Boban Δημοσ. 25 Μαΐου 2005 Δημοσ. 25 Μαΐου 2005 to provlima moy einai to exis: sto suse 9.2 64 (kai to 32 to idio problima) otan telioni i egatastasi den mporo na diorthoso tin analisi.oti kai na pao na peiraxo apo to yast2 otan kano dokimi kolaei.An kano apothikeysi kolaei sinexeia kai den mporo na mpo se x windows. Nomizo oti exei sxesei me tin pci-e, katebasa ena patch gia diorhosi alla tipota. To 9.2 (32bit) to ixa se paliotero sistima kai einai kanoni. to sistima mou einai Athlon 64 3000+ msi k8n neo4 me nForce4ultra kai asus 6600256 mb pci-e
Holy Ghost Δημοσ. 27 Μαΐου 2005 Δημοσ. 27 Μαΐου 2005 o X Server pou enswmatownoun ta Suse 9.2 nomizw pws den exei module gia thn odhghsh kartwn ths nvidia...opote mias kai exeis kai 64bit cpu prepei na katevaseis thn 64bit ekdosh twn drivers,na thn kaneis compile ystera na kaneis ena edit to /etc/X11/xorg.conf wste gia driver na fortonei to module "nvidia" kai oxi to nv...a kai koita na sigoureuteis oti exeis yposthrisksh pci-x ston kernel sou....
Boban Δημοσ. 30 Μαΐου 2005 Μέλος Δημοσ. 30 Μαΐου 2005 nai ontos to nv exei alla kai pou kano update me to YOU (kai vazo tous nvidia drivers) den allazei kati.Ostoso kapos veltiothike i katastasi me to neo X11 kai to KDE 3.4. Alla den eimai euxaristimenos
Holy Ghost Δημοσ. 30 Μαΐου 2005 Δημοσ. 30 Μαΐου 2005 don't trust YOU.eisai tyxeros pou sou deixnei kai eikona pantos,emena den edeixne kan... Mpes monos sou sto site ths nvidia katevase tous teleutaious 64bit drivers. frontise mesa sto pc na yparxei o phgaios kwdikas tou trexontos pyrhna kai kantous monos sou compile.... To arxeio pou 8a katevaseis 8a exei katalhksh .run,gia na to trekseis anoigeis mia konsola ws root kai grafeis aplos " ./xxxxxx.run " Ystera kane edit sto /etc/X11/xorf.conf kai frontise sto section driver mesa sta quotes na leei nvidia...an to compile tou driver ginei epityxws tote grapse "su ---> modprobe nvidia" Afou ginoun ola auta anoikse to kde kai trekse mia konsola kai grapse glxinfo | grep direct...an leei yes eisai ok...gia peraitero test trekse to glxgears...ekei logika 8a pairnneis gyrw sta 7000 frames....oti provlhma exeis kata thn diadikasia kane post na voh8hosoume...
Boban Δημοσ. 30 Μαΐου 2005 Μέλος Δημοσ. 30 Μαΐου 2005 Distixos den doulepse an kai evala kai drivers gia Nforce prin alla me tous drivers tis kartas grafikon krasare kai den mpainei se X win. Xereis kamia ekdosi na doylepsei xoris provlimata se tetoio pc? to xriazomai gia tin doulia mou
Holy Ghost Δημοσ. 31 Μαΐου 2005 Δημοσ. 31 Μαΐου 2005 Εισαι σιγουρος οτι δεν εκανες καποιο λαθος? Εφτιαξα το μηχανημα ενος φιλου που εχει ακριβως το ιδιο συστημα με σενα και την 6600 με τον διπλο πυρηνα και ολα δουλευουν ρολοι... Λοιπον θα σου δωσω λιγο πιο συγκεκριμενες οδηγιες... 1. Κατεβαζεις τον οδηγο που χρησιμοποιησα και εγω απο εδω http://teivos.samos.aegean.gr/~holyghost/NVIDIA-Linux-x86_64-1.0-7174-pkg2.run (δεξι κλικ και Save Target As) 2. Σιγουρεψου οτι υπαρχει στον σκληρο σου ο πηγαιος κωδικας του πυρηνα ο gcc compiler και ο text editor Pico. Αν οχι εγκατεστησε τα μεσω Yast απο το DVD της διανομης σου. Υστερα ανοιξε μια κονσολα και γραψε su και τον κωδικο του root cd / cd /usr/src εδω πρεπει να ειναι ο πηγαιος κωδικας...αν θυμαμαι καλα ο φακελος ειναι " 2.6.8.24default "(η κατι παρομοιο) γραψε ls -col πρεπει οπωσδηποτε να υπαρχει ενας συμβολικος συνδεσμος (νομιζω θα εχει γαλαζιο χρωμα) με filename " linux " που να δειχνει στον φακελο που ειναι ο κωδικας. Αν δεν υπαρχει γραψε " ln -s xxxxxxx linux " οπου χχχχχ ο φακελος του κωδικα(αυτος που ειπαμε παραπανω) 3. Κανε επανεκινηση και μολις εμφανιστει ο boot loader πατα στην επιλογη που λεει failsafe. Αυτο λογικα θα εκκινησει τον υπολογιστη μονο σε κονσολα χωρις να ξεκινησει ο Χ...