Δε νομιζω να επηρεαζει σε κατι το ipv6. Δεν ειμαι και σιγουρος ομως.
Προσπαθησε να συνδεθεις και παρακολουθησε το dmesg.
Απο εκει πιστευω θα παρουμε απαντηση για το τι φταιει...
Αυτά μου βγάζει το dmesg
>Manufacturer: Realtek
[ 75.473850] usb 2-6: >SerialNumber: 00e04c000001
[ 75.474444] rtl8192cu: Chip version 0x11
[ 75.557206] rtl8192cu: MAC address: 00:e0:4c:0f:01:70
[ 75.557218] rtl8192cu: Board Type 0
[ 75.557447] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 75.557457] cfg80211: Updating information on frequency 2412 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557463] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557469] cfg80211: Updating information on frequency 2417 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557475] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557480] cfg80211: Updating information on frequency 2422 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557486] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557491] cfg80211: Updating information on frequency 2427 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557497] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557502] cfg80211: Updating information on frequency 2432 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557507] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557512] cfg80211: Updating information on frequency 2437 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557518] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557523] cfg80211: Updating information on frequency 2442 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557529] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557534] cfg80211: Updating information on frequency 2447 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557540] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557545] cfg80211: Updating information on frequency 2452 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557550] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557555] cfg80211: Updating information on frequency 2457 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557561] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557566] cfg80211: Updating information on frequency 2462 MHz for a 20 MHz width channel with regulatory rule:
[ 75.557572] cfg80211: 2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A mBi, 2000 mBm)
[ 75.557577] cfg80211: Disabling freq 2467 MHz as custom regd has no rule that fits a 20 MHz wide channel
[ 75.557582] cfg80211: Disabling freq 2472 MHz as custom regd has no rule that fits a 20 MHz wide channel
[ 75.557587] cfg80211: Disabling freq 2484 MHz as custom regd has no rule that fits a 20 MHz wide channel
[ 75.557652] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw.bin
[ 75.571397] cfg80211: Ignoring regulatory request Set by core since the driver uses its own custom regulatory domain
[ 75.571687] ieee80211 phy2: >Selected rate control algorithm 'rtl_rc'
[ 75.572683] rtlwifi: wireless switch is on
[ 75.595051] rtl8192cu: MAC auto ON okay!
[ 75.629312] rtl8192cu: Tx queue select: 0x05
[ 75.996783] IPv6: ADDRCONF(NETDEV_UP): wlan1: link is not ready
Δεν μας βοηθα και πολυ.
Για να μην μπλεκεις με κονσολες και wpa_supplicant, θα προτεινα να βαλεις wicd και να προσπαθησεις να συνδεθεις μεσω αυτου.
Ναι,ετσι κ αλλιως Free access ειναι.(ο σπιτονοικοκυρης το εχει,το γνωριζει).
Και απο κοντα τα ιδια παλι..Με φαινεται θα αγορασω κανενα Access point.Ελπιζω να πιανει σημα αυτο κ να δουλευει!
Περιεργα πραγματα παντως, να παιζει με το live cd και να μην παιζει με κανονικη εγκατασταση...
Αν δεν εχεις ξενερωσει και εχεις διαθεση για πειραματισμους, μπορεις να δοκιμασεις και κονσολάτα να συνδεθεις.
Οδηγιες για το wpa_supplicant εδω...
To μονο που εχει αλλαξει ειναι οτι πλεον το wpa_supplicant δημιουργει φακελο /etc/wpa_supplicant/ και εκει μεσα ειναι το .conf
Kαι αφου ειναι Open...
>network={
	ssid="my_ssid"
	key_mgmt=NONE
στο debian πάντως μου είχε βγάλει την παναγία το ipv6 και το έκλεισα γιατί είχε καταντήσει 56k
οπότε στείλτο μπας και
Δοκίμασα και με το wpa_supplicant αλλά τίποτα.
Δεν υπήρχε το .conf αρχείο ,το δημιούργησα και έβαλα μέσα αυτά μου με είπες.Δεν ξέρω αν χρειαζόταν κάτι άλλο.
warlock9_0 : Το απενεργοποίησα αλλά πάλι τίποτα δυστυχώς
