Χiaomi redmi note 2 vs redmi note 3
Δίπλα η ελληνική κοινότητα της miui, ζητά την βοήθεια απ' όποιον μπορεί, στη παγκόσμια ψηφοφορία που παίρνει μέρος. Όποιος θέλει ας ρίξει μια ματιά εδώ ->
https://xiaomi-miui.gr/community/index.php/Thread/10887-Ψηφίστε-την-κοινότητά-μας-για-τα-MIUI-Fan-Site-Awards-2015-Ξεκίνησε/?pageNo=1
Thanks!
Ψηφισαμε Ελλαδα η Ινδια μας περναει αλλα λογικο με τοσο κοσμο που εχει:Ρ
  • Απαντ. 63
To 3 παρε γιατί
1)και καλύτερη ποιότητα έχει
2)και δακτυλικο αποτύπωμα
3)και 3 ram /αντί για 2 που έχει το άλλο
4)****4000mah μπαταρία****
+1 στο 3
εννοειται εχει καλυτερη κατασκευη με εμφανη διαφορά το 3 κ βεβαια μπαταρια "σκυλι"  :)
Επεξ/σία από aces
Update from Official:-
Hi everyone, i am the in charge for the lock IK subject product manager. Just like before, i have released details based on the (link).
In the future, all Xiaomi phone products will have the bootloader locked for security purposes.
However, we want to let you guys to continue
your "Mi Fever" and "play" the phone.So as such, we have released the unlocking bootloader tool.
We acknowledge that all the phones we produced have their bootloader locked. Therefore, everyone would not be able to access the bootloader to flash and even if you attempt to do it via in house android method to achieve root, and edit the boot or recovery, the system will still be unable to work.
Based on the procedure previously, we were able to provide to stable and developer version.
For developer version, we had originally provided root option so as to allow Mi Fans to have the freedom to play with their devices. However due to google cts requirements, we had to change all the versions to without root and as such the system will not have su inside.
Even then if users decide to flash to developer version, they will be unable to achieve root.At the moment, all that was mentioned previously was a buildup to you not unlocking the bootloader circumstances.To unlock the bootloader on developer version, you first need to flash to the developer version.Thereafter, through the unlock bootloader tool, you can enter the system and into the permissons manager, you will see the option to enable root.Enabling root is an upgrading process for the developer version in order for the developer version to have root.This way, you will be able to use root features normally but then there comes the issue again.Having root means that there are security concerns. Should you lose your phone, we will not be able to protect your privacy.We estimate that next week we will announce the unlock bootloader tool, some of you might have gotten it already but you need Xiaomi staff to authorise you in order to use it. To unlock the bootloader, we did so only after much thoughts and debate with regards to customers privacy concern.Though the process is slightly cubersome, it was neccessary.
Απάντηση που δημοσιευτηκε δίπλα. Αυτό σημαίνει ότι το 3 και όλα τα επόμενα κινητά (Μi5,κτλ) θα βγαίνουν με κλειδωμένο bootloader.
