anthony_crete Δημοσ. 26 Αυγούστου 2006 Μέλος Δημοσ. 26 Αυγούστου 2006 ok re man,me lan to vazw!! dokimasa kai to corrupted image alla xwris ip 10.1.1.5 klp.. katse na dw!! PS: to rwssiko evala!
raven3x7 Δημοσ. 26 Αυγούστου 2006 Δημοσ. 26 Αυγούστου 2006 sto rwsiko einai 192.168.1.1 an thymamai kala
anthony_crete Δημοσ. 26 Αυγούστου 2006 Μέλος Δημοσ. 26 Αυγούστου 2006 leei to exhs: FTP TimeoutThe devices ip adress is 192.168.1.199 Please change your machine's ip for the same subnet and then re-running this utility
raven3x7 Δημοσ. 26 Αυγούστου 2006 Δημοσ. 26 Αυγούστου 2006 Opou leei 10.1.1.1 esy to kaneis 192.168.1.1. opoy leei 10.1.1.99 esy to kaneis 192.168.1.199 f your modem/router is not responding after changing some settings in it or after unsuccessful firmware upgrade, please try the below steps. Download the latest Firmware for your modem/router. Choose the EXE version of firmware as opposed to WEB (.BIN) version. The steps after Step 6 are only applicable to EXE version of firmware. Step 1. Try resetting the router to factory defaults by pressing the Reset button at the back of the router for 10 seconds. The router' power should be on when you are pressing the button. Step 2. Set your computer with static IP address. To do that go to Start > [settings] > Control Panel > [Network and Internet Connection] > Network Connections > Local Area Connection > Properties. Select Internet Protocol (TCP/IP) and click on the Properties button. Specify the following settings: IP address: 10.1.1.99 Subnet Mask: 255.0.0.0 Default Gateway: 10.1.1.1 Preferred DNS: 10.1.1.1 Alternate DNS: 4.2.2.2 DNS server addresses can be replaced with your ISP's DNS addresses. Step 3. Temporarily disable firewall and antivirus protection on your computer. To disable WindowsXP built-in firewall go to Start > Control Panel > [Network and Internet Connection] > Network Connections > Local Area Connection > Properties > Advanced > Settings. Set Firewall to OFF. If you have some other firewall and antivirus software installed, please refer to the software manuals on how to disable it. Step 4. Make sure that the router is on. Connect one end of the Ethernet cable (blue network cable) to your router and another end to your hub/switch. Your computer should also be connected to the hub/switch. If you do not have a hub/switch, connect the other end of the cable directly to your computer's network adapter. Step 5. Click on Start > Run and type 'cmd'. Click OK. In the blck DOS prompt type the following commands finishing each one with Enter: arp 10.1.1.1 -d arp 10.1.1.1 -d arp 10.1.1.1 -d ping 10.1.1.1 -t You may see messages like 'Entry was not found', it is normal. You should see repeated message 'Request timed out'. If you are seeing 'Reply from 10.1.1.1', your router is already responding. Step 6. Launch the Firmware Upgrade Utility (the EXE version of the firmware) by double-clicking on it. When firmware upgrade window pops up, select the 'Corrupted Image Mode' option and click Next. You will be prompted to disconnect power from your modem/router. Disconnect the power cable from your modem router and after about 10 seconds click Next. You will be prompted to connect power back to your modem/router. Connect the power cable to the modem/router within 10 seconds. Firmware upload will proceed automatically after that. Click on the Finish button to complete the upload. Your DOS window should now be displaying continuous messages 'Reply from 10.1.1.1'. Step 7. Repeat Step 5. Then try to log into your router via http://10.1.1.1. You will be prompted to enter username and password. Username: admin, password: admin. You can now configure your router for your Internet connection under Home > WAN. Once finished with the settings, click on Apply and then save the settings into the router's memory under Tools > [system] > Save & Reboot. Troubleshooting If during firmware upload procedure you got a message 'FTP Timeout. The device IP address is 192.168.12.199' (address may vary). Close the firmware update utility. Disconnect power from your modem/router. Set your computer with a different IP address as suggested in the message (in this example it is 192.168.12.199. Then repeat the above procedure starting from Step 4. After finishing uploading firmware (before Step 7), change your computer's IP address back to 'Obtain an IP address automatically'. After loading firmware the modem/router's IP address will be 10.1.1.1.
raven3x7 Δημοσ. 26 Αυγούστου 2006 Δημοσ. 26 Αυγούστου 2006 An thes na sou steilw kai to rwsiko manual se pdf(einai starwsika allaexei eikones giakapoia apo ta shmeia PM me.
navar Δημοσ. 26 Αυγούστου 2006 Δημοσ. 26 Αυγούστου 2006 tha rpoteina na valeis sto pc sou aytomates ths rythmiseis gia diktyo kai meta na vgeis se dos kai na grapseis ipconfig /release meta tha sou vgelei ola 0.0.0.0 kai meta ipconfig /renew etsi wste na pareis mia symvath ip me to router apo to DHCP tou router ..meta apo ayto apla kaleseto kai desto...analoga me to firmware pou evales i sthn 10.0.0.1 h sthn 192.168.1.1
raven3x7 Δημοσ. 26 Αυγούστου 2006 Δημοσ. 26 Αυγούστου 2006 grapse lathos. bale statiko ip 192.168.1.2 kai dokimase device ip sto programma 192.168.1.199
anthony_crete Δημοσ. 26 Αυγούστου 2006 Μέλος Δημοσ. 26 Αυγούστου 2006 den einai dinati i epoikoinwnia me ton diakomisti dhcp... dn xerw re gmt!!! Oute me to allo p egrapse o raven3x7 egine tpt!!!! Pali ta idia m evgaze to utility....Dn xerw re gmt ti na kanw.....
raven3x7 Δημοσ. 26 Αυγούστου 2006 Δημοσ. 26 Αυγούστου 2006 bale statiko ip 192.168.1.2 kai dokimase device ip sto programma 192.168.1.199
raven3x7 Δημοσ. 26 Αυγούστου 2006 Δημοσ. 26 Αυγούστου 2006 dokimase diaforetika statika ip mexri na piasei
anthony_crete Δημοσ. 26 Αυγούστου 2006 Μέλος Δημοσ. 26 Αυγούστου 2006 bale statiko ip 192.168.1.2 kai dokimase device ip sto programma 192.168.1.199 diladi xoris corrupted image??
anthony_crete Δημοσ. 28 Αυγούστου 2006 Μέλος Δημοσ. 28 Αυγούστου 2006 loipon paides epitelous to eftiaxa!! twra niw8w anakoufisi afou apo ta 30kbps i taxitita mou 10plasiastike!![oson gia to adsl2 me ton ote...peera vrexei] loipon ti ekana: 1)Vazoume mia statiki IP [192.168.1.2] 2)Fernoume dipla mas to router 3)Trexoume to exe,vazoume device ip 192.168.1.119 password to pass mas [default:admin], tik [ν] sto corrupted image kai kanoume oti mas leei 5)Ean den ginei to xanatrexoume kai kanoume oti mas leei 6)Ean den ginei to xanatrexoume kai kanoume oti mas leei 7)Ean den ginei to xanatrexoume kai kanoume oti mas leei 8)Ean den ginei to xanatrexoume kai kanoume oti mas leei 9) Serfaroumeeeeeeeeeeeeeeeeeeeee :D
