Case Cooling
yositosi
  • Απαντ. 36
edw exei perissoteres plirofories wink.gif" border="0 <A HREF="http://www.anandtech.com/showdoc.html?i=1532&p=5" TARGET=_blank>http://www.anandtech.com/showdoc.html?i=1532&p=5</A> <P><BR>pantos sto taisol eixa valei gia ena diastima (kai etsi einai akoma alla sto pc tis aderfis mou) 2 60mm ystech plai-plai...polu kali psiksi alla kai o Taisol me to xalko apo katw einai wraio HS...otan vazeis 2 fans plai plai den uparxei "tuflo" simeio aera panw akrivws apto cpu ...otan einai mono ena to fan fusaei sto etsi /.\ kai i telia pou einai to kentro den xtipietai apo aera...me duo fans exeis to eksis /\./\ opou i telia exei arketo aera kai genika anevenei to airflow me 2 fans wink.gif" border="0 kai as eksexoun ligo aptis akres....
Pantws akoma kai me ena overclocking sta 1.5Ghz tha xtipietai sta isia me enan XP1800+ kai tha pataei ton P4 2Ghz (twra kai eimaste sxedon sta idia). Opote leei agria mias kai to cpu mou tha kratisei poli perissotero kairo apo oti pisteua!
Akrivws... akoma kai dio coolers na valeis se auti tin diataksi me mikrotero total CFM apo enan delta, pali tha katafereis xamilotera temperatures logw tis apeutheias psiksis tou simiou epafis tou core me to heatsink. Mia alli enallagi pou exw dei se auto einai na valeis to ena fan na rixnei aera kai to allo na travaei kai sigxronws na peraseis monotiki tainia girw apo to heatsink... etsi dimiourgeis air-flow mesa sto heatsink pagwnontas to cpu
<BLOCKQUOTE><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><HR>Originally posted by yositosi:<BR><STRONG> Mia alli enallagi pou exw dei se auto einai na valeis to ena fan na rixnei aera kai to allo na travaei kai sigxronws na peraseis monotiki tainia girw apo to heatsink... etsi dimiourgeis air-flow mesa sto heatsink pagwnontas to cpu</STRONG><HR></BLOCKQUOTE><P>ginetai kai auto apla den einai toso apotelesmatiko ...giati apla o enas anemistiras voithaei ton allo - me to na tous prosferei aera - na girizei pio grigora (meiwsi tis piesis - diladi o aeras pou ftanei sto 2o fan einai idi epitagxumenos) me apotelesma na anevenei to airflow...einai sxedon to idio me to na valeis ena dunatotero fan (anti gia duo pio irema) kai na roufaei apto HS exontas valei kai tainia wste na einai pio "sugkentrwmeno" to roufigma smile.gif" border="0 (akou ti leme grin.gif" border="0)
Kala file Tonymontana den eipa oti auti i diataksi einai pio apotelesmatiki... giati apla den kserw. Pantws to Cooler V8 me ta dio fans vgike psilomoufa apo oti eida se reviews!
Φίλε yosi,<BR>Μην κάνεις καμία επέμβαση στο PC Case σου αν δεν έχεις απομακρίνει όχι μόνο το MoBo και τις κάρτες σου, αλλά και όλα τα drive ΚΑΙ ΚΥΡΙΩΣ ΤΟ PSU!!!<P>Δεν φαντάζεσαι τον αριθμό των μεταλλικών ρυνισμάτων και σωματιδίων που παράγονται κατά το τρύπημα της λαμαρίνας και ακόμα χειρότερα κατά το πριόνισμα με ηλεκτρικά και μη εργαλεία...όλα αυτά τα σκουπιδάκια είναι ΗΛΕΚΤΡΙΚΑ ΑΓΩΓΙΜΑ και άρα απειλούν όλα τα περιφεριακά που είναι μέσα στο case και λειτουργούν με ρεύμα!!! Κινδυνεύεις από το να μπουν μέσα στο PSU και να το κάψουν ίσως μαζί με το ΜοΒο, μέσα στο CPU socket, στις θύρες AGP - PCI...παντού!!! Τα τσουμπλέκια του PC τα αφαιρείς ΟΛΑ για να συνεχίσεις με τις βάρβαρες διαθέσεις σου.<P>Προσόχή!!! Οι ακμές τις λαμαρίνας μετά από κάθε κόψιμο - τρύπημα είναι πολύ κοφτερές και μαγνητίζουν δάκτυλα και παλάμες σαν τρελές για σαδιστικά κολπάκια..