Nemo Δημοσ. 23 Ιουλίου 2002 Δημοσ. 23 Ιουλίου 2002 Apo oti exei anaferthei se forums xriston 3dfx en syntomia doylevei se win98 (xp???? mono se 2d view ) ,( 1) .a: Win98 SE .: Voodoo3 drivers (version 1.03) :: www.falconfly.de/voodoo3.htm .: Cheff's Patch :: 24.48.236.145:82/CheffzPatchV2.exe .: GTA3 Ultimate Trainer +28 :: dl.gamecopyworld.com/dl.c...r%20v2!zip 2)For quite some time now, i've tried to run the damn "GTA3" game in my PC (AMD Athlon 1.2GHz, 256MB SDRAM, Voodoo3 2000 PCI 16MB, Sound Blaster Live! Platinum 5.1, Generic 15' Display supporting 1024x768 max res... Well, in the beginning, I got that damn freeze-after-5-seconds BUG, then I changed the default view to "Bird's Point of View", and worked for some time, crashes were still happening, and I was going NUTS. So I looked at some articles, done some things, and actually improved my game play, could play at least 15-30 minutes withought **** crashes. But anyway, in the end, it crashed. God-damn. Things I've done follows: 1. Update game to 1.1 (http://www.rockstar.com) 2. Used Pa3PyX's Drivers for Win9X (downt know if they're vaporware, just know they're damn fast and crashes GTA3 less than any other driver I've ever used. Remember to enter Safe Mode, deleting any files starting with 3dfx, but DO NOT remove 3dfxcmn.dll if it exists. Get Pa3PyX's Drivers at http://members.fortunecity.com/pa3pyx/ , and install'em in Safe mode, just after deleting the 3dfx* files. Again, I DON'T KNOW the nature of this driver, if it's vaporware, if it'll damage your PC, so DONT BLAME ME IF IT DOESNT WORK. Ok? Oh, and download the latest VIA 4-in-1 at www.viahardware.com if you own a VIA chipset. 3. Delete the txd.img file inside GTA3\models . This is the file with the optimized textures. 4. Disable geometry assist, disable EVERYTHING, use "MipMap LOD Bias" value +8 (You can do this in 3dfx Underground Tools or 3dfx tools, I use both). 5. Visit www.sheepyuk.com and get the HightFPS mod. Personally, I use 16Color textures, I disable papers and leave the pedrestians setting alone... 6. Start GTA3, set display settings to 640x480 resolution, view distance to minimum, this doesnt change anything anyway... 7. Start a game, skip ALL cutscenes, they're great, but hell, they lock the pc 80% of the times i've tried!! 8. Have fun! You'll notice you cant get past that damn "Cutting the Grass" mission and the one wich follows, but i've played the game in my friend's pc with a GeForce2 and got the savegames..., I dont know how to make them avaiable for download, so if there's anyone interested I may e-mail these 2 files (the After-Cutting the Grass Mission and after- Post "Cutting the Grass")... OK? Ok, i've done all this, it really improved my GTA3 gameplay... I noticed that then the game hangs, the next time I went out in the crazy Liberty City world, there would be more chances for the game to hang again, if I havent deleted the txd.img file before starting playing. So, i created a theory... If there's some corrupted textures in the txd.img file (that is the optimized texture files for the voodoo3) the card wouldnt understand these textures and would hang your PC. And, then you restart, as the txd.img file is always being used, more textures would become corrupted, and so the more you play, the more the game crashes. Ok, so I copied the txd.img from my geforce2 friend, and guess what? GTA3 realised someway i've changed the txd.img file and my pc freezed before loading... So, there's some kind of built-in protection inside GTA3, to keep us from playing, because, if my theory is correct, and if there's a way to remove this protection, we could play, because: 1. At the time of the while-loading GTA3 crash, there were no image beside that ugly bitmap, so it couldn't have been a voodoo3 problem 2. The voodoo3 automatically converts textures it cant use, via hardware, as far as I know. This is proven by Max Payne, in the "comics-like screens", that become blurry, but don't crash. ................... gia perissotera info http://3dhq.mine.nu:81/forums/viewtopic.php?t=3476 http://pub43.ezboard.com/fx3dfxfrm2.showMessage?topicID=2235.topic http://pub43.ezboard.com/fx3dfxfrm2.showMessage?topicID=2235.topic http://3dhq.mine.nu:81/forums/viewtopic.php?t=3684 http://www.voodoofiles.net/cgi-bin/ikonboard.cgi?s=3d3bc931646effff;act=ST;f=27;t=32 Exei anaferthei iti to paixnidi exei treksei kapoios me banshee karta progonos-prodromos kai mia skala kato apo tis v3 ta pio simantika forum gia 3dfx gia psaxeis perissotero http://www.voodoofiles.net/cgi-bin/ikonboard.cgi?s=3d3bc931646effff http://pub43.ezboard.com/bx3dfx http://3dhq.mine.nu:81/forums/index.php Pantos anamenete kykloforia neon driver apo user groups (http://3dhq.mine.nu:81/forums) p ou apo oti ypostirizoun tha einai dx 8.1b combatible (oi 1.09 poy kykloforoun se beta )k ai akoma tha exoun opengl1.2 compatibility ) <small>[ 22-07-2002, 12:18: Το μήνυμα επεξεργάστηκε από: Nemo ]</small>
midas2004 Δημοσ. 24 Ιουλίου 2002 Δημοσ. 24 Ιουλίου 2002 paidia pragmati me xp paizei,eno me ta millenium oxi...eixa me kai den epeze..molis ebala xp prin 1-2 bdomades paizei kai taytoxrona paizo kai ego!milame kabla to paixnidaki..
