Me8odos eureshs MAX bitrate se MAX Resolution
trustfm
Ναι, αλλά που αναφέρεται ότι </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">H timh pou mas endiaferei kai kaigomaste einai to BIT/FRAME*FRAME . To idio isxurizetai kai o idios o everwicked sto forum tou.
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">????? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
  • Απαντ. 43
edw file !!!!! http://www.everwicked.com/forums/showthread.php?s=612 28f4c7e5c44c545b07f562e251f70&threadid=260&highlight=compressibility
einai opws sta lew ama sou lewwwwwwwwww <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" />
I never believed in the compressability check...
You will find if the movie is compressible enough for good quality when you edit the logfile and end up with 4-10 quantizers or sth!
I believe that the most accurate thing is the B/P*F. It tells you enough information about a movie. And especially when you've seen the movie, you know if it is dark or not and you need to spend some more bits...
But either way, the logfile editing comes in, so it's no use...
<small>[ 11-05-2002, 03:28: Το μήνυμα επεξεργάστηκε από: trustfm ]</small>
Re paidia, entaxi ola mathimatika einai me sinartiseis paizoume, alla xrisimopoieiste kai ligo tin diaisthisi sas kai tin empeiria pou apoktate meta apo ligo kairo. Pia prospika toulaxiston xero pano kato ti paizei afou exo dei mia fora tin tainia kai den mpainos sti diadikasia euresis tou "idanikou" kadrou giati apla den tha to petixo pote an den kano toulaxiston ena pass olis tis tainias. SPania pia pefto exo me to kadro pou vazo me to mati pia...(vevaia den kaigomai kai toso poli giati panta pao gia 2 cd-otan pas gia 1 ta pragmata sfigoun)
crAss
@trustfm
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">me ton oro mpakalistika ennow akribws auto : oxi apoluta akribes .
me ton oro bit/frame φαντάζομαι ότι αναφέρεσαι στο bits/(pixel*frame).. --- nai nai
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">An theoreis oti mia methodos pou vgazei apotelesma me apoklisi +/- 1% mpakalistiki, xano to xrono mou pou sou eksigo pos douleuei.
<small>[ 11-05-2002, 14:44: Το μήνυμα επεξεργάστηκε από: philippas ]</small>
filipe to xerw bre exw psaxei kai ta exw dei oa auta alla protimw thn lush tou crass <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" />
8ewrousa oti kapws 8a uparxei tropos na breis to kadro me mia sunarthsh eite kateu8ian (xwris kan test ) eite meta to prwto pass alla ekana la8os giati apla to 0,27 einai mia timh mias tainias alla oxi olwn egw pisteua oti einai kapoio max limit alla den einai etsi.
Den to lew egw oti h me8odos pou les den einai tzami ! einai h kaluterh dunath !!! ALLA (to leei kai sto everwicked ) den einai akribeis gia ton logo oti : Comptest(RES) . Katalabes ? einai se sunarthsh me to kadro ! den to lew egw to lene ekei opote prepei na allaxeis kadra kai na kaneis diafora comptests kai na breis susxethsh ths sungkekrimenhs tainais me ta comptests !! Mia funktion tou tupo F(Comptests(i),Res(i)) .
Epishs leei o idios o everwicked oti an mporousame na broume to bit/frame auto 8a htan h teleia me8odos . To 8ema einai oti den mporeis na to bres (me ta sumerina dedomena ).
Pisteuw sto mellon na ftiaxtei programma opou estw na rixnei mia proseggish tou bit/frame. Egw pws to fantazomai ?
Meta to first pass pianei to log file kai briskei mia funtion :
H(argesskunes,grigoreskhnes)=G(bit/frame).
