djkokalis Δημοσ. 7 Μαρτίου 2006 Δημοσ. 7 Μαρτίου 2006 kalispera. pira simera to proi ena frame 5,25 gia dvdrw kai ena lg dvdrw kai exo ena mikroproblimataki. to dvdr to dokimasa se kanoniko pc kai mou egrapse kanonika dvd. to problima einai oti otan to sindeo sto frame kai katopin se forito pc nai men mou to anagnorizei (pragma to opio simenei oti to frame litourgei kanonika) alla otan pao na kapso dvd i cd sto nero mou ta kaiei ola. mipos exo kanei kati lathos? to dvd to sindesa os master. entometaxi exo kai allo frame me skliro disko o opios den thimame an einai master i slave. pezei rolo?eyxaristo gia to xrono sas filika xristos
activex Δημοσ. 7 Μαρτίου 2006 Δημοσ. 7 Μαρτίου 2006 bale ta dvd-cd rom xorista kai tous diskous xorista enohte tous sklirous sto primary kalodio panta... edit : elenkse an litourgi to ata sta 66 - 33 analoga tis siskeues , alios pithano na prepei na allaksis kai kalodio.
djkokalis Δημοσ. 8 Μαρτίου 2006 Μέλος Δημοσ. 8 Μαρτίου 2006 file mou ti enoeis na valo xorista cd rom kai skliro? primary pos tha kano to skliro? ata 66-33 pos tha ta kano? sorry gia tis kourastikes erotiseis.
djkokalis Δημοσ. 8 Μαρτίου 2006 Μέλος Δημοσ. 8 Μαρτίου 2006 sas vazo ti mou evgale to log tou nero mipos kapios vgalei akri thx 1C80-00EE-19E5-MA2X-4002-E22M-C246 Windows XP 5.1 IA32 WinAspi: File 'Wnaspi32.dll': Ver=4.57 (1008), size=48128 bytes, created 23/12/1997 12:00:00 μμ ahead WinASPI: File 'C:\Program Files\Nero\Nero 7\Core\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2/11/2004 12:54:32 μμ NT-SPTI used Nero Version: 7.0.5.4 Internal Version: 7, 0, 5, 4 Recorder: <HL-DT-ST DVDRAM GSA-4167B>Version: DL11 - HA 1 TA 5 - 7.0.5.4 Adapter driver: <USB 2.0> HA 1 Drive buffer : 2048kB Bus Type : set to ATAPI (3) -> ATAPI, detected: ? CD-ROM: <TOSHIBA DVD-ROM SD-R6012>Version: 1334 - HA 1 TA 0 - 7.0.5.4 Adapter driver: <IDE> HA 1 === Scsi-Device-Map === DiskPeripheral : IC25N040ATMR04-0 atapi Port 0 ID 0 DMA: On CdRomPeripheral : TOSHIBA DVD-ROM SD-R6012 atapi Port 1 ID 0 DMA: On === CDRom-Device-Map === TOSHIBA DVD-ROM SD-R6012 F: CDRom0 HL-DT-ST DVDRAM GSA-4167B G: CDRom5 ======================= AutoRun : 1 Excluded drive IDs: WriteBufferSize: 74448896 (0) Byte BUFE : 0 Physical memory : 511MB (523632kB) Free physical memory: 147MB (151304kB) Memory in use : 71 % Uncached PFiles: 0x0 Use Inquiry : 1 Global Bus Type: default (0) Check supported media : Disabled (0) 8.3.2006 CD-ROM (ISO) 9:34:43 πμ #1 Text 0 File Isodoc.cpp, Line 6414 Iso document burn settings ------------------------------------------ Determine maximum speed : FALSE Simulate : FALSE Write : TRUE Finalize CD : TRUE Multisession : FALSE Burning mode : DAO Mode : 1 ISO Level : 1 (Max. of 11 = 8 + 3 char) Character set : ISO 9660 Joliet : TRUE Allow pathdepth more than 8 directories : TRUE Allow more than 255 characters in path : TRUE Write ISO9660 ;1 file extensions : TRUE 9:34:43 πμ #2 Text 0 File Burncd.cpp, Line 3044 HL-DT-ST DVDRAM GSA-4167B Buffer underrun protection activated 9:34:43 πμ #3 Text 0 File ThreadedTransfer.cpp, Line 531 ReadBuffer-Pipe got 72704KB of Memory 9:34:43 πμ #4 Text 0 File Reader.cpp, Line 124 Reader running 9:34:43 πμ #5 Text 0 File Writer.cpp, Line 113 Writer G: HL-DT-ST DVDRAM GSA-4167B running 9:34:43 πμ #6 ISO9660GEN -11 File Geniso.cpp, Line 3312 First writeable address = 0 (0x00000000) 9:34:43 πμ #7 Text 0 File Burncd.cpp, Line 3341 Turn on Disc-At-Once, using CD-R/RW media 9:34:44 πμ #8 Text 0 File DlgWaitCD.cpp, Line 288 Last possible write address on media: 359848 ( 79:59.73) Last address to be written: 354841 ( 78:53.16) 9:34:44 πμ #9 Text 0 File DlgWaitCD.cpp, Line 300 Write in overburning mode: NO (enabled: CD) 9:34:44 πμ #10 Text 0 File DlgWaitCD.cpp, Line 2699 Recorder: HL-DT-ST DVDRAM GSA-4167B 9:34:44 πμ #11 Text 0 File DlgWaitCD.cpp, Line 472 >>> Protocol of DlgWaitCD activities: <<< ========================================= 9:34:44 πμ #12 Text 0 File ThreadedTransferInterface.cpp, Line 847 Setup items (after