Bioshock {Απο τους δημιουργούς του System Shock 2}
privateer
  • Απαντ. 685
Το παιχνίδι κυκλοφορεί εντός του Αυγούστου. Οριστέ μερικές πληροφορίες από μια πρόσφατη συνέντευξη της Irrational Games
  Αναφορά σε κείμενο
PCGH: What are technical features of that engine that you see most fitting for you title? What parts of the product had to be modified to fulfil your requirements?
Irrational Games: Some of the big areas that are custom in Bioshock are:
- The AI system which is a development of an AI engine that we originally developed for Tribes: Vengeance and was then used in SWAT 4.
- Various water rendering features mentioned above to handle water splashing off objects, water flow, surface properties and so on.
- Integration of Havok physics rather than the default UE3 physics solution.
- A flash based rendering system for the game HUD and UIs.
PCGH: If you compare your product to other games that utilize the Unreal Engine 3 like Parabellum or UT 2007 what are the very special technical highlights of your game?
Irrational Games: The great advantage of Unreal is that it gives us a solid base to start from so that we can spend our technology development time on extensions rather than basic rendering and other engine features. In Bioshock, I think our stand out features are:
- The AI, particularly the “ecology” that supports AI to AI interactions (not always hostile), movement of AIs through the level and repopulation of AIs.
- Density and complexity of environmental interactions: the ability to set things on fire, have that fire propagate dynamically, the ability to use water to conduct electricity, the ability to utilize physical objects to cause damage via Telekinesis and so on.
- Freeform movement of players through the game both within and between levels. We rely much more on systemic gameplay than pre-scripted events because we donʼt always know exactly where or when the player is going to encounter something in the game. For example, you can travel back to earlier levels of the game if you want and we have to fully support that.
- Rendering of water surfaces and modeling of water flows.
PCGH: The Unreal Engine 3 is shipping with a modern renderer that fully supports the shader model 3/4 and therefore advanced rendering techniques like FP32 rendering, vertex texturing, higher interpolator counts or dynamic branching. How do you utilize these techniques to increase performance or to offer eye catching visuals?
Irrational Games: Under DirectX 9 we use shader model 3. If you run under DX10, we use shader model 4 which lets us do some nifty things we canʼt do in DX9.
In either case, the game uses high dynamic range rendering. We use fp16 (16 bit floating point format) and, under DX10, a packed floating point format. The packed format reduces the fill rate cost allowing us to deliver the same quality image at a higher frame rate.
Dynamic branching lets us decide what pixel shading algorithm to apply on a pixel by pixel basis. This means we can run a more complex algorithm in cases where it benefits us and a simpler one where it doesnʼt, saving our processing power. So, when generating a shadow, we use dynamic branching to apply a more complex algorithm that generates crisper outlines on the shadow boundaries and a simpler and faster algorithm on the shadow interior. Vertex texturing is used to simulate splashes caused by falling water onto dynamic objects. We render a texture based on the objects in the volume swept by the falling water. That texture is then used to determine where to place particles illustrating the splashes caused by the water hitting those objects.
PCGH: Where there any visuals on your wish list that you had to drop due to a much smoother performance? What details will players with older graphics hardware miss?
Irrational Games: Surprisingly, not really! Weʼve been very pleased at our ability to manage all the dynamic effects (fire in particular) with the density of objects that we want in the game.
Of course, there are always constraints in level building in any game that the artists and designers would love to have removed. If we could magically render whatever we wanted on any hardware, Iʼm sure we would have put in more windows, more water effects and so on. But I think our level builders have done a great job conveying the impression of being in an underwater city that is falling apart around you.
On lower end systems players will have to make the usual trade offs: turning down the resolution and perhaps turning off some of the more advanced effects like real-time reflections on water surfaces and reducing the quality of some of the shaders and textures.
PCGH: As far as overall performance is concerned. Can players increase it remarkably by buying a second graphics card (SLI/Crossfire)?
Irrational Games: Weʼve focused development on single card solutions, so weʼre not recommending people rush out to buy an SLI setup for our game.
PCGH: Dual or even multicore CPUs become more powerful, popular and even affordable recently. Furthermore the Unreal Engine 3 is highly optimised for multithreading. How do you utilize the multithreaded structure of that engine efficiently? What different calculations can be or are split up into different threads and what is the expected performance gain resulting from two respectively four or more cores?
