Bioshock {Απο τους δημιουργούς του System Shock 2}
privateer
Featuring a hulking Big Daddy and a Little Sister hiding in the shadows, the official cover art for the 360 and PC versions of Bioshock is about what you'd expect. Brian Crecente
  • Απαντ. 685
New details for BioShock have been revealed from the July 2007 issue of Electronic Gaming Monthly's (EGM).
- Predicted to be 25 hours long for those who take it slow.
- Rapture labeled as a "city where the artist would not be censored, where the scientist would not be bound by petty morality, where the great would not be constrained by the small".
- Bioshock never forces you to backtrack.
- Enemies wander around rapture, looking for Adam. They will react to sounds, so be stealthy!
- Enemies spawn in a different place everytime.
- The Splicer enemies always know when they're dieing, and will rush to a medical kit once near death.
- In each section of Rapture, there are three Big Daddies to take out.
- There are two options once you have the Little Sister to yourself. You can harvest them, killing the girl and getting lots of Adam, or saving her and getting a little.
- Little Sisters are invincible until the point you harvest them.
- You can eventually get a camera and you can use it to research enemy weaknesses. Snapping different shots will get you more points. With enough points, you can earn bonuses against different Splicers.
- A white hat and a black hat - Atlas wants you to harvest all the little sisters, so you can power up your character and get his family out of Rapture, while Tenenbaum wants you to save the Little Sisters, who are his creation.
- Adam is used at Gatherers' Gardens to buy different plasmids (powers) and gene tonics (character-tweaking substances).
- Any contraption, minus the Gatherer's Gardens, can be hacked into and turned into something that benefits you. E.G, you can hack a medical station to poison Splicers when they come for health.
- You can build custom Plasmids and customize your weapons.
Bioshock Emerges From European Depths On August 24
August 24. The PC version will set you back £34.99, while the 360 and its ultra-expensive, see-through green plastic case will result in a higher price-point of £44.99.
Είχαν πει ότι:
"April 25, 2007
Many of you have been asking if BioShock would utilize DX10 feature set. The official answer is that yes, BioShock will be utilizing DX10. However, for those of you who won't be upgrading by August, don't worry. BioShock will also run with DX9. "
ναι αλλα θα χρησιμοποιει shader 4 και τα αλλα καλουδια του dx10 ή θα ειναι σχεδον ομοιο σε dx9 και dx10(βλεπε lost planet)?
