SATELLITE2SATELLITE Δημοσ. 8 Ιουνίου 2001 Δημοσ. 8 Ιουνίου 2001 SORRY ΦΙΛΕ ΔΕΝ ΚΑΤΑΛΑΒΑ. ΠΑΙΔΙΑ, ΟΠΟΙΟΣ ΕΧΕΙ ASUS ΑΣ ΜΑΣ ΠΕΙ ΠΟΙΟ ΕΙΝΑΙ ΤΟ DAE ΠΟΥ ΦΤΑΝΕΙ ΚΑΙ ΑΝ ΕΙΝΑΙ ΔΥΝΑΤΟΝ ΜΕ ΠΟΙΟ ΠΡΟΓΡΑΜΜΑ RIPPING Ή RECORDING.<p>[ 07-06-2001: Message edited by: SATELLITE2SATELLITE ]
SATELLITE2SATELLITE Δημοσ. 9 Ιουνίου 2001 Δημοσ. 9 Ιουνίου 2001 <A HREF="http://users.pandora.be/erik.deppe/information.htm" TARGET=_blank>http://users.pandora.be/erik.deppe/information.htm</A> <P>ΣΤΟ URL ΠΑΡΑΠΑΝΩ ΥΠΑΡΧΟΥΝ ΜΕΡΙΚΑ ΣΧΟΛΙΑ ΑΚΡΩΣ ΕΝΔΙΑΦΕΡΟΝΤΑ. Ο ΧΡΗΣΤΗΣ ΠΟΥ ΕΓΡΑΨΕ ΤΟ URL ΑΝΑΦΕΡΕΙ ΣΤΟ ΚΕΙΜΕΝΟ ΟΤΙ ΕΧΕΙ PLEXTOR DRIVES (ΑΡΑ ΠΑΝΩ ΑΠΟ ΔΥΟ DRIVES PLEXTOR).<P>ΕΠΙΣΗΣ ΛΕΕΙ<P>Asus CD-S400, CD-S500: The default DAE speed is set to 8x average but it can be set to 20x.<BR>The 40x uses P-CAV mode at this speed while the 50x uses CAV mode.<BR>The 50x is slightly faster because it reaches almost 24x near the end of a disc while the 40x never exceeds 20x.<P>Update (6/5/2000): With firmware 1.10 the default DAE speed of the Asus CD-S500 is 20x, the maximum DAE speed is 16-36x!!!<BR>The firmware of this drive is NOT upgradable!<P>You can use CD Speed 99 to change the speed or a utility from the Asus website called Asus CD-ROM Speed Setting Utility. This program does not only work with Asus drives but with all MMC compliant drives (most Atapi drives and recorders).<BR>You can download this utility on <A HREF="http://www.asus.com.tw." TARGET=_blank>http://www.asus.com.tw.</A> It has the very original name cdspeed.exe <P>Notes:<BR>1) I had a problem using this program together with my SCSI Plextor drives. At startup it gave a bus reset with each SCSI drive so it's not totally bugfree.<BR>2) After the speed is set, you will get a message box telling you the actual reading speed. So if you select 50x when an audio CD is inserted, the program will tell you the drive is set to 20x.<P> <P>ΤΑ ΣΥΜΠΕΡΑΣΜΑΤΑ ΔΙΚΑ ΣΑΣ.