Irrational Games: The game is fully multi-threaded so multiple cores are very useful for us. We have separate threads for physics, rendering and other tasks.
So, thereʼs a very clear jump in overall performance (frame rate) going from one to two cores. Increases beyond that (two to four) are more incremental.
PCGH: Have you already utilized the Intel Core 2 Quad or AMD “4x4” platform? What is your personal opinion about these products?
Irrational Games: Yes we have. Clearly these platforms vastly increase the possible performance of games that use threading. The “sweet spot” for our game is a two core system, though four cores is not going to hurt. I expect our future games will be more focused around these new architectures.
PCGH: Windows Vista comes with the new DiectX 10 API. Will your engine support shader model 4 and will you use advanced features of that shader model like Geometry Shader or Virtual Texture Management?
Irrational Games: We are supporting a number of new features for DX10. Most significantly, DX10 will allow any physical object that comes in contact with a body of water to produce interactive waves that will perturb the surface of the water itself, distorting its refraction and reflection, and blending seamlessly with the simulations already running on the surface. AIs moving in water will leave behind rippling, foaming trails. Bullets and objects that hit water will produce radial ripples. In DX10, for fire and some other effects, we'll be using soft particles which means that the fire particles will no longer "clip" or be cut off by hard surfaces that they intersect with. And finally, under DX10, shadows will be crisper and more precisely match the features of the objects they are cast from. If there is no Direct3D 10 support yet, will it be integrated later on? Have you already made experience with the new API? See above.
  Αναφορά σε κείμενο
PCGH: As far as physics simulation is concerned: Does the player also profit from a PhysX card or are you using Havok solely on the CPU? Are there any plans to accelerate Physics through HavokFX also on GPUs?
Irrational Games: There are no plans to utilise custom physics hardware at the moment.
  Αναφορά σε κείμενο
PCGH: AI plays an important role in a Game with tactical emphasis. Were you satisfied with the AI performance of the Unreal Engine 3 or did you have to overhaul die AI-Part completely?
Irrational Games: As discussed above, weʼre using a completely custom AI solution. The Unreal AI that ships with the engine is not appropriate for the kind of gameplay and level of interactions that weʼre focusing on in Bioshock.
  Αναφορά σε κείμενο
PCGH: Bioshock was developed for release on Xbox 360 and PC. Weʼve seen game-ports from this console in the past to not live up to PC gamersʼ expectations, especially as far as interface, handling and – visually – texture resolution is concerned. Can you erase those concerns for potential buyers of Bioshock?
Irrational Games: At the end of the day, the only way we can really erase those concerns is by getting the game in their hands, or at least a reviewerʼs. I can promise you though that weʼre not just doing a cheap port. The game is being developed on both platforms simultaneously and we have a separate team dedicated to the PC. Weʼre well aware of interface, graphics and gameplay issues that are different between the two platforms.
To be honest, I think our bigger problem has been getting the 360 right. Donʼt forget that we are a PC developer. Weʼve done System Shock 2, Tribes and SWAT 4, all shooters on the PC and its our natural home.
I personally prefer playing the game on PC because I like mouse and keyboard above a controller. I donʼt think PC gamers will be disappointed.
  Αναφορά σε κείμενο
PCGH: Can you already say what rig players must have to play the game with all details in resolution of 1.280x1.024?
Irrational Games: Our recommended spec is as follows:
- CPU: 3GHz dual core processor
- Memory: 2 GB RAM
- Video card: Pixel Shader 3.0 compliant video card with 512 Ram (Geforce 7900 GT or better)
But to run the game at 1280x1024 with all graphics options enabled you really need an NVIDIA 8800 or ATI 2900XT or better.
PS: Άκυροοοοοοοοοοοοοο. Νόμιζα ότι το έκανα το thread στο section παιχνίδια. Κάποιος mod ας το μεταφέρει το post στο thread του Bioshock :)
se auto to game ola kala apo oses foto exw di mexri tora alla re paidia mipos exei ypebolikotato "blur" ? poli tholoura kai kako , tha mou pis einai h mixani grafikon tetia alla opos kai na exei den akousa kanena na paraponiete gia tin elipi "eukrinia" stin eikona kai ypa na to kanw egw !
lete na einai h idea mou ? :s
edit: "But to run the game at 1280x1024 with all graphics options enabled you really need an NVIDIA 8800 or ATI 2900XT or better."