εαν παρολα αυτα ξεκινησει ο Χ τοτε με το που ξεκινησει πατα CTRL+ALT+BACKSPACE για να τον κανεις kill. 4. Πηγαινε στον φακελο που εχεις το αρχειο που κατεβασες 5. Γραψε ./NVIDIA-Linux-x86_64-1.0-7174-pkg2.run η sh NVIDIA-Linux-x86_64-1.0-7174-pkg2.run. Οταν στον οδηγο της εγκταστασης σου πει οτι "No precompiled drivers found...do you want to download precompiled drivers from nvidia's site? " εδω λες ΝΟ και συνεχιζεις με το compile. Καποια στιγμη θα σε ρωτησει αν θες να κανει compile κατι 32bit opengl libraries για θεματα συμβατιτητας, εδω λες YES...Αν ολα πανε οπως τα θελουμε λογικα θα σου πει οτι το compile τελειωσε επιτυχως και αν τρεχετε SUSE linux ανοιξτε το Sax2 για να κανετε τις απαραιτητες ρυθμισεις... 6. Αγνοεις το παραπανω μυνημα, βγαινεις απο την εγκτασταση και γραφεις cd / cd /etc/X11/ pico xorg.conf Σε αυτο το αρχειο ειναι μαζεμενες οι περισσοτερες ρυθμισεις για τον Χ. Πατας pagedown και πας στο σημειο που λεει Section "Device" Identifier "NVIDIA Graphics Adapter" Driver "nv" Σβηνεις το nv και γραφεις nvidia μεσα στα quotes Μολις τελιωσεις το edit πατα CTRL + X για να σωσεις το αρχειο. Ο pico θα σε ρωτησει με τι ονομα να σωσει το αλλαγμενο αρχειο,λογικα θα λεει απο μονο του xorg.conf. Γενικα στις ερωτησεις του pico μετα το CTRL + X πατας Y στην 1η και ENTER στη 2η 7. Αφου εσωσες το αρχειο τοτε οπως εισαι γραφεις modprobe nvidia (αυτη η εντολη φορτωνει απευθειας στον πυρηνα τον driver που εκανες πριν λιγο compile). Αν ολα εχουν παει καλα η εντολη αυτη δεν θα πεταξει κανενα μυνημα λαθους 8. Τελος γραφεις exit για να βγεις απο superuser mode και μετα startx για να ξεκινησει ο Χ..Λογικα θα εμφανισει το logo της nvidia και θα σε βαλει στο KDE (η οποιο γραφικο περιβαλλον εχεις επιλεξει). Καλο θα ειναι να κανεις κατευθειαν μια επανεκινηση... 9. Αν το γραφικο περιβαλλον φορτωσει κανονικια τοτε μπορεις να κανεις και δυο τελευταια τεστακια για να εξακριβωσεις τη λειτουργικοτητα του οδηγου...ανοιξε μια κονσολα και γραψε glxinfo | grep direct. Αν σου εμφανισει direct rendering = yes τοτε πηγαν ολα καλα...επισης γραψε glxgears και δες ποσα frames/sec σου βγαζει (λογικα θα ναι πανω απο 6500). Α και ενα τελευταιο τεστακι, αν η επιταχυνση απο το υλικο (direct rendering) δουλευει σωστα τοτε το γραφικο περιβαλλον θα εχει πιο παχια υφη (smooth). Αυτο ειναι θεμα παρατηριτηκοτητας βεβαια... Αν παλι παει κατι στραβα μολις γραψεις startx δλδ κολλησει παλι η κατι τετοιο...τοτε πατα ενα CTRL + ALT + BACKSPACE για να σκοτωσεις τον Χ και σιγουρεψου οτι ολα τα βηματα της διαδικασιας εγιναν σωστα.... Ελπιζω να βοηθησει αυτος ο μικρος οδηγος...αν εχεις παλι καποιο προβλημα πεστο για να σε βοηθησω....
Boban Δημοσ. 31 Μαΐου 2005 Μέλος Δημοσ. 31 Μαΐου 2005 ok tha ta dokimaso ola auta se clean install. Euxaristo gia tin voithia
Boban Δημοσ. 1 Ιουνίου 2005 Μέλος Δημοσ. 1 Ιουνίου 2005 Distixos pali den doulepse. Prota apo ola sto xorg.conf den exei device idetifier NVidia Graphics adapter kai to evala ego ekei poy eixe driver ton nv os identifier ixe Device[0] pantos otan kano startx grafei os error open /dev/fb0 no such device no devices detected no screens found
Holy Ghost Δημοσ. 2 Ιουνίου 2005 Δημοσ. 2 Ιουνίου 2005 opa vlakeia....allakses auto pou elege Device[0] kai to evales ws Nvidia Graphics adapter...mega la8os...vasika la8os diko mou pou to egrapsa etsi...aplws den 8ymomouna ti akrivws elege...to mono pou eprepe na allakseis htan to nv na to kaneis nvidia....ksanallakse to kai grapse pali oti eixe prin...nomizw ston idio fakelo o pico exei krathsei ena backup tou idiou arxeiou ws xorg.conf~. To compile pantos eisai sigouros oti egine swsta? h entolh modprobe nvidia den vgazei kana error etsi? An allazontas to Nvidia Graphics..... kai to kaneis pali opos htan Device[0] alla me driver to module nvidia den doulepsei, tote grapse ws root xorgconfig (einai edw ----> /usr/X11R6/bin) kai apanthse stis erwthseis pou 8a sou kanei....ystera ksanakane edit to xorg.conf kai allakse mono nv ---> nvidia.... kapoia stigmh shmera 8a sou dwsw ena ena sample gia to xorg.conf....
