dvd to divx guide by trustfm + mini problems
vtsib
kalispera.
diavasa to guide tou trustfm kai eipa na ftiaksw to the wall twn pink floyd se 2 cdakia me AC3 hxo.
ta mini provlimatakia pou antimetopisa:
1)otan eftiaksa ta jobs sto VirtualDubMod kai patisa start afou teleiwse to job1 to job2 mou evgale error (multipass, nth pass) kai etsi den dimiourgithike to deftero .avi
parolafta anoiksa to prwto .avi kai paizei kanonika mia xara.
2)thelw na kopsw thn tainia se 2 cds.
anoigw pali VirtualDubmod kai apo ekei dialegw pou thelw na kopei.otan pataw save as... prepei na valw pali ta xaraktiristika pou eixa valei prin ston codec?(dhladh divx codec 5.0.5 bitrate ktl ktl).an nai tote h tainia den tha kanei na kopei osh wra ekane kai na ftiaxtei?an valw uncompressed tote vgainei kapoia GB!!!
opoios mporei as voithisei.
efxaristw
1) stis rithmiseis tou codec, anti na valeis multipass, 1st pass malon evales one pass. Den e3igite allios giati an ekanes 1o perasma, to avi den tha douleve. Etsi e3igite kai to erron sto 2o perasma, to oti den vrike to arxei log me ta statistika gia na mporesi na kanei to 2o perasma.
2) gia na kopseis tin tainia, prepei na epile3eis to 1o komati pou thes, na theseis Video/direct stream copy (diaforetika tha kanei epanasimpiesi, kati pou den thes!) kai meta save as. Meta epilegeis to deftero komati kai akolouthas tin idia diadikasia
Me kalypse sxedon plhrws o pellaras.
my 2 eurocents mono: koita pou swzeis to log file sou pou kanei generate to 1st pass. Apenergopoihse to MV file giati sthn 5.05 den doulevei kai se poly kosmo dhmiourgei provlimata molis xekinaei to 2o pass.
dini kalitera apotelesmata giati:
sto proto perasma o codec elexei tin fisi tis tainias. Poso grigori argi einai, posa bytes thelei kathe frame gia na simpiesti sosta. I diadikasi stin pragmatikotita einai poio periploki apo oti tin perigrafoume.
sto deftero perasma, o codec tha ele3ei poso diathesimo xoro exei (pou afto to rithmizeis esi me to bitrate) kai me vasi tis plirofories pou sile3e sto proto perasma, tha katanemi ta bytes dikaia. Eki pou ta frames den exoun megales aperiseis, tha fila3ei bytes na ta dosi se frames pou xriazonte perisotera. etsi ola ta frames na einai "isa3ia" diladi oxi alla me blocks kai alla perfect. I ola perfect i ola me liga blocks kai bla bla bla!!!
Epanalamvano den einai akrivos etsi pou ginete stin pragmatikotia.
Εγώ πάλι αντιμετωπίζω ένα άλλο πρόβλημα... Στο BsiLoadmakerαφού ακολούθησα όλα τα βήματα κάνω Generate standalne divx cd και στο step 2 Ο bsplayer μου βγάζει error και κλείνει, αλλα το αρχείο που μου έχει μεταφερθεί στο image/divx παίζει κανονικά χωρίς τους υπότιτλους όμως. Εχω καταλάβει κάτι λάθος μήπος? Γιατί?
oxi einai overlay error ... prepei na exeis mammia ge force karta swsta ?
akou pws 8a liseis to problhma :
1) trexe apo ton fakelo: image-divx ,to bplay.exe .
2) pata ctrl+p - video - use overlay - mode 2
3) kleise to bsplayer .
4) klikare sto loader.bsi
pes mou an doulepse .
Βρήκα τι γινόταν. Τώρα μου βγάζει τους υπότιτλους,αλλα συνειδητοποίησα πως είναι βγάζει κάτι περίεργους χαρακτήρες αντί για Ελληνικά. Τις έψαξα όλες τις γλώσσες μία μία. Σε καμία δεν έβρισκε υποτίτλους όταν έκανε scan to subrip,και σε αυτή που έκανε οι χαρακτήρες δεν καταλαβαίνονται. Καμιά ιδέα για το τι φταίει? Sorry, σας έχω πρήξει! (Δε θα το φτιάξω ποτέ αυτό το divx! Aμάν πλέον! <img src="http://www.insomnia.gr/ubbthreads/images/graemlins/mad.gif" alt="" />)
Όταν πήγα να τα βάλω (copy - paste) μου έβγαλε μήνυμα οτι υπάρχουν ήδη και πρέπει να σβήσω αυτά που υπάρχουν πρώτα για να περάσω αυτά. Υπέθεσα οτι αφού υπάρχουν δε χρειάζεται...
Λάθος υπέθεσα ε...?
