noa113 Δημοσ. 4 Νοεμβρίου 2015 Μέλος Δημοσ. 4 Νοεμβρίου 2015 Τότε Jim μήπως να το βγάλω κι εγώ; Δεν δοκίμασα αυτό που λες αλλά γενικά δεν μου αρέσει να κάνω install προγράμματα gnome-XYZ σε σύστημα χωρίς gnome, και στην συγκεκριμένη περίπτωση μάλλον έχω δίκιο: $ aptitude install gnome-media -s The following NEW packages will be installed: accountsservice{a} apache2-bin{a} apg{a} bluez{a} bluez-obexd{a} cheese-common{a} cracklib-runtime{a} dleyna-server{a} freepats{a} gir1.2-clutter-1.0{a} gir1.2-clutter-gst-2.0{a} gir1.2-cogl-1.0{a} gir1.2-coglpango-1.0{a} gir1.2-evince-3.0{a} gir1.2-gtkclutter-1.0{a} gir1.2-javascriptcoregtk-3.0{a} gir1.2-json-1.0{a} gir1.2-soup-2.4{a} gir1.2-webkit-3.0{a} gkbd-capplet{a} gnome-bluetooth{a} gnome-control-center{a} gnome-control-center-data{a} gnome-desktop3-data{a} gnome-media gnome-online-accounts{a} gnome-settings-daemon{a} gnome-sushi{a} gnome-user-guide{a} gnome-user-share{a} gstreamer0.10-gconf{a} gstreamer0.10-plugins-good{a} gstreamer0.10-pulseaudio{a} gstreamer0.10-x{a} gstreamer1.0-clutter{a} gstreamer1.0-plugins-bad{a} gvfs-backends{a} hwdata{a} libaccountsservice0{a} libapache2-mod-dnssd{a} libapr1{a} libaprutil1{a} libaprutil1-dbd-sqlite3{a} libaprutil1-ldap{a} libcdio-cdda1{a} libcdio-paranoia1{a} libcheese-gtk23{a} libcheese7{a} libclutter-1.0-0{a} libclutter-1.0-common{a} libclutter-gst-2.0-0{a} libclutter-gtk-1.0-0{a} libcogl-common{a} libcogl-pango20{a} libcogl-path20{a} libcogl20{a} libcolord-gtk1{a} libcrack2{a} libdleyna-connector-dbus-1.0-1{a} libdleyna-core-1.0-3{a} libexempi3{a} libfftw3-double3{a} libfluidsynth1{a} libgail-3-0{a} libgee-0.8-2{a} libgeocode-glib0{a} libgjs0e{a} libgme0{a} libgmime-2.6-0{a} libgnome-bluetooth13{a} libgnome-desktop-3-10{a} libgnomekbd-common{a} libgnomekbd8{a} libgoa-1.0-0b{a} libgoa-1.0-common{a} libgoa-backend-1.0-1{a} libgrilo-0.2-1{a} libgssdp-1.0-3{a} libgstreamer-plugins-bad1.0-0{a} libgtkglext1{a} libgtop2-7{a} libgtop2-common{a} libgupnp-1.0-4{a} libgupnp-av-1.0-2{a} libgupnp-dlna-2.0-3{a} libgweather-3-6{a} libgweather-common{a} libibus-1.0-5{a} libilmbase6{a} libinput5{a} libiptcdata0{a} libmediaart-1.0-0{a} libmimic0{a} libmjpegutils-2.1-0{a} libmms0{a} libmozjs-24-0{a} libmpeg2encpp-2.1-0{a} libmpg123-0{a} libmplex2-2.1-0{a} libmusicbrainz5-1{a} libnautilus-extension1a{a} libnss-myhostname{a} libofa0{a} libopenal-data{a} libopenal1{a} libopencv-calib3d2.4{a} libopencv-contrib2.4{a} libopencv-core2.4{a} libopencv-features2d2.4{a} libopencv-flann2.4{a} libopencv-highgui2.4{a} libopencv-imgproc2.4{a} libopencv-legacy2.4{a} libopencv-ml2.4{a} libopencv-objdetect2.4{a} libopencv-video2.4{a} libopenexr6{a} libpulse-mainloop-glib0{a} libpwquality-common{a} libpwquality1{a} libquvi-scripts{a} libquvi7{a} librygel-core-2.4-2{a} librygel-renderer-2.4-2{a} librygel-server-2.4-2{a} libsbc1{a} libsoundtouch0{a} libspandsp2{a} libsrtp0{a} libtbb2{a} libtelepathy-glib0{a} libtotem-plparser18{a} libtracker-sparql-1.0-0{a} libunistring0{a} libvo-aacenc0{a} libvo-amrwbenc0{a} libwacom-common{a} libwacom2{a} libwildmidi-config{a} libwildmidi1{a} libyelp0{a} libzbar0{a} mesa-utils{a} mousetweaks{a} nautilus{a} nautilus-data{a} realmd{a} rygel{a} yelp{a} yelp-xsl{a} 0 packages upgraded, 150 newly installed, 0 to remove and 0 not upgraded. Need to get 91.3 MB of archives. After unpacking 258 MB will be used. Do you want to continue? [Y/n/?]
