Xiaomi Mi Power Bank 2 10000mAh 12,21€
Χτύπησα και εγώ ένα καθώς έχω μείνει υπερευχαριστημένος από το αντίστοιχο των 5000mAh.
Ευχαριστούμε ts.
Αν ειναι οκ το σιτε τοτε το προ αφου ειναι ενα ευρω λιγοτερο :P
Και τα 2 τελικα εχουν quick charge 2 αντι για 3
https://www.cafago.com/en/power-banks-batteries-2481/p-pa3457.html?utm_source=shareasale έχει το προ στα 13.8 ευρο με κωδικο PA3457B . και για νεα μέλη και συνδρομη στο newsletter βγαινει 11 κάτι. Ποιό είναι καλύτερο απο τα 2;;
Υποστηριξη usb type c μονο για φορτιση του power bank και οχι για φορτιση κινητων!
By Ng Chong Seng - on 30 Apr 2017, 12:35pm
1.) USB-C port is only for input
A lot of people are attracted to the Mi Power Bank Pro because of its USB-C port. However, know that this is an input port, not an output port. So you can’t use this port to charge your USB-C device, like your Google Pixel phone or Nintendo Switch.
If you’ve a USB-C device, you can still use this power bank. But you’ve to use its regular USB Type-A port and a USB A-to-C cable. While the power bank’s USB-A port supports Qualcomm’s Quick Charge tech, it will not apply more than 5V for non-QC devices (e.g., USB Power Delivery devices). So if you don’t have a QC device, expect the power bank to only supply around 10W (or 12W for Apple devices).
If you’re so inclined to multi-task, the Mi Power Bank does support fast input and output charging at the same time.
2.) There are two versions of the Mi Power Bank Pro
Not many people know that there are two versions of the Mi Power Bank Pro: model number PLM01ZM and PLM03ZM.
PLM01ZM was the original model released in March 2016. PLM03ZM appeared later in the year in October, and was first offered in a bundle that also included a silicon case to protect the power bank. And recently, Xiaomi has started to sell this PLM03ZM as a standalone version.
It's easy to tell which model you've by just looking at the label. This is the PLM01ZM. (Click for larger image.)
And this is the PLM03ZM. (Click for larger image.)
The PLM01ZM and PLM03ZM are the same for the most part. However, the newer PLM03ZM’s fast charge controller also supports Qualcomm’s Quick Charge 3.0 (PLM01ZM only Quick Charge 2.0). So there will be some gains if you pair it with a QC3.0 charger (to charge the power bank) or use it to charge a QC3.0 device.
Also, the PLM03ZM supports HiSilicon’s Fast Charging Protocol (the PLM01ZM doesn’t). This will benefit users who use Huawei phones that support FCP, such as the Huawei P9 and Mate 8.
Υ.Γ. μπορει να σταματησουν στα τελωνεια τους γιατι απαγορευευτε να στελνουν μπαταριες..
Επεξ/σία από kage
Επιβεβαιώνω ότι η Type C είναι μόνο input, για φόρτιση του power bank. Για φόρτιση συσκευής, καλώδιο type A σε--> ότι παίρνει η συσκευή σας. (Άλλο μοντέλο βέβαια αλλα εκτιμώ ότι θα έχουν ίδια χαρακτηριστικά πάνω κάτω)
Προσοχή μόνο γιατί έχει κάτι ιδιαιτερότητες. Όταν το πήρα δοκίμασα με 2 καλώδια και δεν μπορούσα να φορτίσω τη συσκευή που είχα τότε (Lumia) και το παράτησα στο ράφι. Νόμιζα ότι ήταν ελαττωματικό το power bank. Τελικά δοκίμασα πρόσφατα με άλλο καλώδιο (τέρμα κινεζιά) και ως εκ θαύματος, είδα ότι φορτίζει κανονικά τα πάντα.
Πρεπει να ειναι fake, το δοκιμασα και οντως παει στα 11.16 ευρω, δεν γινεται να στο δινει σε αυτην  την τιμη οταν ολοι το δινουν στα 30 δολλαρια και πανω
το πήρα γύρω στα 14,5 ευρώ από άλλο νήμα (άματο ψάξεις) και άλλο κινεζο-μαγαζί (gearbest) και ήταν γνήσιο. Η τιμή θέλω να πω δεν είναι τέρμα ένδειξη αν είναι ή όχι.
Δεν είναι fake. Αν δεις είναι το παλιό μοντέλο. Επίσης για αυτό υπάρχει το paypal.
