Audio-Video desync σε uncompressed .avi
w4tt4n4b3
Να σε ρωτήσω όμως; Γιατί το VD έβαλε frames;
Από http://www.virtualdub.org/blog/pivot/entry.php?id=83 :
Now, one thing to be aware of with regard to the audio resampling in the capture module is that it does not guarantee zero dropped/inserted frames. Some are of the opinion that such a resampler should mean no frame aberrations, but the problem is that any timing glitches in the video stream that are not handled by frame drops or inserts must be fixed by correspondingly wonking the audio stream in speed and pitch, which can be equally noticeable. Although the video timing correction option will now try to globally change the speed of video to account for a lower or faster than expected frame rate, it will still emit drop/insert commands when it detects holes in the input.
