{TDi}Dj2k..infc Δημοσ. 6 Ιουνίου 2012 Δημοσ. 6 Ιουνίου 2012 Για το ίδιο λόγο που κλέβουν γενικά όλοι. Έλλειψη πειθαρχίας και ύπαρξη αδιαφορίας.
mchls Δημοσ. 6 Ιουνίου 2012 Δημοσ. 6 Ιουνίου 2012 Patch released for Max Payne 3 PC to address common issues The issues addressed by the latest patch are: Compatibility Issues * Fixed reported issues with needing service packs, compatibility with incorrect OS. Various Crashes * Fixed a range of issues which could have led to crashes on startup and in-game. Audio Crash * Fixed reported issues of audio dropouts when no audio device was plugged in, or when the headphones/speakers disconnected while in game. Mouse Sensitivity * Fixed reported issues of mouse being sluggish, especially in prone and Shootdodge™. Increased top end range of mouse sensitivity, but kept the slider from 1-10, allowing the user more range in their sensitivity setting. Mouse Acceleration * Fixed reported issues of mouse acceleration affecting aiming, included commandline option to disable mouse acceleration, -nomouseaccel (In a future update, this will be added as an option in the Mouse Controls menu). Stretched Image / Wrong Aspect Ratio * Fixed reported issues of game locked in incorrect aspect ratio, or alt-entering and having incorrect aspect ratio. Added commandline option for locked aspect ratio as commandline option -aspectratio width:height (ie. -aspectratio 4:3 / -aspectratio 16:9) In a future update, this will be added as an option in the Graphics menu. Video Memory Reporting as 0MB * Fixed reported issues of the video card reporting having 0MB of video memory available. Users unable to adjust Graphics options because of this (Also helps fix stuttering on some video cards)
Moderators GhostRiderLSOV Δημοσ. 6 Ιουνίου 2012 Moderators Δημοσ. 6 Ιουνίου 2012 Αχά! Για να δούμε το απόγευμα.
Moderators GhostRiderLSOV Δημοσ. 6 Ιουνίου 2012 Moderators Δημοσ. 6 Ιουνίου 2012 Πρέπει να έχει βγει ήδη.
naruto14 Δημοσ. 6 Ιουνίου 2012 Δημοσ. 6 Ιουνίου 2012 Ο θείος το έχει φέρει πάντως Οκ πάω να τον ευχαριστήσω
{TDi}Dj2k..infc Δημοσ. 6 Ιουνίου 2012 Δημοσ. 6 Ιουνίου 2012 Πάντως απορώ πως δεν το έχει αναφέρει κανεις ακόμα, αφού βγάλει το πουκάμισο δεν είναι John Mclane?!? Bruce Willis για Max Payne?!?
Vortexxx Δημοσ. 6 Ιουνίου 2012 Δημοσ. 6 Ιουνίου 2012 το αγορασα απο το steam και ακομα να βγει patch που να το κανει να τρεχει στο pc :S
kostask91 Δημοσ. 6 Ιουνίου 2012 Δημοσ. 6 Ιουνίου 2012 να κανω μια ερωτηση ? εγω το παιζω αυτες τις μερες κανονικα. και σημερα μου ειπε να κανω αυτο το update και απο εκεινη την ωρα δε μπορω να το ξαναπαιξω. μου ζηταει activation code . τι κανω ???
sakaplias100 Δημοσ. 6 Ιουνίου 2012 Δημοσ. 6 Ιουνίου 2012 παιδιά δεν διαγράφετε ένα παιχνίδι με τίποτα τα φώτα σας παρακαλώ . πατάω προσθαφέρεση προγραμμάτων κατάργηση ξεκινάει και κολλάει.το παιχνίδι εIναι το max payne 3 έκδοση reloaded
vag007 Δημοσ. 6 Ιουνίου 2012 Δημοσ. 6 Ιουνίου 2012 τοτε η περιμενεις το καινουριο crack η απεγκατασταση και ξανα εγκατασταση..