Twra esu 8a mou peis wrsaiaaaaaa kai auth den 8a einai analogh me to RES ? etsi pou to blepw egw kai auth 8a einai anagkastika analogh me to res ! Opote 8a mou peis eimaste sta idia e ti na kanoume h zwh sklhrh ! lol !
den exwases thn wra sou filippe dont worry <img border="0" title="" alt="[smile]" src="images/icons/smile.gif" />
kala na ste magkes !
<small>[ 11-05-2002, 18:02: Το μήνυμα επεξεργάστηκε από: trustfm ]</small>
Πρώτα απ'όλα philipe αυτο η απόκλιση του 1% μου φαίνεται υπερβολική...αν όχι τραβηγμένη από τα μαλλιά.Εντάξει το comp test είναι ένα πολύ καλό τεστ αλλά μη φτάνουμε και στο άλλο άκρο να θεωρούμε ότι ένα τεστ με αρκετούς και σοβαρούς συμβιβασμούς (compressibility..10% και αυτό πια το περίφημο όριο ότι 55-60%,που είμαι σίγουρος ότι το ανέφερε εμπειρικά κάποιο "μυαλό" του divx και μετά πολλοί το αποδέχτηκαν άκριτα,χωρίς αυτό να είναι μομφή για σένα, είναι ιδανικό για όλες τις ταινίες..γιατί αυτό μας λες οταν αναφέρεις απόκλιση 1%)..Αν πάντως έχεις κάτι περισσότερο να πεις για πως εκπορεύεται αυτή η τόσο μικρή απόκλιση, εγώ έχω μεγάλη περιέργεια να μάθω..
Eπίσης trustfm αναφέρεσαι σ' ενα post toy everwicked αρκετό παλιό που πίστευε ακράδαντα στην αποτελεσματικότητα του log editing που δυστυχώς αποδείχτηκε μούφα..
Καλό είναι ν'ακούμε τα άτομα που ξέρουν περισσότερα από εμάς ..τουλάχιστον από εμένα <img border="0" title="" alt="[smile]" src="images/icons/smile.gif" /> ,αλλά δεν πρέπει να δεχόμαστε άκριτα αυτό που λένε,γιατί ο καθένας έχει τις δικές του εμμονές και αυτό πολλές φορές οδηγεί σε λανθασμένα συμπεράσματα..αν έχεις όμως κάποιο..πρόσφατο post του που να αναφέρει κάτι τέτοιο,επίσης θα είχα περιέργεια να το διαβάσω...
<small>[ 12-05-2002, 01:25: Το μήνυμα επεξεργάστηκε από: cinefreak66 ]</small>
cinefreak den hxera oti to post auto einai palio . <img border="0" title="" alt="[Frown]" src="images/icons/frown.gif" /> twra exeis dikio se auta pou les edw koitame na lusoyme to 8ema <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" />
an exoume tipota neo as to poume . les to new gnot na ta linei auta ? h einai gordios desmos to idio to problhma ? <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" />
egw pantws bazw kadro akoma 640*xx gia 2 cds me ac3 den exw wra re gamwt gia tests . Nomiza oti 8a tan eukolo na broume toulaxiston proseggistika to kadro <img border="0" title="" alt="[Frown]" src="images/icons/frown.gif" /> . H8ela na brw mia me8odo pou na kane kai gia vidomi kai gia xmpeg kai gia oti na nai ... <img border="0" title="" alt="[Frown]" src="images/icons/frown.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">(compressibility..10% και αυτό πια το περίφημο όριο ότι 55-60%,που είμαι σίγουρος ότι το ανέφερε εμπειρικά κάποιο "μυαλό" του divx και μετά πολλοί το αποδέχτηκαν άκριτα,χωρίς αυτό να είναι μομφή για σένα, είναι ιδανικό για όλες τις ταινίες..γιατί αυτό μας λες οταν αναφέρεις απόκλιση 1%)..Αν πάντως έχεις κάτι περισσότερο να πεις για πως εκπορεύεται αυτή η τόσο μικρή απόκλιση, εγώ έχω μεγάλη περιέργεια να μάθω..
