jim_p Δημοσ. 23 Ιουλίου 2015 Δημοσ. 23 Ιουλίου 2015 Το skype ειναι σε qt4 οποτε μαλλον σου πηδηξε τις βιβλιοθηκες της qt4. Συγκεκριμενα θελει αυτα $ apt-cache depends skype skype Depends: libc6 Depends: libc6 Depends: libgcc1 Depends: libqt4-dbus Depends: libqt4-network Depends: libqt4-xml Depends: libqtcore4 Depends: libqtgui4 Depends: libqtwebkit4 Depends: libstdc++6 Depends: libx11-6 Depends: libxext6 Depends: libxss1 Depends: libxv1 Depends: libssl1.0.0 Depends: libpulse0 Depends: libasound2-plugins
warlock9_0 Δημοσ. 23 Ιουλίου 2015 Δημοσ. 23 Ιουλίου 2015 το libasound είναι broken όμως, αυτά πάει να βάλει και με το -f
warlock9_0 Δημοσ. 23 Ιουλίου 2015 Δημοσ. 23 Ιουλίου 2015 σε τι μπορεί να επηρεάσει ο φάκελος? να το libasound $ sudo apt-get install -s libasound2-plugins:i386 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: libasound2-plugins:i386 : Depends: libavcodec-ffmpeg56:i386 (>= 7:2.4) but it is not going to be installed or libavcodec-ffmpeg-extra56:i386 (>= 7:2.4) but it is not going to be installed E: Unable to correct problems, you have held broken packages. αν πάω να βάλω κάτι από αυτά $ sudo apt-get install -s libavcodec-ffmpeg-extra56:i386 Reading package lists... Done Building dependency tree Reading state information... Done Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation: The following packages have unmet dependencies: libavcodec-ffmpeg-extra56:i386 : Depends: libtwolame0:i386 but it is not going to be installed E: Unable to correct problems, you have held broken packages. αν πάω να βάλω αυτό γίνεται πανικός και βγάζει τα μισά πράγματα του συστήματος $ sudo apt-get install -s libtwolame0:i386 | head -n 50 Reading package lists... Building dependency tree... Reading state information... The following packages were automatically installed and are no longer required: baloo-kf5 libbaloocore4 libbaloofiles4 libbaloopim4 libbalooqueryparser4 libbalooxapian4 libgrantlee-core0 libgrantlee-gui0 libkdcraw-data libkdgantt2-0 libkpgp4 libqgpgme1 libsendlater4 libswscale-ffmpeg3 Use 'apt-get autoremove' to remove them. The following extra packages will be installed: gcc-5-base:i386 libc6:i386 libc6-i686:i386 libgcc1:i386 Suggested packages: glibc-doc:i386 locales:i386 The following packages will be REMOVED: akregator amarok dolphin dragonplayer ffmpegthumbs freespacenotifier gstreamer1.0-plugins-ugly gwenview kamera kate katepart kde-runtime kde-style-qtcurve kdelibs-bin kdelibs5-plugins kdepim-runtime kdepimlibs-kio-plugins kdesudo kdoctools kio-audiocd kmix konsole libakonadi-calendar4 libakonadi-contact4 libakonadi-kcal4 libakonadi-kde4 libakonadi-kmime4 libavcodec-ffmpeg56 libavformat-ffmpeg56 libbaloowidgets4 libcalendarsupport4 libincidenceeditorsng4 libkabc4 libkactivities-models1 libkalarmcal2 libkateinterfaces4 libkatepartinterfaces4 libkcal4 libkcalutils4 libkcddb4 libkdcraw23 libkde3support4 libkdepim4 libkdepimdbusinterfaces4 libkdewebkit5 libkemoticons4 libkf5filemetadata-bin libkfile4 libkfilemetadata4 libkgapi2-2 libkhtml5 libkio5 libkipi11 libkleo4 libkmediaplayer4 libknewstuff2-4 libknewstuff3-4 libknotifyconfig4 libkolab0 libkonq-common libkonq5abi1 libkonqsidebarplugin4a libkontactinterface4a libkparts4 libkpimidentities4 libkpimtextedit4 libkpimutils4 libkprintutils4 libktexteditor4 libktnef4 libktorrent-l10n libktorrent5 libkutils4 libkworkspace4abi2 libkxmlrpcclient4 libmailcommon4 libmailimporter4 libmailtransport4 libmessagecomposer4 libmessagecore4 libmessageviewer4 libmicroblog4 libmuon libokularcore3 libopencv-highgui2.4 libopenimageio1.2 libpimcommon4 libplasma3 libplasmaclock4abi4 libplasmagenericshell4 libsmokekdecore4-3 libsmokekdeui4-3 libsmokekfile3 libsmokekhtml3 libsmokekio3 libsmokeknewstuff2-3 libsmokeknewstuff3-3 libsmokekparts3 libsmokektexteditor3 libsmokekutils3 libsmokeplasma3 libstreamanalyzer0 libsyndication4 libtaskmanager4abi4 libtemplateparser4 libtwolame0 libweather-ion6 muon-discover muon-notifier muon-updater phonon-backend-vlc plasma-dataengines-workspace plasma-scriptengine-javascript plasma-scriptengine-python plasma-scriptengine-ruby plasma-scriptengine-superkaramba plasma-scriptengine-webkit plasma-scriptengines plasma-widget-folderview plasma-widgets-workspace python-kde4 python3-pykde4 ruby-kde4 ruby-plasma software-properties-kde vlc vlc-nox vlc-plugin-notify The following NEW packages will be installed: gcc-5-base:i386 libc6:i386 libc6-i686:i386 libgcc1:i386 libtwolame0:i386 0 upgraded, 5 newly installed, 128 to remove and 5 not upgraded. jim σε unstable είσαι?
