Προβλημα με σκληρο...please help! :(
scouser
  • Απαντ. 36
Sto BIOS ton blepei paidia kanonika...Einai NTFS (oxi FAT).. Ekana ta diagnostics tis WD alla dustixws den ebgalan kapoio sumperasma..
Tha dokimasw to partition magic re paidia, ti na pw...ksenera..
Ayto lew ki egw. Afoy ton briskei kai toy leei unlockated shmainei oti exei agnwsto partition (oyte fat' date=' oyte ntfs) h ayto to agnwsto partition einai ena katestrameno partition logw katastrofhs ths epifaneias toy diskoy h isws kai kapoioy ioy. Gi ayto lew partiotion magic, na doyme mhpws einai anagnwrisimo to partition apo kei.
Mporei na egine kai kati poly aplo. Na mhn eixe kleisei o ypologisths otan ton aposyndese kai na egine apo thn aposyndesh to problhma.[/quote']
File ebala to partition magic alla den fainetai na egine kamia tromeri allagi..Ennow pws kai to PM to blepei san unformatted....Episis, dokimasa kai to Easy Recovery Pro, pou eixe sustisei enas filos...Ekane ligi doulitsa genonos. Diladi ekane recover gyrw sto 20% twn arxeiwn pou eixa ston en logw skliro... Episis, ta arxeia pou mporesan na ginoun recovered ta ebgale me diko to filename, pragma poy simainei pws prepei na tsekareis ola ta recovered arxeia ena pros ena gia na deis ti einai k na ta kaneis rename esy.. Bebaia mikro to kako, an mporouse na kanei recover ola ta arxeia...Dustixws omws oute me auto mporesa na kanw swsta ti douleia moy.
file kai ego antimetopisa prin ligo kairo to idio problhma. dusthxos den katafera na kano tipota. anagkastika na kano format kai meta me ena recovery program(Recover My Files v3.70) epanefera para polla arxeia.h blakeia olou tou thematos einai oti ta arxeia mou ta ebgale ola me alla onomata p.x cluster32168+2686+23.mp3 kai osa arxeia htan megalutera apo 4mb mou ta xorize,dhladh ena binteo mou to ekobe se diafora komatia. asta na pane! den mporeis na fantasteis posa kantilia katebaza ekeines tis meres. den thelo oute na to thumamai! diabasa oles tis apanthseis pou sou exoun steilei(ta ekana kai ego ola auta) kai akoma den ksero ti na kano kai ti ftaiei. kalh tyxh
Γεια χαρα παιδια!!
βασικα τα διαβασα τα μηνυματα σας..ειχα στειλει και εγω καπια μηνυματακια και τελικα μια καλη..insomnia ψυχη μου εδωσε τα φψτα του και τελικα ολα ενταξει!!προσπαθησα αρχικα να κανω ανακτηση δεδομενων με το προγραμμα easy recovery alla opvw eipe kai o filo parapanv moy ta ebgaze xvriw fakeloyw kai kommena kai epeidh eixa πολλα και με επιασε απογοιτευση...ΑΛΛΑ!
Ο εν ονοματι "spirosta" μεεσωσε και δημοσιο θα πω ενα μεγαλο ευχαριστω!!
λοιπον. το προγραμμα και απο μενα τεσταρισμενο και λειτουργει αψογα ειναι το file scavenger!na fantasteite οτι πολυ γργορα εγω ανακτησα πανω απο 70Gb!!!ικανοπιητικα , γρηγορα...ευκολα!!
Καλο κουραγιο και καλη τυχη!
