SUSE 10 Problems
eddiefullmetal
to kinternet mou bgazei ta exis
SuSE Meta pppd (smpppd-ifcfg), Version 1.59 on linux.
Status is: disconnected
trying to connect to smpppd
connect to smpppd
Interface is eth0.
Status is: lurking
pppd[0]: Plugin rp-pppoe.so loaded.
pppd[0]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.3
pppd[0]: Plugin passwordfd.so loaded.
pppd[0]: Renamed interface ppp0 to dsl0
pppd[0]: Using interface dsl0
Status is: lurking
pppd[0]: Couldn't increase MTU to 1500
pppd[0]: Couldn't increase MRU to 1500
pppd[0]: replacing old default route to eth0 [192.168.1.1]
pppd[0]: local IP address 192.168.99.1
pppd[0]: remote IP address 192.168.99.99
pppd[0]: Starting link
Establishing connection due to activity.
Status is: connecting
kai h sindesi apo windows paizei kanonika
επρεπε να συνεχιζει σε κατι σαν
conect: dslo < -- > eth0
trying to conect to smpppd
conect to smpppd
Pap authntication succeedes
Local ip changed to ........
remote ip address .....
kai loipa
to smpppd apo ta services trexei ???
Lipon paides problem solved sas euxaristw para poli olous gia to endiaferon kai tis simboules pou mou dwsate
oi rithmiseis pou paizoun gia tin dsl einai opws akribos eipe o gmouzo dlh dial on demand ,aytomatically retrieve dns
kai sto ip details dynamic ip address kai default route epilegmena
Sto resolv.conf gia ote exo aytoys toys
nameserver 195.170.2.1, 195.170.0.2
me ti moni diafora oti sto dns xrisimopoihsa ti dieuthinsi tou router mou
kai pali sas euxaristw
twra paw gia updates...:-D :mrgreen:
Πρωτα απ'ολα πηγαινε στο YOU παλι και κανε install το Multimedia Pack 1
Τωρα ανοιξε το Yast2 και πηγαινε στο 'Change Source of Installation'
Πατησε "add"
Protocol: HTTP
Server Name: packman.iu-bremen.de
Directory on Server: suse/9.3
Αφου το κανεις, πατησε το πληκτρο "UP" ωστε το packman να ειναι στην 1η θεση.
...OK και Finish.
Ανοιξε τωρα το 'Install & Remove Software' και χρησιμοποιησε το package manager για να κανεις uninstall(εαν εχουν εγκατασταθει) τα mplayer, kaffeine, xine-ui and libxine1.[κανε search για το καθενα]
Αφου τα απεγκαταστησεις, εγκαταστησε τα παλι ενα-ενα.Μην ξεχασεις να τικαρεις το "Autocheck dependencies"
Μαζι με το mplayer θα εγκαταστησει και τα W32codecs. ;)
Για να μπορεις να βλεπεις και DVD's χρειαζεσαι το 'libdvdcss' που μπορεις να το κατεβασεις απο εδώ http://download.videolan.org/pub/libdvdcss/1.2.8/rpm/redhat/libdvdcss-1.2.8-1.i386.rpm
Αφου το κατεβασεις κανε δεξι κλικ στο αρχειο και διαλεξε 'Install with Yast'
ελπιζω να βοηθησα 8)
O amarok είναι ο βασιλιάς! Καλό και το xmms το έχω και αυτό δουλεύει μια χαρά αλλά δεν ειναι σαν τον amarok...