wOOzY Δημοσ. 24 Ιουλίου 2002 Δημοσ. 24 Ιουλίου 2002 Παιδιά έβαλα Windows XP Professional Ελληνικά.Έχω το εξής πρόβλημα: Έκανα εγκατάσταση το παιχνίδι,μπαίνω μέσα στο Menu,δεν βλέπω καθόλου τα γράμματα(New game κτλπ),μόλις μπω στο Game και πάω να πάρω το αμάξι,το παιχνίδι είναι τετραγωνισμένο και πάει πολύ αργά,με αποτέλεσμα να καταντάει εκνευριστικό!Καμιά ιδέα;Το σύστημα μου είναι: 1.333 Mhz,256 Ram,Creative Ge Force 2 Mx 400...Κάτι είχε πάρει το μάτι μου για ένα Patch,που κάνει για τα Windows XP,αν μπορείτε φέρτε μία και το UrL για να το κατεβάσω..Φιλικά,Δημήτρης.Ευχαριστώ! <img border="0" title="" alt="[smile]" src="images/icons/smile.gif" /> <small>[ 24-07-2002, 06:07: Το μήνυμα επεξεργάστηκε από: Fo©us ]</small>
DJ_XLR8 Δημοσ. 24 Ιουλίου 2002 Μέλος Δημοσ. 24 Ιουλίου 2002 If you are getting no textures or an incredibly dense fog in the game with an NVIDIA video card, you need to enable Fog Table Emulation. Right Click on an empty area of the desktop Left Click on Properties Click on the Settings Tab Click on Advanced Properties Click on the GeForce Tab (it will have the same name as you video card) Click on the Additional Properties Click on the Direct3D Setting Tab Place a Check Mark next to Enable For Table Emulation Click Apply Click OK and keep clicking OK until all those windows are closed. Then try the game again. Also with Nvidia cards, Anti aliasing settings Right Click on an empty area of the desktop Left Click on Properties Click on the Settings Tab Click on Advanced Properties Click on the GeForce Tab (it will have the same name as you video card) Click on the Additional Properties Click on 3d Anti aliasing Change setting (anything but off made my G3Ti200 choppy) Click Apply TEST Το patch για τα WinXP.