recorder preparation) 0: TRM_DATA_MODE1 () 2 indices, index0 (150) not provided original disc pos #0 + 354842 (354842) = #354842/78:51.17 relocatable, disc pos for caching/writing not required/ required, no patch infos -> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 354842 blocks [G: HL-DT-ST DVDRAM GSA-4167B] -------------------------------------------------------------- 9:34:44 πμ #13 Text 0 File ThreadedTransferInterface.cpp, Line 1059 Prepare recorder [G: HL-DT-ST DVDRAM GSA-4167B] for write in CUE-sheet-DAO DAO infos: ========== MCN: "" TOCType: 0x00; Session Closed, disc fixated Tracks 1 to 1: 1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 727023616, ISRC "" DAO layout: =========== __Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________ -150 | lead-in | 0 | 0x41 | 0x00 -150 | 1 | 0 | 0x41 | 0x00 0 | 1 | 1 | 0x41 | 0x00 354842 | lead-out | 1 | 0x41 | 0x00 9:34:44 πμ #14 Text 0 File SCSIPassThrough.cpp, Line 39 SPTILockVolume - completed successfully for FCTL_LOCK_VOLUME 9:34:44 πμ #15 Text 0 File SCSIPassThrough.cpp, Line 84 SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME 9:34:44 πμ #16 Phase 24 File dlgbrnst.cpp, Line 1730 Caching of files started 9:34:44 πμ #17 Text 0 File Burncd.cpp, Line 4175 Cache writing successful. 9:34:44 πμ #18 Phase 25 File dlgbrnst.cpp, Line 1730 Caching of files completed 9:34:44 πμ #19 Phase 36 File dlgbrnst.cpp, Line 1730 Burn process started at 24x (3.600 KB/s) 9:34:44 πμ #20 Text 0 File ThreadedTransferInterface.cpp, Line 2685 Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0 9:34:44 πμ #21 Text 0 File MMC.cpp, Line 17173 StartDAO : CD-Text - Off 9:34:44 πμ #22 Text 0 File MMC.cpp, Line 21850 Set BUFE: Buffer underrun protection -> ON 9:34:44 πμ #23 Text 0 File MMC.cpp, Line 17404 CueData, Len=32 41 00 00 14 00 00 00 00 41 01 00 10 00 00 00 00 41 01 01 10 00 00 02 00 41 aa 01 14 00 4e 35 11 9:34:54 πμ #24 SPTI -600 File SCSIPassThrough.cpp, Line 290 G: CdRom5: SCSIStatus(x00) WinError(121) NeroError(-600) Sense Key: 0x00 (KEY_NO_SENSE) Sense Code: 0x00 Sense Qual: 0x00 CDB Data: 0x2A 00 FF FF FF 6A 00 00 20 00 00 00 Sense Area: 0x00 00 00 00 00 00 00 00 00 00 00 00 00 Buffer x05380000: Len x10000 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0x00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 9:34:54 πμ #25 CDR -600 File Writer.cpp, Line 302 Device not available G: HL-DT-ST DVDRAM GSA-4167B 9:34:54 πμ #26 Text 0 File ThreadedTransfer.cpp, Line 228 all writers idle, stopping conversion 9:34:54 πμ #27 Text 0 File ThreadedTransfer.cpp, Line 222 conversion idle, stopping reader 9:35:09 πμ #28 Phase 38 File dlgbrnst.cpp, Line 1730 Burn process failed at 24x (3.600 KB/s) Existing drivers: File 'Drivers\ASPI32.SYS': Ver=4.57 (1008), size=23936 bytes, created 23/12/1997 12:00:00 μμ Registry Keys: HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
activex Δημοσ. 8 Μαρτίου 2006 Δημοσ. 8 Μαρτίου 2006 ton disko me ta windows tha ton valis sto primary master kalodio kai sto primary slave ton deutero disko <se periptosi pou exeis fisika> alios asto keno kalitera. sto secontary master kai slave bale to dvdrom-cdrom me opia sira thes. ta ide kalodia einai 2 epano sti mitriki tha dis pio einai to noumero 1 <primary> kai to noumero 2 <secontary> idalos mpes sto bios kai elenkse an ta ebales sosta, kane dokimes mexri na ta bris, pisteuo pantos pos einai aplo to thema sou. to ata 66-33 mhn se apasxoli arki na baleis kenourgia kalodia sinithos einai xromatos kitrinou , ta sigekrimena mporoun na doulepsoun asinxrona thn kathe siskeuh sou kai den tha thn ypoxronisoun sthn taxitita ths mikroterhs. kane kai ena install tous ide drivers tis mitrikhs sou kai elenkse an ontos douleuoun sta sosta ata oi siskeues sou xrisimopiontas kapio programa opos to sisoftsandra gia analish ton periferiakon klp. akoma pio apla auto mporis endexomenos na to dis kai apo kapio options ton ide driver pou tha egatastishs. edit: mia erotish , to dvd-recorder sou einai usb h mou fenete??!