Oxygene Δημοσ. 4 Νοεμβρίου 2015 Δημοσ. 4 Νοεμβρίου 2015 Μόνο εμένα δεν μου δούλεψε ποτέ σωστά το apulse; Μετά από λίγο ο ήχος χάνεται στην κλήση (η δική μου φωνή, το άτομο που συνομιλώ συνεχίζει να ακούγεται κανονικά)
tritonas00 Δημοσ. 4 Νοεμβρίου 2015 Δημοσ. 4 Νοεμβρίου 2015 Δοκιμασες να πεις στο skype να μην κανει auto adjust το volume?https://github.com/i-rinat/apulse/issues/33
Oxygene Δημοσ. 4 Νοεμβρίου 2015 Δημοσ. 4 Νοεμβρίου 2015 Δεν θυμάμαι, θα το κοιτάξω τώρα που το ανέφερες. Για την ιστορία, εγκατέστησα και το skype42, αλλά εμφανίζει πολλά issues τους τελευταίους μήνες (π.χ. αποσυνδέεται και για να ξανασυνδεθεί πρέπει πρώτα να κάνω login από το τελευταίο skype)
jim_p Δημοσ. 5 Νοεμβρίου 2015 Δημοσ. 5 Νοεμβρίου 2015 Jesus! Κανε το apt να μην βαζει suggested και recommended εξαρτησεις, γιατι βλεπω βαζει και εξαρτησεις των εξατησεων... των εξαρτησεων http://askubuntu.com/questions/179060/how-not-to-install-recommended-and-suggested-packages
noa113 Δημοσ. 5 Νοεμβρίου 2015 Μέλος Δημοσ. 5 Νοεμβρίου 2015 Έκανα απεγκατάσταση το pulseaudio αλλά και πάλι δεν δουλεύει ο ήχος στο Pychess ενώ δουλεύει στον Iceweasel. Στον alsamixer πλέον έχω πολλά κανάλια:* Master* Headphone (Muted)* speaker* PCM* Line (Muted)* Line Boost (Muted)* Mic (Muted)* Mic Boost (Muted)* Beep Jesus! Κανε το apt να μην βαζει suggested και recommended εξαρτησεις, γιατι βλεπω βαζει και εξαρτησεις των εξατησεων... των εξαρτησεων http://askubuntu.com/questions/179060/how-not-to-install-recommended-and-suggested-packages Θα το δοκιμασω και θα επανελθω...
jim_p Δημοσ. 5 Νοεμβρίου 2015 Δημοσ. 5 Νοεμβρίου 2015 Γιατι εβγαλες το pa αφου δεν ειχες καποιο προβλημα με αυτο;
noa113 Δημοσ. 5 Νοεμβρίου 2015 Μέλος Δημοσ. 5 Νοεμβρίου 2015 Το έβγαλα γιατί έλεγα μήπως αυτή ήταν η αιτία. Επίσης το λέει και το wiki: "If that does not work well and remove the /etc/pulse directory and reinstall PulseAudio". Τελικά δεν δουλεύει ο ήχος στο pychess, με ή χωρίς pulseaudio.
noa113 Δημοσ. 7 Νοεμβρίου 2015 Μέλος Δημοσ. 7 Νοεμβρίου 2015 Καλησπέρα Jim, το έβαλα και το gnome-media αλλά δεν είχα κάποια διαφορά στον ήχο: δουλέυει στο iceweasel αλλά όχι στο pychess...
jim_p Δημοσ. 7 Νοεμβρίου 2015 Δημοσ. 7 Νοεμβρίου 2015 Βγαλε ενα screenshot απο την τρεχουσα ρυθμιση του gstreamer-properties, την καρτελα που λεει audio.
noa113 Δημοσ. 10 Νοεμβρίου 2015 Μέλος Δημοσ. 10 Νοεμβρίου 2015 Όταν τρέχω από κονσόλα gstreamer-properties παίρνω μήνυμα λάθους: $ gstreamer-properties Gtk-Message: GtkDialog mapped without a transient parent. This is discouraged. Και ταυτόχρονα βγαίνει ένα παράθυρο που μου λέει κι άλλο μήνυμα: Failed to load UI file; please check your installation. Μάλλον τελικά ήθελε κάποια από τις εξαρτήσεις που του είπα να μην βάλει, σωστά;
k_antoni Δημοσ. 10 Νοεμβρίου 2015 Δημοσ. 10 Νοεμβρίου 2015 Από περιέργεια, τι θα βάζατε σε desktop/laptop, jessie ή stretch; Φίλος θέλει ένα μηχάνημα σταθερό, αλλά ταυτόχρονα με τις τελευταίες εκδόσεις των προγραμμάτων! thnx
Oxygene Δημοσ. 11 Νοεμβρίου 2015 Δημοσ. 11 Νοεμβρίου 2015 Debian stable και τελευταίες εκδόσεις των προγραμμάτων δεν πάνε μαζί 1
pmav99 Δημοσ. 11 Νοεμβρίου 2015 Δημοσ. 11 Νοεμβρίου 2015 Από περιέργεια, τι θα βάζατε σε desktop/laptop, jessie ή stretch; Φίλος θέλει ένα μηχάνημα σταθερό, αλλά ταυτόχρονα με τις τελευταίες εκδόσεις των προγραμμάτων! ubuntu LTS + ppa για ότι χρειάζεται/θέλει πιο καινούριο.