wOOzY Δημοσ. 24 Ιουλίου 2002 Δημοσ. 24 Ιουλίου 2002 Φίλε μου σε ευχαριστώ πολύ! <img border="0" title="" alt="[smile]" src="images/icons/smile.gif" /> EDIT:Κατέβασα το Patch,το τρέχω,μου βγάζει ένα Error και λέει ότι η γλώσσα του είναι διαφορετική από αυτήν που έχουν τα Windows..Έχω Ελληνικά,το Patch είναι στα Αγγλικά..Ευχαριστώ πολύ και πάλι! <small>[ 24-07-2002, 14:17: Το μήνυμα επεξεργάστηκε από: Fo©us ]</small>
poisom Δημοσ. 25 Ιουλίου 2002 Δημοσ. 25 Ιουλίου 2002 HI PAIDES! EGW PALI (WS GNWSTOS GKANTEMEIS) EXW ENA NEO PROBLIMA POU DEN EXEI PAROUSIASTEISE KANENAN WS TWRA (NOMIZW)! KANW INSTALL TO GAME GIA PRWTI FORA LOIPON APO TO 1o CD META BAZW TO 2o CD GIA NA PAIKSW. TO PAIXNIDI KSEKINAEI KANONIKA BLEPW TA EISAGWGIKA VIDEOS KAI MPAINW STO ARXIKO MENU. WS EDW EIMASTE KALA SYNEXIZONTAS LIPON KANW NEW GAME KAI TA SXETIKA KSEKINAW NA PAIZW ME PSILOKOLLHMATA OXI OMWS ENOXLITIKA KAI OPWS KATEBAINW TON ARXIKO DROMO KANW TIS KATALLILES MANOYBRES (KAI TWRA TO KALO) KAI SAN NEOS ODIGOS TO TRAKARW SE KAMIA KOLONA I SE KANENA ALLO AMAXI KAI META APO 2 sec TO PIAXNIDI KANEI TO POLYPOTHETW CRASH KAI META ARXIZW EGW @@!##$#!$%$%5$#%^$^!@$#$@#$%45 !@$!$@#$@%$@% GRRR!!!! EXW XP PROFESIONAL ENGLISH VERSION CELERON 750(OVERCLOCKED) RIVA TNT 2 M64 DETONATORS 28.42 512 RAM LIP0N TI EXETE NA MOY PROTINETAI PLEASE HELP ME!!!
pieros Δημοσ. 27 Ιουλίου 2002 Δημοσ. 27 Ιουλίου 2002 file poisom isws irthe i wra na skefteis gia mia anabathmisi kartas grafikwn! Filika <img border="0" title="" alt="[Wink]" src="images/icons/wink.gif" />
ex_tep Δημοσ. 27 Ιουλίου 2002 Δημοσ. 27 Ιουλίου 2002 Ki egw auto tha protina.Akomi kai h GF3 ligi peftei gi auto to paixnidi:)Bebaia me ena sindiasmo GF3 kai kalou epeksergasth den tha xeis prob kanena
TJ Δημοσ. 29 Ιουλίου 2002 Δημοσ. 29 Ιουλίου 2002 Paidia opoios exei provlima me to menu tou pexnidiou den fenode ta grammata (under windows XP)to paixnidi exei provlima me ta Windows XP xriazete ena update..Eixa kai ego to idio provlima protou koitaxo to readme tou paixnidiou pou egrafe : Windows XP + nVIDIA based cards (possibly other brands): We have found a possible problem with Windows XP that manifests itself as graphical problems both in the game menu and also during game play. We have traced this problem to be a Windows XP problem. Technically this problem is solved by the use of a newer version of d3d8.dll than is shipped on CD with Windows XP. (The version on the Windows XP CD that has problems is 5.1.26000.0 versions tested without error include 5.1.2600.15 and 5.1.2600.29) Currently the only way we know to update this dll file is to install the Windows XP Patch: The Computer Cannot Enter Standby or Hibernate If a Direct3D-Based Screen Saver Is Running (Q306676) downloadable from the following Web Site: http://download.microsoft.com/download/whistler/Patch/Q306676/WXP/EN- US/Q306676_WXP_SP1_x86_ENU.exe. katevaste to patch kai tha ftiaxei ... kai emena mou pigenei kapos arga se analisi 800*600 kai exo AMD 2000xp kai Geforce 256 DDR.. <small>[ 29-07-2002, 01:33: Το μήνυμα επεξεργάστηκε από: TJ ]</small>
kavaliotis Δημοσ. 30 Ιουλίου 2002 Δημοσ. 30 Ιουλίου 2002 Pantos me to susthma pou exo sto signature mou kato se sunduasmo me WindowsXP to epaiza teleia xoris kanena problhma se 1024x768 32bit! Phgaine kai parapano alla eiani kalh analush auth kai etsi paizo se authn! To eixa apo antegrammeno kai etreksa to Patch kai ola ok! Exo kollhsei se mia apostolh tora kai den ksero ti na kano! Oso gia tous allous, to dokimasa me thn karta thn dikia mou se PII 400Mhz kai paizei kaloutsika, otan exei polla graphics phgainei ligo pio arga, alla an eisai porwmenos mporeis na to paikseis me ligh duskolia! Parte mia kalh karta grafikwn, anamenontai polla nea paixnidia!