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Gia to 10% to pososto lathous an den alakseis to resolution einai 1%(an alazeis to resolution xoris na kaneis allo test to % lathous einai poli megalitero).
To mono simbibasmo pou kaneis,otan kaneis to test, einai oti theoreis oti 100% quality => quant=2. Meta einai thema diko sou na dialekseis pio pososto thes. 50-60% pou les gia emena einai ligo. Sinithos an ginetai prospatho na ftaso to 100% alla polles fores den ginetai se ikanopoitiki resolution(den pao pote kato apo 400xXXX gia 1cd) opote simbibazesai kapou endiamesa.
Το 1% του λάθους προφανώς αναφέρεται στην αξιοπιστία του comp test..αν κατάλαβα καλά (που πάλι αμφιβάλλω για το τόσο μικρό ποσοστό..που τελικά ποιος και πως το υπολόγισε?)..αλλά ας το δεχτούμε. Το ότι επιλέγεις μόνος τελικά ποιο ποσοστό είναι το ιδανικότερο πλησιάζοντας το 100% είναι για μένα και η μεγαλύτερη¨"αυθαιρεσία", αφού για κάθε ταινία δε δέχομαι ότι το ποσοστό είναι το ίδιο,δηλ για μια αρκετά σκοτεινή ταινία θεωρώ ότι και ένα ποσοστό της τάξης του 45-50% είναι καλό,ενω για μια αρκετά φωτεινή ένα καλό αποτέλεσμα μπορεί να κυμαίνεται και πάνω απο 60%..ο ιδιος είπες οτι δεν πας κάτω από καποια συγκεκριμένη resolution (για μένα το όριο αυτό είναι μεγαλύτερ )άρα επομένως και εδώ βασίζεσαι στο.."feeling" <img border="0" title="" alt="[smile]" src="images/icons/smile.gif" /> ..οπότε και πάλι ολόκληρη η μέθοδος (αν δεχτούμε ότι το compt test είναι αξιόπιστο) είναι αρκετά "ελαστική"..
Τέσπα επειδή ίσως κουράσαμε αρκετά το θέμα..απλώς κλείνω λέγοντας ότι για μένα καμιά μέθοδος δεν είναι ακόμα αρκετά αξιόπιστη (απλως όλα είναι ενδείξεις για να σε φέρουν πιο κοντά στο επιθυμητό αποτέλεσμα μη βαδίζοντας στα κουτουρού..και γι' αυτό άλλωστε το λόγο, έχουν και αξία) και το feeling και η εμπειρία παίζουν ίσως το πρωταγωνιστικό ρόλο..
Re file mperdeueis tin quality me simpiestikotita tis tainias. An mia tainia einai skoteini kai argi tha sou dosei to 100% se mikro xoro. To quant 2,3,4.. den simainei statheri BitRate!!! alla simainei staleri piotita eikonas. Elpizo na katalaveneis ti diafora.
Gia to CompTest
Exo kanei polles tainies kai meso oro peftei konta +/- 1% sto prgamatiko megethos tis 1-pass me quant=2 an dialekseis 10% test (SelectRangeEvery(130,13) sto GKnot).
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> To quant 2,3,4.. den simainei statheri BitRate!!! </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Σίγουρα δεν υποστηρίζω κάτι τέτοιο..αλλά ναι φυσικά και πιστεύω ότι το compressibility έχει σχέση με την ποιότητα..μ'αυτό δεν ήταν το θέμα μας τόσά post μακριά??.Γιατί εσύ μπορεί να έχεις τιμή καλή bits\(pixel*frame),αλλά τελικά να μη συμπιεστεί η ταινία όπως την περιμένεις..θα μας τρελάνεις τελείως <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> ..εσύ δεν είσαι και ο υπέρμαχος του comp test?Αν δεν το κάνεις για να πάρεις όσο το δυνατόν καλύτερη ποιότητα γιατί το κάνεις??..και τα quantizers παίζουν ρόλο στην ποιότητα της ταινίας..φυσικά και δεν παίζει ρόλο μόνο το bitrate. Μικρότερο quant σημαίνει καλύτερη ποιότητα..Τη σκοτεινή ταινία την αναφέρω,γιατί για μένα μπορείς να επιλέξεις υψηλή ανάλυση με χαμηλό bitrate ,χωρίς να έχεις μεγάλη απώλεια στην ποιότητα..