molis diavasa auto anarotieme ti einai to "better" ???? exoume apothrasinthi telios mou fenete :S
BioShock PC Hardware Requirements Revealed
On the fence about which version of BioShock you'll be picking up? It's inevitable that you'll purchase the thing, believe me, it's just a question of whether your PC is up to the processing challenge. My underpowered PC doesn't quite make the cut, hovering right around the minimum system requirements which is wholly unacceptable, so it's going to be the Xbox 360 version—or, possibly, the PLAYSTATION 3 version, should 2K Games announce such a thing. Gamers looking to finalize their NewEgg orders, however, will want to read on to see what BioShock needs and wants from a hardware set up.
Operating Systems: Windows XP (with Service Pack 2) orWindows Vista
Minimum System Requirements:
CPU: Pentium 4 2.4GHz Single Core processor
System RAM: 1GB
Video Card: Direct X 9.0c compliant video card with 128MB RAM (NVIDIA 6600 or better/ATI X1300 or better, excluding ATI X1550).
Sound Card: 100% direct X 9.0c compatible sound card
Hard disk space: 8GB free space
Recommended System Requirements:
CPU: Intel Core 2 Duo processor
System RAM: 2GB
Video card:
DX9: Direct X 9.0c compliant video card with 512MB RAM (NVIDIA GeForce 7900 GT or better)
DX10: NVIDIA GeForce 8600 or better
Sound Card: Sound Blaster® X-Fi™ series (Optimized for use with Creative Labs EAX ADVANCED HD 4.0 or EAX ADVANCED HD 5.0 compatible sound cards)
Important Note: Game requires Internet connection for activation
Όλο και περισσότερα παιχνίδια εκμεταλλεύονται το νέο hardware. Αυτό είναι καλό για όσους είχαν σκάσει τα φράγκα,κακό για όσους μένουν με ένα παλιό PC configuration πλέον. Τόσο το Lost Planet,όσο και το Colin McRae: Dirt είναι καλύτερα στα high-end PC's και το κυριότερο με καλύτερο framerate (μέχρι και 100% καλύτερο framerate αφού όταν το Χ360 βγάζει 30 στο PC βλέπεις 60) σε λογικές αναλύσεις τύπου 1280x960 + FSAA. Ακριβώς το ίδιο θα γίνει και με το Bioshock αλλά και με το Gears Of War. Είναι καιρός να κάνετε αναβάθμιση,γι' αυτό λέγαμε ότι ήταν ευκαιρία τρελή να κάνει αναβάθμιση κάποιος στις αρχές του χρόνου (και μέχρι στιγμής δεν αξίζει μια ένας quad-core καθώς ΣΕ ΟΛΑ τα παιχνίδια είμαι GPU limited με τον Core2Duo στα 3.51)....γιατί ακόμα και μετά από 7 μήνες (στην περίπτωσή μου και αρκετών άλλων 9 μήνες αφού είχαμε κάνει νωρίτερα την αναβάθμιση αυτή) το PC σας θα παρέμενε high-end και θα έτρεχε χωρίς πρόβλημα όλα τα παιχνίδια με max details ;)
τωρα ομως η αναβαθμιση σε Ε6600 και 8800gts κανει τα μισα λεφτα απο πριν 9 μηνες.Και ετσι κι αλλιως στο μεσοδιαστημα δεν βγηκε κανενα καλο/βαρυ παιχνιδι.Για μενα τωρα ειναι καλυτερα για upgrade
Σοβαρή αναβάθμιση προληπτικά ούτε και εγώ κάνω. Ακόμα-ακόμα δεν είδαμε κανένα από τους "βαριούς" τίτλους έτσι κι αλλιώς.
Ευτυχώς μπορώ να περιμένω αρκετά -δε χρειάζεται να παίξω το Bioshock με το που θα βγει. Προτιμώ να το παίξω άνετα αργότερα με μια καλή αναβάθμιση, που θα μου επιτρέπει να παίξω και άλλους από τους πολυαναμενόμενους για μένα τίτλους (από το 2006 και το 2007 so far ζήτημα να βρήκα ένα τίτλο να μου αρέσει πολύ και να μη τρέχει στο PC μου), ενώ θα έχω ακούσει και από ένα ικανό αριθμό άλλων αν τελικά τα άξιζαν τα λεφτα τους, και το.... χιλιάρικο της αναβάθμισης.
