Project "QUIET PC" !!!
kavaliotis
Loipon exoume kai leme!
Ekana ena testaki me kleisto kai anoixto kouti gia na apodeikso kapoia pragmata se osous lene oti me anoixto kouti exoun kalutera temps! Ego pistevo oti an exeis kalo airflow mesa sto kouti, me kleisto kouti exeis kalutera temps.. Loipon exoume kai leme..Oi times einai oles FULL LOAD trexontas to UD_Agent, dhladh h CPU douleve sta 100% kai ka8e test dihrkese 30 lepta..
1. Me anoixto kouti kai overclocked sta 1667 me ola ta fans sta 7 Volts (kai ths CPU)
<img src="http://homepages.pathfinder.gr/kavaliotis/1.Anoixto_Kouti_OC_1667" alt="" />
2. Me kleisto kouti kai overclocked sta 1667 me ola ta fans sta 7 Volts (kai ths CPU)
<img src="http://homepages.pathfinder.gr/kavaliotis/2.Kleisto_Kouti_OC_1667.jpg" alt="" />
3. Me kleisto kouti kai MH overclocked sta 1533 me ola ta fans sta 7 Volts (kai ths CPU)
<img src="http://homepages.pathfinder.gr/kavaliotis/3.Kleisto_Kouti_NoOC_1533" alt="" />
To kouti einai pia entelos a8orubo mias kai to fan tou Volcano doulevei sta 7 Volts..Mallon guro stis 3.000strofes, an kai den mporo na to po me sigouria afou to motherboard den mou leei me posa doulevei..Isos to oti to doulevo sta 7 Volts mallon den to afhnei na pairnei ta readings..An kapoios kserei kati as pei..
<small>[ 24-06-2002, 19:49: Το μήνυμα επεξεργάστηκε από: kavaliotis ]</small>
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by @_zerocool:
<strong>re kavalioti mhpws ta temps einai ligo psyla gia th CPU. Koita mhn pa8eis kamia zhmia.Alla mou aresei h case temp pou exeis.
To case ayto poso to phres kai apo pou?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Eipame h ASUS deixnei 8-10 ba8mous pio polu apo kanonika! Opote ekei pou leei 62 gia thn CPU upologise oti exo 52-54! Better?!?!
Oso gia to kouti, to phra apo thn Agglia apo www.overclockers.co.uk ..Pantos an 8es na pareis kati paromoio, kalutera pare ena me alouminio..Einai polu prio elafru kai fernei kalutera case temps apo 2 eos 4 ba8mous..Einai ligo pio akriva nomizo alla otan to phra ego ta koutia alouminiou htan duseureta kai panakriba.. Oxi oti tora einai fthna, alla einai kapos f8hnotera..
Παιδιά τα πάντα είναι σχετικά με τον θόρυβο και δυστυχώς απρόβλεπτα...
Πρώτα απ' όλα τα fans γερνάνε εύκολα με 24/7 λειτουργεία και κάνουν περισσότερο θόρυβο...το αφήνουμε στην άκρη...
Έκανα και εγώ ο έρμος την αλλαγή από το WBK38 στο spire copper base...με το delta fan...μια από τα ίδια...άλλαξα λοιπόν το delta με έναν απλό 80mm με rpm reading...ξαφνικά άκουγα τους δίσκους μου! μα κάνουν θόρυβο αυτά τα αθώα πραγματάκια; Τέλος πάντων είμουνα αθόρυβος και είχα πει στον εαυτό μου ότι μόνο με Watercooling θα προσπαθούσα πάλι για υψηλά O/C μια και αφού μου αρέσει να πειραματίζομαι δεν θα ήθελα να αρχίσω να δίνω 50+ euros για HSF κάθε τόσο...
Μέχρι που μου ήρθε από εκεί που κακώς δεν το περίμενα! Έχει κανείς σας ακούσει πώς κάνουν οι GF4; Με το stardard cooler η Creative μου καλύπτει όλους τους άλλους θορύβους...έλεος πια...πρέπει να πάρω και waterblock για την GF δλδ;
Τα μονωτικά είναι πεταμένα λεφτά για εμένα...αν προσθέσεις το κόστος τους σε ένα μεγάλο Cooler --π.χ. ένα Volcano 7 και Dynamat σίγουρα κοστίζει όσο ένα Alpha 8045 ή κάτι τέτοιο --που με πολύ πιο αθόρυβους ανεμιστήρες θα κάνει την ίδια ή και καλύτερη δουλειά.
Watercooling σε θέλω...
Imagine
