US Robotic problem!!
WaVe
neurotic fest oxi den iparxei oute provlima gia to pc sou oute gia to modem sou na stelnei paketa pings.mionis apla to bandwidth kata 0.,0000001 tis 100.skepsou oti paketa otan katevazeis stelnontai apira sto pc sou.opote allo ena den exei provlima.
  • 1 χρόνο αργότερα...
  • Απαντ. 95
Exw to urs9105 k merikes fores otan girnaw spiti k koitaw to pc ta vlepw ola disconnect, dc++, msn, skype klp.
Ama prospathisw na bw sto router ekini ti stigmi den kanei tipota, oute kan anoigei i selida tou router.
Ama omws klisw to koubaki tou router k to ksananoiksw ola einai ok.
Kamia idea? Lete na fteei to firmware? Exw valei afto pou dinei to http://www.adslgr.com :roll:
To thread einai poly palio alla to problhma parousiasthke se emena ayto ton kairo. Katarxin stoixeia xrhshs:
modem: usr9106 me version 2.1 firmware.
isp: forthnet 768/256
H aitia:
Syndiasmos ISP kai modem. H Forthnet stelnei epaneilimena allages wanip. To usr "kollaei" kai prospa8ei ef exhs na parei xwris logo nea wanip.
Giati syndiasmos (?) : Exw to usr9106 se 2 diaforetikes poleis me forthnet. Den parousiazete to problhma kai sta 2 modem. Filos exei to neo usr9107 sthn idia polh, me ton idio paroxea. To problhma parousiazete kai se ayton enw parallhla sthn idia akribws perioxh to 1 apo ta 2 modem mou douleyei xwris problhma.
Ta symptwmata:
- Otan anoigete ena apo ta syndedemena PC, h endeixh ADSL anabosbhnei kai otan epanerxetai, h endeixh WANIP ginetai (kai paramenei) kokkinh.
- Exei apodw8ei IP apo ton ISP alla h endeixh WANIP paramenei kokkinh.
- Otan kanena PC den einai anoikto (idle time), h endeixh ADSL anabosbhnei kai otan epanerxetai, h endeixh WANIP ginetai (kai paramenei) kokkinh.
H lysh:
1. Ftiaxte kafedaki.
2. Mpeite stis ry8miseis tou modem (eite apo webpage eite apo command line)
3. Security -> Virtual Servers. Afaireste (remove) ola ta ports pou exete.
4. Service Provider Settings -> WAN Setup. Sto service pou hdh exete patiste to koumpi "Edit".
5. Ry8miste to Authentication se AUTO. Apenergopoihste (uncheck) ta IGMP, WAN kai QoS services. Patiste "Apply" kai "Finish" gia na kanei reboot to modem.
6. Me anoikto to modem bgalte ta kalwdia diktyou. Teleytaio bgalte to thlefwniko kalwdio. Pieite kafedaki kai perimenete 2 lepta.
7. Sbhste to modem apo to koumpi reymatos. Pieite kafedaki kai perimenete 5 lepta. Sbhste to/ta PC(s) pou prokeitai na syndesete sto modem.
8. Xwris na balete ta kalwdia, anoixte to modem apo to koumpi reymatos.
9. Topo8ethste to thlefwniko kalwdio kai perimenete thn prasinh endeixh ADSL.
10. Topo8ethste mono to 1o kalwdio diktyou sth Ethernet 1 (an exete perissotera apo 1 PC mhn syndesete ta ypoloipa). Perimenete th prasinh endeixh. To WANIP 8a parameinei sbhsto (logw tou bhmatos 5).
11. Anoixte to PC pou exete syndesei sto modem. Akolou8hste to bhma 2.
12. Service Provider Settings -> WAN Setup. Sto service pou hdh exete patiste to koumpi "Edit".
13. Energopoihste (check) ta IGMP kai WAN services. Patiste "Apply" kai "Finish" gia na kanei reboot to modem. Perimenete thn prasinh endeixh WANIP.
14. Efoson parete prasinh endeixh WANIP, sbhste to syndedemeno PC. Perimenete 1 lepto. To WANIP 8a parameinei prasino.
15. Anoixte to syndedemeno PC. H endeixh ADSL den prepei na anabosbisei ka8olou. H prasinh WANIP endeixh prepei na parameinei sta8erh.
16. An exete kai alla PCs, syndeste ta kalwdia diktyou tous sto modem.
17. Stis ry8miseis tou modem, Security -> Virtual Server -> Topo8ethste xana ta ports pou eixate.
18. Eiste etoimoi.
Εγώ αντιμετωπίζω το εξής πρόβλημα.
Δεν μου ανάβει το λαμπάκι που αντιστοιχεί στην ένδειξη οτι είναι συνδεδεμένο στο ίντερνετ.Κλειδώνει κανονικά στα 2048 αλλά δεν συνδέεται.
μόντεμ u.s.robotics 9108
isp forthnet
ταχύτητα 2048/256
Αυτό έγινε όταν έφυγα για πρωτοχρονιά κλείνω το ρουτερ και όταν γύρισα δεν μπορούσα να συνδεθώ
Μήπως έχει χάσει τις ρυθμίσεις του το router?Για δοκίμασε να του ξαναπεράσεις τα username\pass για την dsl!
Δυστηχώς δεν λειτούργησε.Έκανα reboot,reaset to router αλλά τίποτα.Παίζει να μου έχουν αλλάξει τους κωδικούς χωρίς προειδοποίηση????Δοκίμασα με άλλο ρούτερ αλλά τίποτα.Τί να κάνω ρε που!@#$%στη μου.
isp forthnet
ταχύτητα 2048/256
poles fores ama den einai sflama tou isp thelei reset apo ote.gia na dei kapoios ti fteei dokimazei na mpei me stoixeia [email protected] kai password otenet an parei ip tote ok apo ote.
