δυνατό deck, είναι οι σπάνιες και καλές κάρτες υπερβολικά ακριβές ακόμα γιατί έχουν πέσει όλοι πάνω να τις πάρουν και δεν έχουν βγει αρκετές από packs ακόμα για να ικανοποιήσουν την ζήτηση. Τώρα μπορεί να είναι η στιγμή να πουλήσει κανείς. Γενικότερα μου φαίνεται πως είναι η καλύτερη εποχή για πειραματισμούς με αυτοσχέδια decks, όπως ακριβώς το ίδιο συμβαίνει και στο hearthstone αμέσως μετά το release ενός expansion... σπάει το meta και παίζει ο κόσμος ο,τι γουστάρει και αυτοσχεδιάζει.
Ξοδεψα 1,5 ευρω να φτιαξω ενα deck, σκοπευω να παιξω για πρώτη φορά constructed σημερα!
Μεχρι τώρα έχω ξοδεψει 6 event tickets σε phantom draft, στο πρώτο πήγα 5-1 στα αλλα 5 εκανα το πολύ 2 νικές.
Λιγο βλακεία που πρέπει να κανεις τουλάχιστον 3-1 για να παρεις πισω το event ticket. (75% winrate?)