λιμάρισέ τες πριν σου "λιμάρουν" το δάκτυλο - ή ακόμα χειρότερα το PCB του MoBο ή κάποιας κάρτας που μετά δεν θα φτιάχνει με χάνζαπλαστ!!!<P>Στην συνέχεια το κουτί θέλει προσεκτικό καθάρισμα με νοτισμένο πανί (εκεί να δεις μαυρίλα από σωματίδια που λέμε + σκόνη βέβαια wink.gif" border="0), και αν γίνεται πριν από αυτό καλό φύσιμα με κάποιο κομπρεσεράκι...όχι με σπρέι πεπιεσμένου αέρα όμως γιατί είναι ακριβό!!!<P>Μετά θα βάλεις τα κομμάτια του PC πάλι μέσα για να έχεις το κεφάλι σου ήσυχο...<P>Το 2ο fan κάτω από το τροφοδοτικό και πάνω από το CPU θα έχει πολύ καλά αποτελέσματα αφού θα μεταφέρει την ροή του αέρα σχεδόν όλη κοντά στο CPU και άρα θα τον ψήχει καλύτερα...προσοχή όμως...η τοποθέτηση και 2ου fan στην περιοχή, στο πίσω μέρος του κουτιού δηλαδή που επίσης θα βγάζει αέρα με ροή όμως που σχηματίζει 90 μοίρες γωνία σε σχέση με το επιπλέον fan του PSU μπορεί να έχει αντίθετα αποτελέσματα αφού τα 2 fan σε ένα μικρό/μεγάλο βαθμό (που αυξάνει όσο μικρότερη είναι η απόσταση μεταξύ τους) θα αγωνίζονται το ένα ενάντια στο άλλο. <P>Καλό είναι το fan στο πίσω μέρος του κουτιού να είναι ΕΙΣΑΓΩΓΗ και με μία κατασκευή από χαρτόνι και κολλητική ταινία να σχηματίζες μία μούφα στην διάμετρο του fan και με απόληξη τέτοια ώστε να οδηγείς τον αέρα αποκλειστικά στο fan του CPU cooler. Το 2ο fan του PSU θα είναι ΕΞΑΓΩΓΗ (έμμεσα - με ενδιάμεσο το θάλαμο του PSU) και θα απομακρύνει τον ζεστό αέρα του CPU cooler που όμως τώρα θα τροφοδοτείτε απευθείας από το περιβάλλον και όχι από ένα ήδη θερμότερο του περιβάλλοντος κουτίου. <P>Καλό θα ήταν να μπει και μία 2η εισαγωγή αέρα για την ψήξη του κουτιού γενικότερα, αφού η 1η θα είναι μόνο για το CPU λόγω μούφας. Αν η μούφα δεν υπάρχει, τα 2 fan που θα προσθέσεις ( 2o PSU σαν εξαγωγή & το πίσω σαν εισαγωγή) θα δημιουργήσουν κλειστό κύκλωμα, και ο αέρας δεν θα προλάβει να μπει στο κουτί και θα βγαίνει πάλι χωρίς να ψήχει τίποτα.<P><BR>Γενικά να φροντίζεις το σύνολο των fans που βάζουν να είναι ίδιο-περίπου ίδιο σε ισχύ με αυτό των fans που βγάζουν...δηλαδή αν έχεις 3 80άρια για εξαγωγή και 1 80άρι εισαγωγή δεν κάνεις τίποτα...η αναλογίες σε μέσους όρους πρέπει να είναι ίσες.<P>Ισχύει χονδρικά ότι 3 60x60 = 2 80x80 ή και 2 60x60 = 1 80x80. 1 120x120 = 3 80x80. Tα 92άρια είναι ισχυρότερα από τα 80άρια αρκετά άλλά όχι και σαν 120άρια...πάντα μιλάμε για απλά fans του εμπορίου, Sunon π.χ. ή και Panaflo (αθόριβα - panasonic) και όχι black abel Delta κτλ...<P>Fans καλό είναι να ψάξεις να βρεις στο εμπόριο ηλεκτρονικών ειδών και όχι στα "επώνυμα" κομπιουτεράδικα αφού οι τιμές είναι στο 1/2 ή και στο 1/3 από αυτά και οι επιδώσεις μπορεί και ανώτερες...δυστυχώς delta fans δεν νομίζω να φέρνει κανείς άλλος πέρα από checkmate στην Ελλάδα... frown.gif" border="0<P>Υπάρχουν και fans με 3ο καλώδιο για rpm monitoring αλλά δεν είναι απαραίτητο κατά την γνώμη μου. Τα Sunon είναι εξαιρετικά, και ας μην έχουν. <P>Για αθόρυβα fans, απλά ρίχνεις το voltage των φασαριόζικων...άλλωστα τα αθόρυβα είναι στην ουσία (πέρα από sleeve αντί για ball bearing) με "κομμένα γκάζια" και άρα χαμηλές επιδόσεις. Θόρυβο προκαλούν οι υψηλές στροφές και το άγριο βήμα των πτερυγίων. Όσο μεγαλύτερης διαμέτρου είναι η πτέρυγα, τόσο πιο μικρό βήμα χρειάζεται ώστε να σπρώχνει τον ίδιο αέρα ή/και στροφές. Έτσι ένα 80άρι fan στις 3000rpm είναι πιο αποτελεσματικό και πιο αθόρυβο από το άγριου βήματος delta 60x60 7000rpm!<P>**Το βήμα μετριέται σε μήκος (ίντσες: 1in ή 1" = 2,54cm) και αν βανταστείς την έλικα σαν βίδα του αέρα, είναι η θεωρητική απόσταση που θα προχωρίσει σε μία πλήρη περιστροφή.