Arch και Crypto ReDi PC 200 usb TV Tuner
Nightstalker
>[sgn@Arch ~]$ yaourt -S rtl2832u-git
==> Downloading rtl2832u-git PKGBUILD from AUR...
x rtl2832u-git.install
x makefile.patch
x PKGBUILD
Comment by: R00KIE on Wed, 09 Nov 2011 14:03:33 +0000
Updated to comply with kernel modules packaging guidelines[1].
[1] http://mailman.archlinux.org/pipermail/arch-general/2011-October/022410.html
Comment by: R00KIE on Thu, 19 Jan 2012 14:21:19 +0000
Updated package to fetch the sources from another git repository because the previous sources no longer compiled under kernel 3.2, the new git repository has v.2.2.2 of the driver while the previously used repository had v.2.2.0. These sources also seem to be actively maintained.
The name of the module has changed to dvb-usb-rtl2832u (previous name was rtl2832u). This has been tested on a x86_64 system only with kernel 3.2.1-1-ARCH. I did not test if the IR receiver is working with this newer sources.
Comment by: masutu on Wed, 08 Feb 2012 22:56:05 +0000
Thanks, works great with 0ccd:00a9 TerraTec Electronic GmbH RTL2838 DVB-T COFDM Demodulator [TerraTec Cinergy T Stick Black], +1 vote!
Would you mind to rename this package to dvb-usb-rtl2832u-git (create new pkgbuild, merge request)? IMHO it would better fit (module name as you already mentioned/searchability/other PKGBUILDs like dvb-usb-rtl2832u-stv20, dvb-usb-rtl2838u-arch, dvb-usb-rtl2838u-lts).
Comment by: R00KIE on Sun, 12 Feb 2012 10:44:54 +0000
I will upload a new renamed package and ask to merge the votes and comments, but first have to check a few things about the remote control handling so I upload an updated package and instructions.
Right now I have tested if the remote control works, and it does, but the key mappings have to be hardcoded in the driver so things work automagically with the dev/input driver in lirc, this means you have to find which code corresponds to each key of the remote you want to use and then write a patch against the driver, this is cumbersome and there is probably a better way to do it.
First Submitted: Thu, 04 Aug 2011 01:27:34 +0000
rtl2832u-git 20120119-1
( Unsupported package: Potentially dangerous ! )
==> Edit PKGBUILD ? [Y/n] ("A" to abort)
==> n
==> rtl2832u-git dependencies:
- linux (already installed)
- git (already installed)
==> Edit rtl2832u-git.install ? [Y/n] ("A" to abort)
==> n
==> Continue building rtl2832u-git ? [Y/n]
==> Building and installing package
==> Determining latest git revision...
 -> Version found: 20120229
==> Making package: rtl2832u-git 20120229-1 (Wed Feb 29 17:41:05 EET 2012)
==> Checking runtime dependencies...
==> Checking buildtime dependencies...
==> Retrieving Sources...
 -> Found makefile.patch
==> Validating source files with md5sums...
   makefile.patch ... Passed
==> Extracting Sources...
==> Starting build()...
==> Connecting to GIT server....
Cloning into 'rtl2832'...
remote: Counting objects: 348, done.
remote: Compressing objects: 100% (156/156), done.
remote: Total 348 (delta 192), reused 348 (delta 192)
Receiving objects: 100% (348/348), 718.76 KiB | 639 KiB/s, done.
Resolving deltas: 100% (192/192), done.
==> GIT checkout done or server timeout
==> Starting make...
Cloning into '/tmp/yaourt-tmp-sgn/aur-rtl2832u-git/src/rtl2832-build'...
done.
patching file Makefile
make -C /lib/modules/3.2.7-1-ARCH/build SUBDIRS=/tmp/yaourt-tmp-sgn/aur-rtl2832u-git/src/rtl2832-build/RTL2832-2.2.2_kernel-3.0.0 modules
make[1]: Entering directory `/lib/modules/3.2.7-1-ARCH/build'
make[1]: *** No rule to make target `modules'.  Stop.
make[1]: Leaving directory `/lib/modules/3.2.7-1-ARCH/build'
make: *** [default] Error 2
==> ERROR: A failure occurred in build().
   Aborting...
==> ERROR: Makepkg was unable to build rtl2832u-git.
==> Restart building rtl2832u-git ? [y/N]
==> n
==> n
==> Making package: rtl2832u-git 20120229-1 (Wed Feb 29 17:41:29 EET 2012)
==> Removing existing pkg/ directory...
Already up-to-date.
==> The local files are updated.
done.
   Aborting...
τι πάει στραβά?
Συνδέστε για να σχολιάσετε
Κοινοποίηση σε άλλες σελίδες
  • Απαντ. 31
Ειναι πληρως ενημερωμενο το συστημα σου?
Βλεπω στο πρωτο σχολιο:
This seem's to be broken with 3.2.8-1 ARCH I'm getting error:
make[1]: *** [_module_/home/letku/.local/share/Trash/files/rtl2832u-git/src/rtl2832-build] Error 2
With older kernels things were fine.
