F.E.A.R. 2: Project Origin
privateer
  • Απαντ. 292
Fear 2: Project Origin - Better textures, effects and resolution on PC?
The developers wanted to spice up Project Origin with more action but didn't want to cut back on the scary moments. John O'Roke, Leading Software Engineer at Monolith, tells us what has changed in matters of graphics and technology.
Monolith is currently developing Fear 2: Project Origin, the anxiously awaited successor of Fear. PC Games Hardware interviewed John O'Roke, Leading Software Engineer at Monolith, about how the developers have upgraded the Lithtech Engine to modern standards. Besides the technical details he also mentioned that the PC has the capabilities to deal with high resolution textures and higher quality graphics effects. Fear 2: Project Origin is supposed to hit the markets on 10th February...
F.E.A.R. 2 System Requirements Revealed
Do you have what it takes?
by Jimmy Thang
January 12, 2009 - By way of F.E.A.R. 2's French web site, developer Monolith has revealed the system requirements for its highly-anticipated first-person shooter. Posted below are the minimum and recommended hardware requirements for F.E.A.R. 2: Project Origin:
Minimum System Requirements:
*CPU: P4 2.8GHz (3.2GHz Vista)/Athlon 64 3000+ (3200+ Vista)
*GPU: DX9-capable graphics card with 256MB (SM 2.0b). NVidia 6800 or ATI X700.
*RAM: 1GB (1.5GB Vista)
*Hard Drive: 12GB
*OS: Windows XP SP2/Vista SP1
*DirectX: 9.0c
*Sound: DX9.0c compliant
*Optical drive: DVD (boxed only)
*Internet: Broadband
Recommended System Requirements:
*CPU: Core 2 Duo 2.2GHz processor family/Athlon 64 X2 4400+ (required for MP host)
*GPU: Fully DX9-compliant graphics card with 512MB (SM 3.0). NVidia 8600 GTS or ATI HD 2900 XT.
*Ram: 1.5GB
*Hard Drive: 12GB
*OS: Windows XP SP3/Vista SP1
*DirectX: 9.0c
*Internet: Broadband (768kbit/sec upstream required to host 16 players)
You can test your gaming rig out on F.E.A.R. 2 when it releases this February.
απο το ign.com...μικρές οι απαιτήσεις θεωρώ για τα σημερινά standards..
Λετε να εχω προβλημα με την 295 GTX που εχω? Θα αυτοκτονησω εαν δεν παιξω 1920χ1200 με χ8ΑΑ και χ16ΑF , full 60 fps οπως παιζω ολα τα αλλα εκτος απο crysis ....
ουδέν σχόλιο...
τι??δε παίζεις crysis στο full!!!σε κοροιδέψανε!!!:lol:...εγώ θα αυτοκτονήσω με αυτά που γράφετε ορισμένοι....:-D
Καλυτερα μια ακομα για SLI να εισαι σιγουρος.
Το παιχνιδι παντως ειναι κορυφη. Ακομα δεν εχω παιξει τα expansions του πρωτου ομως... damn
ντροπή σου:P...ξεκίνα τώρα να παίζεις και θα προλάβεις για το νέο μόλις βγει
Εγω θα μπορω να το παιξω με ολα φουλ σε 1280χ1024 με 4xaa και 8 χaf??
Ετοιμάσου για για γενναίους συμβιβασμούς στα γραφικά
Εγώ πάντως λέω ότι το game θα phail από άποψη horror...το κόβω να το κάνανε ένα απλό fps και τα graphs δεν φαίνονται ιδιαιτερα καλύτερα από τα προηγούμενα. Το πρώτο ήταν epic.
Επίσης αυτό περί απαιτήσεων που ρωτάτε, δηλαδή πως μπορούμε να ξέρουμε? Από όσο ξέρω δεν δουλεύει κανεις σε καμια εταιρία η κάνω λάθος?