<P>Πτώση τάσης μπορείς να δημιουργήσεις αν βάλεις σε σειρά μία μικρή αντίσταση ή ένα ποντεσιόμετρο (μεταβλητή αντίσταση) σε συνδεσμολογία ροοστάτη. Ανοίχτε και κάνα βιβλίο 3ης ληκείου - ηλεκτρισμό!!! Τα απλά είναι εκεί και θα σας βοηθήσουν.<P>Αν θέλετε περισσότερα στείλτε κάνα prv message και να τα γράψουμε συγκεντωμένα κάπου να πηγαίνεται να τα βλέπετε...γαμ*** τα hardware sites μου μέσα!!!<P>Imagine wink.gif" border="0<P>P.S. Φίλε μου timinman, καλή προσπάθεια, αλλά οι τρυπούλες δίπλα στα drive, sorry δηλαδή, αλλά είναι δυνατόν να κάνουν δουλειά;;; Αμ όχι τίποτε άλλο, σκέψου ότι η θερμότητα ανεβαίνει...δεν πάει με τις πάντες...βάλε ένα cooler ομοιοτρόπως με τα πλαϊνά στο πάνω μέρους του case και...θα δεις.
File pyro einai diskolo na vreis Delta... episis egw pou ton exw paei na me trelanei. Oi logoi polloi... prwton kanei TROMAKTIKO thorivo... episis dimiourgei trelous kradasmous opote an to case sou den einai epwnimo kai gerodemeno (atsali kata kirio logw) oi trantagmoi sigxronizontai kai to pc miazei se leitourgia ena trakter!!! Pantws simera perasa to WBK68 (poli athorivo) kai oi thermokrasies einai pali poli xamiles (kai an mou tin varesei pernaw pali to Delta kai to WBK68 ginetai to thirio WBK38 wink.gif" border="0 ).<BR>Telos, to Volcano exei kales metriseis alla to vriskw tromaktika thorivwdes kai na ksereis oti sketo copper heatsink den dikaiologei tin timi tou.. enw apo pleuras epidosewn pio kala einai ta heatsinks me "copper" contact surface kai "aluminum alloy" tis fetes tis psiktras!
thanks file Imagine. Vasika gia ta rinismata dne to eixa skeftei katholou kai exeis apolito dikio. Gia to deutero PSU fan tha to valw outws i allos na travaei aera APO to cpu. Episis mallon exeis dikio sto oti me to na prosthesw kai ena eisagwgis xwris tube tha exw aplws megali alla mi apotelesmatiki roi. Mallon me vlepw na petaw apla ena fan pou na eksagei apo pisw ton zesto aera pou vgazei to fan tou cpu kai na prosthetw ena akoma fan stin prosopsi! Thanks wink.gif" border="0
File tonymontana sto Athlon OC wet dream vrika ta steppings kai leei oti to CPU mou paei mexri 1.65Ghz kai prepei na exei dikio giati ton diko sou ton exei mexri 1.55Ghz kai esi kataferes na piaseis ta 1.5Ghz. Opote pisteuw oti dikaioume na aisiodoksw oti tha kataferw na piasw toulaxiston to 1.6Ghz!
mporei na ta piaseis alla se tetia overclock mpainoun sti mesi ki alloi paragontes opos ipsila Vcore kai ara anagki apo kalo PSU kathws kai ipsiles thermokrasies...den exeis para na dokimaseis...gia na tsekareis to overclock sou trekse to Prime95 torture test gia kana 24wro kai an den stamatisei (na ginei apo kokkino => kitrino) tote eisai ok wink.gif" border="0<BR> <A HREF="http://www.mersenne.org/freesoft.htm" TARGET=_blank>http://www.mersenne.org/freesoft.htm</A>
Erwtisi tonymontana: To sistima sou douleuei me PSU 300Watt i tha tou epefte poli ligo???<BR>Episis kserei kanenas pou tha vroume to mobo tis MSI me to KT266A stin thessaloniki?? A nai, se ti timi?? Thanks wink.gif" border="0
<BLOCKQUOTE><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><HR>Originally posted by yositosi:<BR><STRONG>Erwtisi tonymontana: To sistima sou douleuei me PSU 300Watt i tha tou epefte poli ligo???<BR>Episis kserei kanenas pou tha vroume to mobo tis MSI me to KT266A stin thessaloniki?? A nai, se ti timi?? Thanks wink.gif" border="0</STRONG><HR></BLOCKQUOTE><P>tha douleue me to 300ari tis sparkle...kai me allo analogo...
