Μια βοηθεια...Playstation ή X-Box ???
Γιάννης Platano
giannh sigxaritiria gia tin epilogi sou!na se enimeroso episis oti afou valis tsipaki sto xbox boris na metaferis arxia safto kai na antigrapsis pexnidia sto sliro tou klt -XORIS- na to sindesis katholou me to pc.Iparxoun programmata pou einai san file managers pou boris na metaferis arxia na svisis ktl. An exis kapoio provlima me tous emulators xbox media player ktl emeis eimaste edo post it!sou protino na dokimasis prota N64 kai ton xbox media player. exei katapliktikes dinatotites o media player!
  • Απαντ. 58
giannh sigxaritiria gia tin epilogi sou!na se enimeroso episis oti afou valis tsipaki sto xbox boris na metaferis arxia safto kai na antigrapsis pexnidia sto sliro tou klt -XORIS- na to sindesis katholou me to pc[/b'].Iparxoun programmata pou einai san file managers pou boris na metaferis arxia na svisis ktl. An exis kapoio provlima me tous emulators xbox media player ktl emeis eimaste edo post it!sou protino na dokimasis prota N64 kai ton xbox media player. exei katapliktikes dinatotites o media player!
Πολυ ενδιαφερον αυτο φιλε μου για τη μεταφορα αρχειων.Πως γινεται???Μεχρι την Τριτη θα το εχω τσιπαρει... :D :D :D
i metafora arxeion ginetai meso enos ftp client
sou proteino ton flashfxp.tha agoraseis ena kalodio crossover oste na sindeseis to pc sou me to xbox
gia na ginoun ola auta bebaia tha peis sto filaraki pou tha sto tsiparei na sou perasei kai to programma evolution-x..mi to xehaseis file
otan ta kaneis ola auta...edo tha eimaste na se boithisoume...einai ola poli apla
Ευχαριστω πολυ παιδια!!!! :D :D
boris na metaferis oti arxia thelis sto xbox akoma kai to evolution-x XORIS na sindeseis to xbox me pc. to mono pou xreazesei einai ena programmataki. Kikloforoun 2 giafti ti doulia to xToolBox v0.41 kai to boXplorer v0.96 Ta programmata afta ta grafis se cd i dvd pou diabazete apo to xbox kai aplos ta trexis apo to xbox kai i doulia ginete. Ektos apo to evolution-x boris na valis kai alles dashboards opos avalaunch an thes vevea na exis oles tis dashobards pou kiloforoun vazis tin X-select pou exei epilogi na dialegis me poia dashboard tha ksekinisis apo oses exis valei!
Parepimtontos ginete to xbox na peksi antigrafes kai genika na kani otidipote me tsipaki XORIS tsipaki me katalila programata exploit pou exoun bgei.Exo ola ta katalila programata gia na to kano den to exo dokimasi vevea giati an ginei kamia stravi me afto bori na ginei monimi zimia.
Koitakse sto xbox sou tin imerominia pou exi apo piso DEN prepei na ine poli prosfati. I teleftea ekdosi tou xbox einai i 1.4 kai mexri stigmis den ipostirizete apo kanena tsipaki. Oi ipoloipes ekdoseis den exoun kanena provlima. (1.0 1.1 1.2 1.3) Ego exo tin 1.1 kai den exo kanena provlima :) boris na deis ti ekdosi einai to xbox sou poli efkola des afti ti selida: http://www.xbox-scene.com/versions.php gia perisoteres plirofories.
Loipon paidia molis pira kai ego Xbox beno lipon sto modchip.gr gia na agoraso chip kai exi ta exis 3:Devil Chip 1.3,Lpc Mod kai to X-elexis pio mou protinete na valo etsi oste kai na mporo na alaxo ton disko kai va valo to evo-X gia ripping alla kai ton media player gia mo3 divx etc
tin topothetisi tha tin kano ego
Ειλικρινα δεν το καταλαβα πως χωρις να τα συνδεσω με καλωδιο μπορουν να επικοινωνουν pc και xbox....Παρακαλω για μια εξηγηση ...Ευχαριστω πολυ προκαταβολικα!!!! :D :D Αν τελικα επιλεξω καλωδιακη συνδεση που μπορω να βρω 10 μετρα lan καλωδιο?? Στα μαγαζια με ηλεκτρικα ή ηλεκτρονικα??? :?: :?: :?:
Τελικα το τσιπαρα χθες βραδυ...Ολα καλα φαινοντε και απο σημερα....αρχιζω.Το μονο κακο οτι το dvd ειναι Philips και δεν διαβαζει απλα cd αλλα θελει cdrw.Μου ειπε ομως ο φιλος οτι καπου ακουσε οτι υπαρχει τροπος να τα διαβασει.Ξερει κανεις κατι???Ευχαριστω πολυ. :D :D :D
Δεν την εχω εφαρμοσει την παρακατω μεθοδο και δεν ξερω αν λειτουργει.Κανε μια προσπαθεια παντως...
GET ALL TYPES/BRANDS OF CDRs TO WORK ON YOUR XBOX!
Until now, it has been a common misconception that CDRs don't work on most Xboxes. Our very own tech guru, Mark ( a.k.a. gAm3 Fr3aQu3), has discovered the proper way to burn games on any CDR that will work on your modified Xbox!
Discovered By: Mark of Precisionmods (a.k.a. gAm3 Fr3aQu3) on Wed.08.07.02
Requirements:
01.Goldenhawk’s CD-Rwin 4.0 or Higher [4.0 Recommended]
02.Fire Burner v1.06 [Recommended]
03.CD-R/CD-RW or DVD-R/DVD-RW Drive [Recommended]
04.DVD/CD-Rom Drive
05.Blank CD-R’s [of course]
06.Modified XBOX
Step 1:
Place the CD-RW backup in your CD/DVD-Rom Drive. Launch CD-Rwin. Click on Extract Disc/Tracks/Sectors [3rd Icon from the left].
Step 2:
Select “Disc Image/Cuesheet” for Extract Mode. Under File Name, select a place where you want to save your image. Under Reading Options, leave “RAW” and “CD-Text” checked. Select “Ignore” under Error Recovery. For Jitter Correction and Subcode Analysis, just leave it on “Auto”. For Data Speed, Audio Speed, Read Retry Count, and Subcode Threshold, just leave it as it is. Save the settings by clicking on “Save Settings”. Now Click Start. CD-Rwin should now be creating a Game-Name.BIN and a Game-Name.CUE
Step 3:
After the 2 files have been created, launch Fire Burner v1.06. Click on Visual CUE Burner/Binchunker. Inside the Fire Burner v1.06 window, right click and select Load Tracks from *.CUE. Find your Game-Name.CUE and open it. Now right click again and select Burn/Test Burn. Select your Recording Device and Writing Speed [i use 4x]. Recording Method should be at Disk at Once [DAO] aka “RAW”. Check “Eject CD” and “Close Session”. Everything else should be left unchecked. Now click OK. Your Xbox CD-R backup should now be recording.
Step 4:
Once finished, put the Xbox CD-R backup in your Xbox and have some fun! ^_^
***Reproduction of the above content is not allowed without the permission of Precision Mods. 08.12.02
