problem with dvd
stratukos
Den ksero pou boreis na to vreis.Ekana ki ego ena psaksimo ,alla den vrika kati to ikanopoiitiko.Pantos ego tin tainia pou anafereis tin ekana rip kanonika,hrisimopoiontas prota to Anydvd kai meta to decrypter.Ligo dyskolo na ehei autin tin prostasia pantos giati oute k'ego tha borousa na tin diavaso.To dvd-rw pou eheis sigoura den ehei provlima afou diavazei kanonika k'alla diskakia.Mistiria pragmata!Tha ksanaparo tin tainia gia na to tsekaro pali kai ta ksanaleme
Πρώτα αναγνώρισε το κλείδωμα ( ποίο είναι SSC...)και θα σου απαντήσω με τι τα αντιγράφεις.
δοκιμασε να βρης το πιο κάτω:
Aplus DVD Copy is professional DVD clone tool for burn your favorite DVD movies to DVD-R(W) and DVD+R(W) Disc remaining original quality. so, it is time for you keep you original DVDs in safe. it is simply and easy way to copy a DVD Movies by yourself, just need three step! insert your source DVD movies and destination blank DVD disc then press start . and everything will happen automatically!. Aplus DVD Copy support clone DVD movies even it is protected such as CSS(Content Scrambling System), region, Macrovision or SONY ARCCOS protected DVD movies.
Key Features:
- It just takes less 1/5 of playback time to Clone a DVD Disc.
- Backup DVD movies onto your hard disk.
- Burn DVD movies to DVD-R(W) and DVD+R(W) Disc
- Support copy DVD-5/DVD-9 type DVD movies to DVD-9(Dual Layer) disc
- Support compress DVD-5/DVD-9 type DVD movies to DVD-5 disc
use latest industry standards compression technology to ensure the DVD disc you create with best quality
- Automatically prepares blank DVD for recording.
- Support clone CSS(Content Scrambling System) protected DVD movies
- Support clone region protected DVD movies
- Support clone Macrovision Protected DVD movies
- Support clone SONY ARCCOS protected DVD movies
Μάλλον αυτό το ARCCOS είναι το δικό σου.......
Το προβλημα ειναι οτι η συσκευη δεν αναγνωριζει καθολου το δισκο. Σαν να μην εβαλα τιποτα μεσα στο drive.Οποτε δεν μπορω να ξερω τι ακριβως κλειδωμα εχει. Και για αρχη δεν προσπαθω να την ξεκλειδωσω, αφου ειναι παρανομο, αλλα να την παιξει το dvd player του pc.Αν ηταν το Arccos θα ηταν παιχνιδακι αλλωστε!!!
K'ego auto tha elega.Pigaine stis idiotites tou dvd-rw,pata to tab pou leei"Yliko"meta tsekare ti monada dvd-rw pou eheis kai pata idiotites ksana.Ekei pou leei "periohi Dvd"tha deis se pio region einai kleidomeni i siskevi
Ean den to eheis allaksei polles fores tote tha eheis toulahiston mia eukairia akomi na allakseis to region se periohi 2.Ean ehei ginei allagi pano apo 5 fores tote i siskevi mallon ehei kleidothei.Elpizo na min einai kati tetoio pantos
Το dvd-r εχει ακομα 4 ευκαιριες γαια να αλλαξω το region,αφου δεν το εχω πειραξει ποτε. Το προβλημα λυθηκε αφου η συσκευη μου δεν μπορει να το διαβασει.Το πηγα σε ενα φιλο που εχει... liteon (!!!) και το διαβασε κανονικοτατ. Και το πιο περιεργο ειναι οτι δεν ειχε κανενα προβλημα στο ξεκλειδωμα αφου δεν ειχε προστασια.Μονο με το dvd decrypter στην αρχη και με το clone dvd στη συνεχεια καταφερα να το αντιγραψω.Ευχαριστω ολους οσους απαντησαν και μπορεσαν με τον τροπο τους να βοηθησουν.
Το προβλημα τελικα ειναι στη συσκευη. Κατι συμβαινει με το nec 3550a και δυσκολευεται να διαβασει καποια dvd και μερικα δεν τα διαβαζει καθολου. Λετε να εχω ιο
