Bioshock {Απο τους δημιουργούς του System Shock 2}
privateer
kamia sigkrisi me ta grafika pc vs xbox iparxei i einai noris?
Τα ίδια θα είναι. Έχουν ρίξει κάτι DX10 effects στο νερό αλλά σιγά τα λάχανα. Η μόνη διαφορά θα είναι το AF,οι μεγαλύτερες αναλύσεις που θα μπορεί κάποιος να ενεργοποιήσει στα PC's και το framerate,από εκεί και πέρα όμως τα γραφικά θα είναι ίδια.
  • Απαντ. 685
ΕΤΣΙ ΠΡΕΠΕΙ ΝΑ ΓΙΝΟΝΤΑΙ ΤΑ PORTS
if youʼre worrying about the dreaded taint of consolification, by the way, donʼt. Itʼs clear that the PC team at Irrational are every bit as platform-snobbish as us. Thereʼs a PC-only options menu that lets you turn off the quest compass guiding you to your next objective, disable the golden sheen on mission-critical items, and as for auto-aiming, it isnʼt even an option unless you plug in a 360 pad.
Also exclusive to this edition is a magnificently intricate PC-only quick-switch menu. Because you can have 19 different weapon ammo types on top of your six Plasmids at any given time, using the mouse wheel can get fiddly. So thereʼs also a key you can hold down to pause the game and pick any one of those 25 modes of attack with a single click. Hacking, too, has been designed differently for the PC to make best use of the mouse - itʼs quicker, slicker and less frustrating than the sluggish Xbox controls.
The final geekily gratifying thing about the PC version is how well it runs. It was dazzlingly beautiful and hitchlessly smooth on a machine with an Athlon X2 5200 and a single entry-level GeForce 8800 - running DirectX 9. And this was at 1600x900 on max settings.
http://www.gamesradar.com/us/pc/game/reviews/article.jsp?articleId=2007081595653768046&sectionId=1000&releaseId=20060426172718471012
Single Entry-level GeForce 8800 προφανώς εννοούν μια 8800GTS. Θαυμάσια νέα έτσι; 5 μέρες ακόμα :D
ετσι? δηλαδη με διαφοροποιησεις την δυνατοτητα switch-off την πυξιδα και χωρις autoaim για mouse ?
δηλαδη lol!!!
εγω αυτο που θελω να δω ειναι τι θα κανει η mod κοινοτητα με το bioshock. βλεπω καλες πιθανοτητες...
δηλαδη lol!!!
Βασικά δεν έχουμε να κάνουμε με port αλλά με ταυτόχρονη ανάπτυξη των 2 εκδόσεων από διαφορετικά studios,οπότε άκυρο το θέμα με το porting (που είπα παραπάνω. Από βιασύνη μου βγήκε η λέξη αυτή :P). Βάση των παραπάνω έχει χαμηλές απαιτήσεις και τρέχει κομπλέ (ακόμα και σε middle-end PC's),έχει ειδικά DX10 εφέ για το νερό (το προσπερνάμε όμως γιατί ΟΚ,σιγά τα λάχανα :P),εκμεταλλεύεται τα ποντίκια και τα πληκτρολόγια,έχει νέα/διαφορετικά menus από την Χ360 έκδοση και αφαιρεί την πυξίδα (κάτι το οποίο είχαν ζητήσει πολλοί gamers στο Oblivion και βγήκε και patch γι' αυτό). Ειλικρινά τι περισσότερο μπορείς να ζητήσεις από ένα multi-platform παιχνίδι; Αντί για lol θα έπρεπε να πεις εύγε....ή μήπως ζηλεύεις την extra προσοχή που δόθηκε στην PC έκδοση; :P :p
PS: 17 του μηνός (σήμερα δηλαδή) διαθέσιμο το demo από Fileplanet και Fileshack
PS2: Άκυρη η ημερομηνία. To Be Announced είναι τώρα. Λέγεται ότι το demo θα βγει μετά την κυκλοφορία του παιχνιδιού γιατί μερικοί το έχουν ήδη το παιχνίδι κι η 2K φοβάται ότι κάποιος θα hack-έψει το .exe αρχείο του παιχνιδιού για να τρέξει και το full πριν τις 21 του μηνός. Τρέχα γύρευε,ότι να 'ναι λέμε :P
ego exo kai pc kai xbox, alla tha to pekso sto pc
απο αυτα που ξερουμε μεχρι στιγμης εγω θα ελεγα οτι ειναι ενα ξερο πορτ απο 360.
ομως προφανως αυτο πεφτει βαρυ σε μερικους οπως ο αρθρογραφος του αρθρου που εβαλες πιο πριν (αλλα και σε αλλους ʽβαρεμενουςʽ pcακηδες),
και βρισκομαστε στην ευχαριστη θεση να διαβαζουμε για "σημαντικες διαφορες" οπως η ελειψη πυξιδας αλλα και η χρηση του mouse... :D
ευγε? ευγε!
ευγε? ευγε!
Μάλλον δεν γνωρίζεις τα πράγματα όπως έχουν,οπότε και δεν έχει νόημα να εκφέρεις και απόψεις....ή μάλλον το γεγονός ότι δεν πρόκειται για Port αλλά για ταυτόχρονη ανάπτυξη του τίτλου από διαφορετικά studios σας έχει πειράξει μερικούς ;) . Παν μέτρον άριστον (ακόμα και στην ζήλεια)....μην ζηλεύετε τόσο πια,ξυδάκι να σας περάσει μερικών ;). Άντε και σε κανέναν άλλο τίτλο θα τους πούμε να σας ρίξουν κάνα exclusive μικρό χαρακτηριστικό ώστε να μην φαίνεστε σε "δεύτερη μοίρα" :P ;)
PS: http://www.2kgames.com/cultofrapture/pcblowout.html . Κατεβάστε το podcast. Ω τι τύχη....λέει για PC team. Άντε γιατί πέφτει παραπληροφόρηση από μερικούς εδώ μέσα :P . Κατεβάστε να μάθετε και τις διαφορές των 2 εκδόσεων από τους ίδιους τους developers,άντε καλά παιδάκια ;).
"We didn't start from the console interface and trying making work on the PC. We started from the point of making a good PC interface"
Και πολλά άλλα στο podcast. Truth hurts some people ;)
EDIT:
2007 - Irrational Games is renamed to 2K Boston and 2K Australia.[1]
Studios
2K Boston is currently developing BioShock, a spiritual sequel to System Shock 2, with 2K Australia.
2K Australia is focusing on the PC version of BioShock.
Ελπίζω να πήρατε ένα μικρό μάθημα μερικοί έτσι; ;)
