ksessalonikios Δημοσ. 7 Αυγούστου 2005 Δημοσ. 7 Αυγούστου 2005 1. ROUTER = 9106 / Software Version: 0921_022505-2.14L.01A.a2a013b, TELLAS, INTRACOM 2. Select the modulation below. = Auto Mode (G.Dmt, G.lite or T1.413) VPI: [0-255]= 8 VCI: [32-65535]= 35 Service Category: UBR without PCR PPP over ATM (PPPoA) VC/MUX Authentication Method: CHAP PPP MTU: 1500 Dial on demand (with idle timeout timer) = UNCHECKED PPP IP extension = UNCHECKED Enable IGMP Multicast = UNCHECKED Enable WAN Service = CHECKED Service Name = pppoa_8_35 Allow "Reaim" Proxy = CHECKED Enable Quality Of Service = CHECKED WAN Setup - Summary Make sure that the settings below match the settings provided by your ISP. VPI / VCI: 8 / 35 Connection Type: PPPoA Service Name: pppoa_8_35 Service Category: UBR IP Address: Automatically Assigned Service State: Enabled NAT: Enabled Firewall: Enabled IGMP Multicast: Disabled Quality Of Service: Enabled 3. Διακόπτης...το θέμα ειναι ομως οτι δεν εχω δοκιμάσει ποτέ να κάνω το restart μέσα απο τον browser
bravenew Δημοσ. 7 Αυγούστου 2005 Δημοσ. 7 Αυγούστου 2005 paidia exo kai ego to idio modem/router kai mou ekane mia fora to idio. Fisika sta topic diktivn anafero gia tin karta diktiou... tespa den mporousa na sindetho sto router kai paratirisa oti (eixa balei ton H/Y otan anoigei na pairnei auto ip apo to router) den eperne nea ip apo to router. Patisa ananeosi alla tipota den epairne nea ip. opote anagkastika na balo custom ip kai ektote den eixa kanena problima epeita apo ip forced from isp. Elpizo na boithisa.
ksessalonikios Δημοσ. 7 Αυγούστου 2005 Δημοσ. 7 Αυγούστου 2005 bravenew mporeis na analyseis ligo ti diadromi kai tis epiloges poy ekanes
poulinos Δημοσ. 8 Αυγούστου 2005 Δημοσ. 8 Αυγούστου 2005 Vasika efiga gia diakopes giafto k den apadisa' date=' dioti den to epsaksa kan.Vevaia ws proxthes pou girisa den eixe alaksi i IP mou (1mina+ dld) giafto k den to piraksa. Alla apo proxthes exei alaksi [b']idi[/b] 2 fores ( gademi pouline ) Perimena fisika k apo to filo mas na mas pei an to ekana sto diko tou modem na doume an alazei tpt. Vevaia an les pws i rithmiseis einai i idies tha to elenksw k tha sas pw! ax kalo mou zyxel exo xexasei ti simenei na sou klino ton diakopti.
gv Δημοσ. 8 Αυγούστου 2005 Δημοσ. 8 Αυγούστου 2005 bravenew mporeis na analyseis ligo ti diadromi kai tis epiloges poy ekanes mallon ennoei oti exei valei manual tin ip tou pc tou px.192.168.1.2 auto exo kanei kai ego apo tote pou agorasa to USR9105 kai mexri tora den exo oute ena disconnect (to routeraki einai monimos anikto) !!!
ksessalonikios Δημοσ. 8 Αυγούστου 2005 Δημοσ. 8 Αυγούστου 2005 στο local area connections>properties>internet protocol>properties>use the folowing IP address>IP address ?????
WaVe Δημοσ. 9 Αυγούστου 2005 Μέλος Δημοσ. 9 Αυγούστου 2005 mallon ennoei oti exei valei manual tin ip tou pc tou px.192.168.1.2 auto exo kanei kai ego apo tote pou agorasa to USR9105 kai mexri tora den exo oute ena disconnect (to routeraki einai monimos anikto) !!! Re paidia k egw manual IP exw valei alla mou to kanei sixna. Emena otan alazei i IP mou kanoun disconnect ola to programata k den mporw na pw sto 192.168.1.1 ' date=' prepei na paw sto router k na klisw k na ksananoiksw to diakoptaki tou router. Oso gia tis alles plirofories pou thes [b']gv[/b] otan paw home tha tis kanw post!!
