gallaki Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 χαχα ετσι, ετσι κ αλλιως εδω και 2 μερες δεν εχω κλησει αυτην την σελιδα παο το ινσομνια για να βλεπω εξελίξεις :Ρ
tr3quart1sta Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 :cry: :cry: ακριβως αυτα που ηθελα..!!! No Chasis Redesign: despite the intel ad and various mockups, the chasis remains the same unibody aluminum enclosure as existing models. Comparing the leaked specs dimensions and weight are identical to the existing MacBook Pro 13″ model. No SSD: this may come as a build to order option, but the idea of a hybrid SSD drive or straight SSD drive as standard isn’t happening No High-Resolution Screen: keeping the same screen resolution on the 13″ Pro model is what surprises me the most about this update, the MacBook Air 13″ still has a better resolution SuperDrive is Still Here: I’m not too surprised that the superdrive is still around, but I am a little disappointed. I’ve used mine twice, I’d rather have less weight and thickness than a dusty DVD drive, but then again this is a Pro machine and many Pro users need to burn and read media still
basilis222 Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 ακριβως αυτα που ηθελα..!!! No Chasis Redesign: despite the intel ad and various mockups, the chasis remains the same unibody aluminum enclosure as existing models. Comparing the leaked specs dimensions and weight are identical to the existing MacBook Pro 13″ model. No SSD: this may come as a build to order option, but the idea of a hybrid SSD drive or straight SSD drive as standard isn’t happening No High-Resolution Screen: keeping the same screen resolution on the 13″ Pro model is what surprises me the most about this update, the MacBook Air 13″ still has a better resolution SuperDrive is Still Here: I’m not too surprised that the superdrive is still around, but I am a little disappointed. I’ve used mine twice, I’d rather have less weight and thickness than a dusty DVD drive, but then again this is a Pro machine and many Pro users need to burn and read media still :shock: Δεν πιστέβω να ειναι αληθεια! (δεν νωμιζω να κανε κατ τετοιο η Apple) Αν ειναι ομως ετσι ολοι περνουμε Air!! "Τονίζουν, ωστόσο, ότι πρόκειται για σημαντική αναβάθμιση με καινοτομίες και όχι μια απλή προσθήκη χαρακτηριστικών." οτι θελει γραφει ο καθένας. Θα δουμε αυριο. ελπιζω να ειναι κατι που θα μας κανει να λιοσουμε απο την λυσα μας για να το απκτισουμε!
mentoras99 Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 Αν και δεν μας εχουν πει σιγουρα οτι το αυριονο even ειναι για mbp... τι ωρα θα γινει αυτη η περιβοητη παρουσιαση στην αμερικη? τι ωρα ελλαδας θα εχουμε τοτε?
tr3quart1sta Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 Αν και δεν μας εχουν πει σιγουρα οτι το αυριονο even ειναι για mbp... τι ωρα θα γινει αυτη η περιβοητη παρουσιαση στην αμερικη? τι ωρα ελλαδας θα εχουμε τοτε? δεν θα γινει παρουσιαση απλα θα ανανεωσουνε το online store τους... και ωρα δεν ξερουμε...
mentoras99 Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 Α, τοσο καλα... οι εικονες που διερευσαν παντως, ειναι απο το 13αρι, σωστα? για 15αρι τιποτε?
alexzzz Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 Εγώ πάλι γιατί το κόβω δύσκολο το μαύρο αφού δεν έχουν ανακοινώσει keynote. Δεν είναι απλά ένα upgrade που θα κάνουν μέσα σε ένα βράδυ αλλά μεγάλη αλλαγή. Άρα ή το 24 του μηνού είναι μούφα ή απλά θα είναι το ίδιο καλούπι με ανεβασμένα χαρακτηριστικά... λέω εγώ τώρα έπρεπε να το είχα παίξει στο στοίχημα ρε γμτ... Βετεράνος των rumors έχω γίνε
gallaki Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 παιδια και να ρωτήσω κατι, με το που τα βάλουν στο site εμείς μπορούμε να παραγγείλουμε? Η μονο στο Αμερικα θα είναι και Ελλαδα θα έρθουν πιο μετα?
basilis222 Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 παιδια και να ρωτήσω κατι, με το που τα βάλουν στο site εμείς μπορούμε να παραγγείλουμε? Η μονο στο Αμερικα θα είναι και Ελλαδα θα έρθουν πιο μετα? Εχουμε Apple Store Στην ελλαδα? μπορεις απο το Amazon. Για ελλαδα θα αργισουν.
basilis222 Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 * Solid State Driver 16GB σε κάθε μοντέλο της σειράς για γρηγορότερη εκκίνηση του Mac OS X. * Το μοντέλο των 13" θα "φοράει" έναν Intel Core i5 Sandy Bridge. * Το μοντέλο των 13" θα έχει 3 θύρες USB αντί για 2 που είχε πριν.** [Διαψεύτηκε από φωτογραφία} * Θα υπάρχει επιλογή για matte τύπου οθόνης στο κορυφαίο μοντέλο των 13 ιντσών. * Το SuperDrive θα έχει την δυαντότητα αντικατάστασης με έναν SSD στα μοντέλα 15-ιντσων και 17-ιντσων. * Βελτιωμένες οθόνες σε όλα τα μοντέλα: 1440x900 στο 13"[Διαψεύτηκε απ'ο φωτογραφία] και 1680x1050 στο 15" μοντέλο. * Λέγεται πως όλα τα μοντέλα θα είναι 200-300 γραμμάρια ελαφρύτερα. * Όλα τα μοντέλα θα έχουν μεγαλύτερη διαρκειας ζωής μπαταρία:το 13-ιντσων θα κρατάει εώς 12 ώρες και το 15 ιντσων θα κρατάει 10 ώρες σίγουρα. * Το 17ιντσων μοντέλο θα διαχειρίζεται μέχρι 8GB μνήμη RAM. * Nέα θύρα της Apple με ονομασία Thunderbolt η οποία θα χρησημοποιεί την τεχνολογία Light-Peak της Intel.[Confirmed] * Τα νέα MacBook Pro θα έχουν μία θύρα για SDXC. * Επιβαιωμένεται η φήμη για την θύρα Thunderbolt!(θα υποστηρίζει συσκευές High-Speed-E/A and MiniDisplay-Port) * FaceTime High-Definition Camera!
tr3quart1sta Δημοσ. 23 Φεβρουαρίου 2011 Δημοσ. 23 Φεβρουαρίου 2011 * Βελτιωμένες οθόνες σε όλα τα μοντέλα: 1440x900 στο 13"[Διαψεύτηκε απ'ο φωτογραφία] και 1680x1050 στο 15" μοντέλο. μαλλον θα τοχει σαν επιλογη