Maglaras Δημοσ. 24 Αυγούστου 2002 Δημοσ. 24 Αυγούστου 2002 </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DJ XLR8: <strong>If you are getting no textures or an incredibly dense fog in the game with an NVIDIA video card, you need to enable Fog Table Emulation. Right Click on an empty area of the desktop Left Click on Properties Click on the Settings Tab Click on Advanced Properties Click on the GeForce Tab (it will have the same name as you video card) Click on the Additional Properties Click on the Direct3D Setting Tab Place a Check Mark next to Enable For Table Emulation Click Apply Click OK and keep clicking OK until all those windows are closed. Then try the game again. Also with Nvidia cards, Anti aliasing settings Right Click on an empty area of the desktop Left Click on Properties Click on the Settings Tab Click on Advanced Properties Click on the GeForce Tab (it will have the same name as you video card) Click on the Additional Properties Click on 3d Anti aliasing Change setting (anything but off made my G3Ti200 choppy) Click Apply TEST Το patch για τα WinXP.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Ta ekana ola afta alla kai pali dem fenonte ta gramata kai i piotita tis eikonas den einai kai oti kalitero. Ti allo xriazete na kanw gia na doulepsei? Exw ena P4-1.8 kai mia GF2MX400-64mb Edit: to path pou lete einai anageo? <small>[ 23-08-2002, 20:57: Το μήνυμα επεξεργάστηκε από: Maglaras ]</small>
msnes7 Δημοσ. 25 Αυγούστου 2002 Δημοσ. 25 Αυγούστου 2002 ΠΑΙΔΕΣ ΕΧΩ ΚΑΙ ΕΓΩ ΑΥΤΟ ΤΟ ΚΑΤΑΠΛΗΚΤΙΚΟ ΠΑΙΧΝΙΔΙ ΑΛΛΑ ΟΤΑΝ ΤΟ ΠΗΡΑ ΠΗΓΑ ΝΑ ΠΑΘΩ ΣΟΚ ΕΧΩ PIII 550 W98 384 RAM GF3 T500 KAI TO ΠΑΙΧΝΙΔΙ ΕΚΑΝΕ ΜΙΚΡΟΚΟΛΛΗΜΑΤΑ ΣΑΝ ΝΑ ΕΚΑΝΕ CACHE THN ΔΙΑΔΡΟΜΗ.ΑΦΟΥ ΕΠΣΑΞΑ ΣΤΟ INTERNET ΔΙΑΒΑΣΑ ΣΕ ΞΕΝΟ ΦΟΡΟΥΜ ΟΤΙ ΤΟ ΠΑΙΧΝΙΔΙ ΧΡΕΙΑΖΕΤΑΙ CPU>800 MHZ KAI 64 MB RAM.ΛΕΩ ΜΑΛΛΟΝ Ο ΕΠΕΞΕΡΓΑΣΤΗΣ ΘΑ ΦΤΑΙΕΙ ΑΛΛΑ ΕΙΔΑ ΟΤΙ ΕΒΓΑΛΕ Η ΕΤΑΙΡΙΑ ΕΝΑ PATCH TO ΟΠΟΙΟ ΔΙΟΡΘΩΝΕΙ ΚΑΠΩΣ ΤΗΝ ΚΑΤΑΣΤΑΣΗ ΣΤΟ FRAME RATE.ΕΒΓΑΛΑ ΤΑ ΜΟΥΣΙΚΑ ΚΟΜΜΑΤΙΑ ΚΑΙ ΜΠΟΡΩ ΝΑ ΠΩ ΟΤΙ ΤΡΕΧΕΙ ΚΑΠΩΣ ΙΚΑΝΟΠΟΙΗΤΙΚΑ.
Nemo Δημοσ. 5 Σεπτεμβρίου 2002 Δημοσ. 5 Σεπτεμβρίου 2002 http://www.voodoofiles.com/7802 Amigamerlin 2.5 for Voodoo 3/4/5 Version 2.5 and support DirectX...........................It's said that these drivers can run GTA 3 without having it crash............................. To whom it may concern , might help.
polaki Δημοσ. 6 Σεπτεμβρίου 2002 Δημοσ. 6 Σεπτεμβρίου 2002 </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by timiman: <strong>Shit!! Πάντως φίλε ΠΡΑΓΜΑΤΙΚΑ ΑΞΙΖΕΙ να αλλάξεις κάρτα γραφικών για να παίζεις αυτό το παιχνίδι! Προσωπικά πιστεύω ότι είναι κλασσικό παιχνίδι για να κολλήσεις με τις ώρες και να παίζεις ασταμάτητα!!</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Tiiiiiiiiii?? Ti les tora, edo ego pira olokliro Playstation 2 ton Ianouario otan epaiksa to paixnidi se ena filo mou...!! <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" /> <img border="0" title="" alt="[big Grin]" src="images/icons/grin.gif" /> Oxi karta grafikon aksizei na allakseis, systima olokliro!!!!!