WaVe Δημοσ. 9 Αυγούστου 2005 Μέλος Δημοσ. 9 Αυγούστου 2005 Simera eida k tis rithmiseis mou, einai idies me aftes pou les k esu gv apla san Software Version leei: 1409_061604-2.14L.01A.BA08a :roll: Auti einai i teleftea?? ISP exw FORTHnet k DSLAM eimai se Siemens1, thats all
poulinos Δημοσ. 10 Αυγούστου 2005 Δημοσ. 10 Αυγούστου 2005 Re paidia k egw manual IP exw valei alla mou to kanei sixna.Emena otan alazei i IP mou kanoun disconnect ola to programata k den mporw na pw sto 192.168.1.1 ' date=' prepei na paw sto router k na klisw k na ksananoiksw to diakoptaki tou router. Oso gia tis alles plirofories pou thes [b']gv[/b] otan paw home tha tis kanw post!! ama den mporeis na mpeis sto 192.168.1.1 pou ine o router mipos ine kolima tou router.giati o isp den fteei kati.episis i xirokinita doseis tin ip sto tcp ip tis kartas diktiou i automatic apo ton dhcp pali den tha allaxei kati.
WaVe Δημοσ. 10 Αυγούστου 2005 Μέλος Δημοσ. 10 Αυγούστου 2005 Diavasa pados pws k allou user eixan to idio provlima, dld meta tin alagi IPs na min mporoun na boun sto 192.168.1.1, ax den kserw ti allo na pw ... :roll:
poulinos Δημοσ. 11 Αυγούστου 2005 Δημοσ. 11 Αυγούστου 2005 usr 9105 rules wave.right. ax kalo mou zyxel oso kai na se basanizo.ama bgaloun kana firmware update tote pisteuo oti tha lithei mia kai kali.mazepste stoixeia kai steilte ta kai mia sovari eteria pou ine i usr kati tha bgalei.
gv Δημοσ. 11 Αυγούστου 2005 Δημοσ. 11 Αυγούστου 2005 Αποσύνδεση και επανασύνδεση USR 9105 Σήμερα το πρωί, και καθώς δούλευα στο internet, το router μου έχασε την σύνδεση (κόκκινο WAN IP) και προσπάθησα να μπώ στο 192.168.1.1 για reboot ... (σημειώνω ότι είναι η πρώτη φορά που μου τυχαίνει να δω αποσυνδεδεμένο το USR9105) ... Ενώ μπήκα, αποφάσισα να περιμένω κάνα 10λεπτο για να δώ την συμπεριφορά του. Έκλεισα λοιπόν τον firefox και περίμενα ... Σε 2-3 λεπτά συνδέθηκε πάλι μόνο του !!! χωρίς να πειράξω το παραμικρό ... και φυσικά χωρίς reboot ... μήπως αν το αφήσετε λιγάκι συνδεθεί πάλι και το δικό σας ????
ksessalonikios Δημοσ. 11 Αυγούστου 2005 Δημοσ. 11 Αυγούστου 2005 μερες ολοκληρες να το αφήσω εγώ, προκοπή δεν βλεπω αν δεν βαλω το χεράκι μου
icy20 Δημοσ. 12 Αυγούστου 2005 Δημοσ. 12 Αυγούστου 2005 ΛΟΟΟΟΛ.Εσεις ειστε τυχεροι προφανως.Εμενα ουτε καν αναβει το λαμπακι του wan ip και κανει αποσυνδεση σχεδον καθε 2 ωρες!!!!!!ΔΕΝ φταιει η συγκεκριμενη συσκευη γιατι δοκιμασα και με καινουρια.Τοσους μηνες δεν ειχα κανενα προβλημα τον τελευταιο μηνα γινεται αυτο...Ξεκινησε 1-2 φορες τη μερα να αποσυνδεεται και τωρα το κανει καθε 2ωρο...Το θεμα ειναι οτι εχω over isdn...Εχει μονο ενα firmware.Με το βλαμενο το κρυπτο usb η συνδεση δεν καταλαβαινει χριστο...Και ΝΑΙ εχω και εγω 4νετ...Πρεπει να ειμαι σε intracom dslam αν δεν κανω λαθος...Απο ρυθμισεις εχω ακριβως τις ιδιες με το παιδι που εγραψε πρωτο...
poulinos Δημοσ. 12 Αυγούστου 2005 Δημοσ. 12 Αυγούστου 2005 na sou allazoun ip kathe dio ores pantos apo kai klietai.mono ama den katevazeis tipota meta apo mia ora tha gineis disconect kai o router tha xanampei automata.