jim_p Δημοσ. 23 Ιουλίου 2015 Δημοσ. 23 Ιουλίου 2015 Σε testing ειμαι αλλα δεν εχω τιποτα απο kde, μονο qt4 (για smplayer, subdownloader, skype και wps-office) και qt5 (για smtube, owncloud-client και mkvtoolnix-gui).
bilakos10 Δημοσ. 23 Ιουλίου 2015 Δημοσ. 23 Ιουλίου 2015 @warlock0_9 Δοκίμασε να κάνεις remove το skype και μετά να περάσεις την libasound2.
warlock9_0 Δημοσ. 23 Ιουλίου 2015 Δημοσ. 23 Ιουλίου 2015 αυτά που έβαλα από πάνω είναι με το skype απεγκατεστημένο
eSATA Δημοσ. 27 Ιουλίου 2015 Δημοσ. 27 Ιουλίου 2015 Κατέβασα το Telegram από εδώ, που έχει μέσα το telegram σαν executable αρχείο και δουλεύει κανονικά. Το έβαλα στο /home/esata/.local/share/applications/Telegram για να το έχω στο μενού. Έφτιαξα αρχείο Telegram.desktop στο /home/esata/.local/share/applications/Telegram.desktop και του έδωσα τις παρακάτω ρυθμίσεις: [Desktop Entry] Encoding=UTF-8 Name=Telegram Exec=/home/esata/.local/share/applications/Telegram/Telegram Icon=/home/esata/.local/share/applications/Telegram/teleicon.png Type=Application Categories=Network; Εμφανίστηκε στο μενού και δουλεύει κανονικά αλλά το πρόβλημα είναι ότι δεν έχει icon.. Καμια ιδέα; (είμαι λίγο offtopic αλλά μην ανοίγω καινούργιο θέμα)
warlock9_0 Δημοσ. 27 Ιουλίου 2015 Δημοσ. 27 Ιουλίου 2015 στο .xsession-errors λογικά θα σου λέει ποιο είναι το πρόβλημα 1
eSATA Δημοσ. 27 Ιουλίου 2015 Δημοσ. 27 Ιουλίου 2015 στο .xsession-errors λογικά θα σου λέει ποιο είναι το πρόβλημα (wrapper-1.0:996): exo-WARNING **: Failed to load "/home/esata/.local/share/applications/Telegram/teleicon.png": Failed to open file "/home/esata/.local/share/applications/Telegram/teleicon.png": Permission denied Thanks. Το έβαλα αλλού και το πήρε κανονικά.
warlock9_0 Δημοσ. 28 Ιουλίου 2015 Δημοσ. 28 Ιουλίου 2015 έτσι για την ιστορία, τα broken dependencies του skype φτιάχτηκαν και έγινε η εγκατάσταση κανονικά δεν υπάρχει tray όμως γιατί σταμάτησε να υποστηρίζεται στο kde 5, φαντάζομαι το ίδιο θα συμβαίνει και σε dropbox, viber κλπ εδώ το γιατί http://blog.martin-graesslin.com/blog/2014/03/system-tray-in-plasma-next/ σε αρκετές διανομές λύνεται με το sni-qt και patchαρισμένη Qt αλλά στο debian δεν το βλέπω να γίνεται https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=712938#25
warlock9_0 Δημοσ. 15 Αυγούστου 2015 Δημοσ. 15 Αυγούστου 2015 πρέπει να είναι από τις λίγες φορές στα αρκετά χρόνια που έχω το debian που το sid ειναι ΚΑΡΑσπασμένο μιλαμε στο kde γίνεται πανικός, καλά που δεν έκανα upgrade στο laptop που κάνω δουλειά
bilakos10 Δημοσ. 19 Αυγούστου 2015 Δημοσ. 19 Αυγούστου 2015 πρέπει να είναι από τις λίγες φορές στα αρκετά χρόνια που έχω το debian που το sid ειναι ΚΑΡΑσπασμένο μιλαμε στο kde γίνεται πανικός, καλά που δεν έκανα upgrade στο laptop που κάνω δουλειά Είναι μια καλή ευκαιρία να φύγεις από το KDE
Oxygene Δημοσ. 19 Αυγούστου 2015 Δημοσ. 19 Αυγούστου 2015 'Η να φύγει από Debian και να πάει σε Arch 1