Όσο για το άλλο που λές.. </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Exo kanei polles tainies kai meso oro peftei konta +/- 1% sto prgamatiko megethos tis 1-pass me quant=2 an dialekseis 10% test (SelectRangeEvery(130,13) sto GKnot). </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Εγώ μέχρι τώρα ήξερα ότι και τα quants παίζουν ρόλο στο μέγεθος μιας ταινίας..και σίγουρα με σταθερό quant=2 θα έπρεπε να πάρεις πολύ μεγάλο μέγεθος..αν ήταν να πάρουμε το ίδιο μέγεθος με 1 pass και σταθερό quant=2, δεν θα υπήρχε λόγος να κάνουμε 2 pass...
Aν εννοείς όμως ότι απλώς μ'αυτόν τον τρόπο υπολογίζεις ακριβώς το μέγεθος που θέλεις, δε συνιστά ταυτόχρονα και απαραίτητα ότι έχεις καταφέρει να πετύχεις τις ιδανικές ρυθμίσεις...
Επειδή ίσως ζαλίσαμε πολύ κόσμο και επειδή με όλη την ειλικρίνεια αναφέρω ότι δεν έχω ασχοληθεί πολύ με comp test,γεγονός που ίσως με οδήγησε σε κάποιο λάθος..αναφέρω οτι θα απαντήσω πλέον μόνο μέσω pm σε ένα ενδεχόμενο ακόλουθο post (εν προκειμέων αναφέρομαι στον philippa) ..Aν πάντως και κάποιος άλλος ενδιαφέρεται να το συνεχίσουμε, εγώ δεν έχω πρόβλημα..αλλά μάλλον αν είναι υπόθεση μόνο 2 δεν έχει νόημα.Κλείνω λέγοντας ότι έχω κάνει ερώτηση για comp test στο www.everwicked.com
<small>[ 13-05-2002, 00:22: Το μήνυμα επεξεργάστηκε από: cinefreak66 ]</small>
Na sta po allios an mia tainia simpiezetai kala p.x mia skotini tainia den simainei oti prepei na pas pio kato se % quality apo alles tainies pou den simpiezontai kala.Auto eithela na toniso.
To Comp Test sou dinei to megethos mias tainias an simpiesti me stathero quant=2(100% quality).
Etsi leitourgei kai i 2-pass simpiesi. To proto pass simpiezi tin tainia me stathero quant=2 silegei tis plirofories gia tin simpiesi p.x motion, katagrafei to megethos tou video (auto ennoo me megethos tis 1-pass)
kai meta kanei scale kato gia na petixei to megethos pou thes pou to ruthmizeis me to bitRate.
Koitakse an thes kai to link edo nomizo oti ta eixa eksigisei kalitera edo: doom9>forum>divx5>Whats the best way to predict filesize with DivX 5.0 ? sto telos tis selidas.
Auto eitan kai emena to teleutaio mou minima gia auto to thema.
<small>[ 13-05-2002, 00:47: Το μήνυμα επεξεργάστηκε από: philippas ]</small>
paidia ok kai egw sumfwnw oti to 8ema exantlh8hke sigoura oxi me ton pio telio tropo alla me ton pio kalo pou uparxei twra . Apla kalw olous tous insomniacs an pote ma8oun h hdh xeroun kati panw sto 8ema h estw exoun mia idea , na mhn distasoun na poun thn apopsh tous se auto to topic !
