ViPeRMaN Δημοσ. 29 Νοεμβρίου 2003 Δημοσ. 29 Νοεμβρίου 2003 molis trexo to game,anigi i mixani grafikon(mallon tou quake 3 arena einai) kai idou ta apotelesmata.... COD 1.0 build win-x86 Oct 5 2003 ----- FS_Startup ----- Current language: english Current search path: G:\PROGRA~1\CALLOF~1\main\pak6.pk3 (3 files) G:\PROGRA~1\CALLOF~1\main\pak5.pk3 (4858 files) G:\PROGRA~1\CALLOF~1\main\pak4.pk3 (1668 files) G:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files) G:\PROGRA~1\CALLOF~1\main\pak2.pk3 (694 files) G:\PROGRA~1\CALLOF~1\main\pak1.pk3 (2642 files) G:\PROGRA~1\CALLOF~1\main\pak0.pk3 (12828 files) G:\PROGRA~1\CALLOF~1/main G:\PROGRA~1\CALLOF~1\main\localized_english_pak1.pk3 (3736 files) localized assets pak file for english G:\PROGRA~1\CALLOF~1\main\localized_english_pak0.pk3 (1204 files) localized assets pak file for english File Handles: ---------------------- 29625 files in pk3 files execing default.cfg couldn't exec language.cfg couldn't exec config.cfg couldn't exec autoexec.cfg ========= autoconfigure configure.csv: using configuration 1200 cpu MHz 256 sys MB 32 vid MB execing configure.cfg fs_basepath is write protected. fs_homepath is write protected. Hunk_Clear: reset the hunk ok ...detecting CPU, found AMD w/ 3DNow! Measured CPU speed is 1.56 GHz System memory is 256 MB (capped at 1 GB) Video card memory is 32 MB Streaming SIMD Extensions (SSE) supported ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded ...setting mode 3: 640 480 FS ...using colorbits of 32 ...calling CDS: ok ...registered window class ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 8 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- Hunk_Clear: reset the hunk ok Could not load OpenGL. Make sure that you have the latest drivers for your video card from the manufacturer's web site. any ideas?????
Vasilius Δημοσ. 29 Νοεμβρίου 2003 Δημοσ. 29 Νοεμβρίου 2003 NAi katevase detonator 43.45 k tha sai fine.
CodeMan Δημοσ. 4 Δεκεμβρίου 2003 Δημοσ. 4 Δεκεμβρίου 2003 Asxeto.....pragmatika poly wraio game!!To termatisa prosfata kai ecseplaghn!! Teleia grafika kai effect!!
